Jaguar has the same problem that Chrysler’s dealing with. Both of these brands currently have just one new model to sell. For Chrysler, it’s the Pacifica minivan. For Jaguar, it’s the F-Pace, which is an SUV.
Both brands haven’t got anything else to sell at the moment because they intended to be selling something different – electric vehicles – by now. The problem is that EVs aren’t selling well, especially the high end ones. Mercedes, BMW and Porsche have all walked back their prior “commitment” to electrify their entire lineups – in order to avoid EVs stacking up unsold on their dealers’ lots. They are going back to selling vehicles with engines – because those do sell.
Jaguar’s problem is that it hasn’t got anything else to send its dealers, to fill the spaces on the showroom floor that were supposed to be filled with new Jaguar EVs that aren’t coming anytime soon.
For now at least, the F-Pace must carry the flag all by itself.
The F-Pace is a luxury-performance SUV sold by Jaguar. It is not a crossover. These terms are often used interchangeably, which creates confusion about what a given SUV – or crossover – actually is.
An SUV can also be made to look like a crossover – and a crossover can be made to look like an SUV, adding to the confusion.
So – what are the differences between them that define them?
An SUV is based on a rear-drive layout, as most big luxury cars are. Even if the SUV has AWD, most of the engine’s power usually goes to the rear rather than the front wheels, unless the rear wheels lose grip (and then the system routes power to the front wheels). Crossovers are based on the front-drive layout common to lower-priced cars. If the crossover has AWD, it is usually the case that most of the time, most of the engine’s power is routed to the front wheels, unless they begin to lose grip (at which point the system routes some of the power to the rear wheels).
This difference in power flow results in a different driving feel – which is further differentiated by the fact that in a crossover, more of the drivetrain’s weight is over the front wheels, because the transmission and axle are packaged into a single transaxle snugged up close to the side of the sideways-mounted engine) while SUVs have the weight of their drivetrain more evenly spread out from front to rear, because the transmission is bolted behind the engine and there’s a driveshaft that connects it to the rear axle, which is a separate component located at the rear of the vehicle.
SUVs also have beefier/heavier duty frames and bigger available engines; for these reasons they can usually pull more weight than a crossover of the same size.
The F-Pace may look like a sporty crossover, but it is a sporty SUV.
Prices start at $57,000 for the P250R Dynamic S. It comes with an excellent Meridian audio system, panorama sunroof, partially synthetic leather upholstery and a 2.0 liter, turbocharged four cylinder engine paired with an eight speed automatic and full-time AWD.
The $66,500 P400 R-Dynamic S gets a much more powerful 3.0 liter six, augmented with “mild hybrid” tech and an electrically powered supercharger. This version of the F-Pace also comes standard with an adaptive suspension, configurable drive modes and bigger brakes.
The heaviest-hitting F-Pace is the $92,400 SVR 575 Edition – which comes with a mechanically supercharged 5.0 liter V8 engine, plus a torque-vectoring differential, even bigger brakes (with red powder-coated calipers), 21 inch wheels with “summer” tires and an even more excellent 17 speaker Meridian surround sound audio system.
This model most similar to this Jag is arguably a Porsche – the $62,900-to-start Macan. Other possible cross-shops include the Mercedes GLC and the BMW X3, which are both just a little bit smaller than the Jag and less expensive – but don’t offer more engine than small fours and sixes. In the case of the GLC, there’s nothing more than a small four available.
Every ’26 F-Pace (irrespective of trim) gets 90th Anniversary (for Jaguar) badges.
It looks like a crossover, but this SUV runs like a Jaguar.
Available V8 engine.
Superb Meridian sound systems.
Base trim’s four cylinder engine is underwhelming – for almost $60k to start.
Current design is pushing ten years old (first year was 2017).
Jaguar may not be around to support this vehicle ten years from now.
The F Pace is available with three different kinds of engines – as opposed to the usual variations of one or two.
Each defines the trim.
The P250 comes standard with a 2.0 liter turbocharged four that touts 246 horsepower; it is paired with an eight speed automatic and full-time AWD. This engine is similar to the 2.0 liter fours that come standard in rival luxury-sport SUVs such as the Mercedes GLC – which comes only with a 2.0 liter four sold in different power outputs according to the trim level. The standard 2.0 four in the Benz touts 255 horsepower. It’s also got mild-hybrid augmentation, which means the engine gets cycled off during coasting/deceleration and when the vehicle isn’t moving. This allows the Benz to tout 24 city/32 highway. But the Jag’s 22 city, 27 highway is not far behind and it can be argued the Jag has the advantage of not having the hybrid augmentation, because it adds complexity for not much obvious benefit to the vehicle’s owner. There is also the repetitive cycling off and back on of the engine in vehicles that have mild hybrid augmentation.
Next up (in the P400) is an unusual engine. Not just because it’s an inline six. BMW offers this same type of engine in the X3 (and X5). What’s unusual is that the Jag’s 3.0 liter inline six has both a mechanical turbocharger and an electrically driven supercharger. The latter is added to eliminate the slight but inevitable moment before a turbocharged engine responds to a floored accelerator pedal. It takes a moment for exhaust gas pressure to build up (this is what the turbo uses to build boost) before the turbo-boost builds power. The electrically driven supercharger eliminates that moment of hesitation because it does not rely on exhaust to build boost. Total output of the combined effort is 395 horsepower and 406 ft.-lbs. of torque. This engine is also paired with the eight speed automatic and the full-time AWD system.
The Jag’s ultimate engine – in the SVR – is a 5.0 liter turbocharged V8 that touts 567 horsepower and 516 ft.-lbs. of torque. This engine outclasses the highest-output version of the 2.0 liter turbo four that’s available in the AMG version of the Benz GLC (which touts 416 horsepower out of those 2.0 liters) as well as the BMW X3’s top-gun 3.0 liter six, which maxes out at 393 horsepower.
One of