What’s the difference between the Mazda CX-70 and the Mazda CX-90 – other than the latter having three rows while the former has two?
Next to nothing.
There’s also a big difference between the both of them and every other full-size crossover in their class: They both come standard with an inline six cylinder engine. You have to move up to the luxury crossover class – in price – to get anything like that and even then, you sometimes don’t.
The CX-70 is the two-row iteration of the CX-90. Or you could say the CX-90 is the three-row iteration of the CX-70. It amounts to the same thing as both are otherwise pretty much the same large crossover, with identical standard and optionally available drivetrains.
There are, however, some differences in trim – and price.
Interestingly, you can get the three-row CX-90 for several thousand bucks less than two-row CX-70 because Mazda offers the three-row CX-90 in a “base” 3.3 Turbo Select trim that lists for $38,800. The the two-row CX-90 isn’t available in that trim. It starts at $40,445 for the Turbo Preferred, which comes with 21 inch rather than 19 inch wheels, standard leather seats covers, a heated steering wheel, sunroof, wireless connectivity and a larger, upgraded 12.3 inch LCD center display.
The reason for this difference is probably that Mazda assumes the three-row CX-90 will be more attractive to people who have kids to carry around and so are probably focused a bit more on practical considerations – which includes budgetary ones – while the likely CX-70 prospect is more focused on amenities for adults.
Still, the base trims of both CXs come standard with Mazda’s new 3.3 liter inline/turbocharged six, which is augmented by a mild-hybrid system that’s chiefly there to pump up the gas mileage by powering accessories electrically when the load is light and the six can be shut down (automatically) to conserve fuel.
A high performance version of this same engine is standard in Turbo S versions, which sticker for $53,240 to start and top out at $56,670 for the Turbo S Premium Plus, which also gets pretty much all of the luxury amenities in the lower trims, plus quilted leather seat covers.
There’s also a third option.
Mazda offers the CX-90 with a plug-in hybrid drivetrain that replaces the 3.3 liter six with a 2.5 liter four augmented by a more powerful hybrid system that can be externally charged, like an EV – and that can driven for about 25 miles on battery power alone – but that does not have to be plugged in to continue driving it (like an EV) when the charge is depleted; the gas engine takes over at that point and charges the batteries as you drive.
The plug-in PHEV (Partial Hybrid Electric Vehicle) CX-70 is available in two trims, the $44,250 PHEV SC and the $47,250 PHEV SC Plus.
What’s New For 2026
The most notable change for the new model year is a new/standard tow mode (Premium and Premium Plus trims) that increases the CX-70’s towing capacity to 5,000 lbs. The base Turbo Preferred trim also gets standard heated seats, which were formerly optional.
What’s Good
In addition to being all-around a very nice large crossover, the CX embarrasses higher priced luxury brand crossovers from Lexus and Audi that come standard with four cylinder engines.
Plug-in variant offers almost as much power as the Turbo S six and EV capability without the EV liability.
Driving verve – and not just in a straight line – both qualities lacking in so many other crossovers.
What’s Not So Good
“Mild hybrid” augmentation is a compliance technology that adds to the cost of the CX-70 (and CX-90) and arguably isn’t of much benefit to the vehicle owner.
Optional (and desirable) higher-powered version of the 3.3 liter inline six is restricted to much more expensive trims.
As is true of almost every new vehicle, the CX-70’s LCD touchscreen interface isn’t as easy to use as “old fashioned” switches and buttons.
Mazda did something interesting, brave – and smart. Instead of replacing a six with a turbo four – as has become very common, as a compliance measure – Mazda developed a brand-new inline six for its top-of-the-line models, the CX-70 and CX-90.
This was brave, obviously, given the push – from the federal government – to downsize engines, in order to better comply with federal gas mileage and emissions (of CO2) regulations – which seemed destined to wax rather than wane. It was also smart – because, as it turns out, the regs are waning – courtesy of Trump’s ending of the so-called “endangerment” finding that was the basis for regulating CO2 as an “emission” (implying it is a pollutant, which is absurd since it has nothing to do with air quality) and his pushing back the scheduled near-doubling of Corporate Average Fuel Economy (CAFE) requirements to 50 MPG, which along with the “endangerment finding” are why there are so many little turbo fours under the hoods of even large crossovers that used to always come with sixes. Including even luxury-brand crossovers such as the Lexus RX350, which now comes only with a turbo/hybrid-augmented four.
This Mazda six isn’t just a six, either. It is an inline six, which is the kind of six generally found only in luxury-brand vehicles, as for example those made by BMW and Mercedes-Benz. There are two reasons why. One is that the inline configuration is exceptionally smooth and free revving, because inline sixes don’t need heavy balance weights to smooth out what would otherwise be a rough idle. The other reason is they are long – relative to a V6 – and so generally only fit (front to back rather than side to side) under the hood of vehicles built around a rear-drive layout. These are generally luxury-brand vehicles, as from BMW and Mercedes.
While the CX-70 (and CX-90) come standard with AWD, it is a rear-biased system – meaning it default sends most of the engine’s power to the rear wheels rather than the front wheels, as in the case of vehicles built on a front-biased system, with the engine sending power to the front wheels most of the time. The Mazda’s six is mounted front-to-back and not side-to-side. There are definite benefits to both, which we’ll get into shortly.
The standard version of the 3.3 liter six makes 280 horsepower; the higher-output version in the Turbo S trim touts 340 horsepower, enough to get the CX-70 to 60 in six seconds. Gas mileage with the stronger engine is – interestingly – essentially the same as with the base version of the engine, which touts 24 city, 28 highway vs. 23 city, 28 highway for the stronger engine. Both engines have one of those “mild-hybrid” systems that automatically cuts off the gas engine during coasting/deceleration and when the vehicle isn’t moving – to help with compliance.
An eight speed automatic is standard with both versions – as is full-time AWD.
Mazda also offers a four cylinder engine – augmented with a plug-in hybrid system – as an optional choice, for those who like the idea of a vehicle that can operate for short hops as an electric vehicle without the long having-to-waits of an electric vehicle. The 2.5 liter four plus the hybrid stuff touts 323 horsepower and the ability to drive about 25 miles on battery power. After that, the gas engine automatically kicks on and you can keep driving until you run low on gas. Touted mileage with this Partial Hybrid Electric Vehicle (PHEV) is 24 city, 27 – about the same as with the inline six.
This Mazda is unusual in another respect, already mentioned. It is the only non-luxury-brand large crossover that’s based on a rear-drive layout, with its engine mounted front-to-back rather than side-to-side.
This distributes the weight of the drivetrain more evenly, front-to-back. FWD-based vehicles with their engines mounted sideways have a transaxle – transmission and axle bundled together into a single unit – snugged up against the engine; most of the drivetrain’s weight is thus over the front wheels. This is not something that matters much in terms of driving feel unless you like to drive fast, especially in the curves.
Then, it does.
FWD-based vehicles are nose heavy and tend to understeer. They push toward the outside of the curve. Rear-drive vehicles are better balanced and when pushed, tend to oversteer. The rear end will start to come around, unless you keep on the gas – which can be a little scary until you master the art of the thing.
The difference is one feels better than the other to the enthusiast driver. The type of driver who’d really prefer to have a Miata but has kids and needs the extra seats.
For the most part, that kind of fun is limited to the high-priced stuff from luxury brands such as BMW (as for example the X5) and Mercedes (the M-Class). But what you’re getting here is something that is laid our very similarly that costs about $20k less and comes standard with a six rather than a 2.0 liter four.
Even if you don’t want to corner like an SCCA driver, you’ll find the Mazda just feels intangibly better than the FWD-based stuff. And you’ll find the sound of the six a lot more appealing than the under-engined sound of a 2.0 liter four.
Another intangible thing that’s also a measurable thing is the length of the Mazda’s hood. It is pleasant to look over that long hood. It is a quality that once defined cars of substance. Most cars have scrunched up, boxy noses because they have little engines bunched under them, which is fine for an appliance.
This is something more.
The CX-70 is 200.8 inches long, which defines it as full-size. The main difference between it the CX-90 is that inside, there are two rather than three rows, so you’ve got more room for stuff and a bit less for people. Specifically, you have 39.6 cubic feet behind the second for whatever you need to haul around vs. 14.9 cubic feet behind the CX-90’s third row. Both CX’s have roughly the same total available space – 75.3 and 74.2 cubic feet, respectively – but it’s easier (faster) to make full use of it in the CX-70 because it’s not necessary to spend any time or effort folding away a third row that’s not there to begin with.
Like the exterior, much attention was given to the CX-70’s interior, to make it appealing to look at. This ins’t easy within the parameters set by the “crossover” template; at least, not without taking away from the practicality and utility that are the main reasons why most people buy a crossover. Many would probably love to have a Miata instead, but the family won’t fit into one.
Mazda wants to keep them in the family, though – by getting the buyer’s family into a crossover that does not look, drive or feel like an appliance.
Both the CX-70 and CX-90 punch way above their weight on both counts. They are good-looking on the outside and rich-looking inside. A particular aspect of this being the absence of a cheap-looking gaudy LCD touchscreen display such as one does find inside luxury-brand (and priced) large crossovers such as the BMW X5 and Benz GLE. Yes, there is an LCD display, but it’s small and tasteful and not staring the driver in the face.
The driver gets analog-style gauges in a proper instrument cluster. The steering wheel has an air bag (of course, because it must) but it does not look like it does. Soft padding covers many dash surfaces and everything just flows coherently, elegantly. It is for this reason a genuinely pleasant place to spend time in.
Even more so when you think about what you paid – vs. what the guy who bought the Benz paid.
It’s a small thing in the grand scheme of things, but it’s curious that Mazda prices the three-row CX-90 just a little bit higher-to-start than the two-row CX-70. On the other hand, the CX-70 does come with more standard stuff (as described earlier) for the extra $1,645 you pay.
It’s hard to get excited about crossovers – because most of them are just transportation appliances.
That’s why it’s exciting to come across one that isn’t.
If you like what you’ve found here please consider supporting EPautos.Â
We depend on you to keep the wheels turning!Â
Our donate button is here.Â
[…] https://www.ericpetersautos.com/2026/03/01/2026-mazda-cx-70/ […]
It’s unfortunate they’re not selling the CX-60 in the States. It’s much better-looking, cheaper, and a more reasonable size.
The CX-70 may look svelte, but its weight is in the 4,800 to 4,900 lbs range.
Like nearly all modern vehicles, it’s a fat-ass porker.
I like Mazda but the screen is a no, and future longevity? The odd repair guy with the accent on YouTube pointed out the problem with repairing stuff on the 90 version. Just about anything requires removal of the front of the car. Turbos, the hybrid drive – good luck with a modern wrench spinner working under the time constraints of warranty work getting it back together correctly.
Did they fix the hybrid/gas engine drivability glitch? First year many complaints about odd transition from one to the other.
I rented a ’24 CX-90 in Honolulu and it’s a good car. Because it had the 3rd row it was a juggle to fit a 9′ surfboard in it. The CX-70 w/o the 3rd row would be better fit for me. I’m actually starting to look at the CX-50 as an eventual replacement for my wife’s ’23 CX-5 PP. The smart move would be to keep the CX-5, low mileage and paid off.
I folded the 3rd row down on the CX-90, but for some reason the second row wouldn’t fold down all the way no matter what I tried, only like one third of the way. Never did figure out what was going on, checked the manual and online and never could figure it out. Pretty weird. Think with the CX-90 3rd row the second row is designed to only tip forward to get into the 3rd row. Something like that, unless I’m off base and wrong about that. Unless you definitely need the third row for hauling people and kids, I’d stick with the CX-50 because the back seats fold down flat. Keep up the good work Eric.
Correction, would stick with the two row CX-70 over the 3 row CX-90.
Another correction. I watched a YT video and the middle seat on the 3 row CX-90 does fold down flat with the lever on the seat bottom. The levers didn’t work on the one that I rented, possibly attributed to abuse by previous renters. Not sure what was happening to my memory.
Wait till you see the interior of the new CX-5. They got rid of most buttons and went with a giant touch screen. Sad to see Mazda caving in to that trend.
Guy at work hit a deer with his tesla. In addition to traveling an hour away to the approved tesla body shop, he ended up with the cx-70 as a rental.
He said he likes it very much, but he’s not a car guy [see tesla] so don’t know anything about it.
Morning, Dan!
I’m a car guy – and I like it. If I had to have a crossover, I mean. There are built-in compromises with any family-type vehicle. But Mazda does a fine job infusing some Miata-ness in all of its vehicles.
RWD based AWD! yay!
inline 6! yay!
std auto trans (not cv)! yay!
could deal without mild hybrid but we have to pick our compliance poison these days.
If jeep doesn’t put their strait 6 or the v8 back in the grand cherokee in 1-2 years, I’ll look at this car for sure, or the new charger?
Thanks Eric.
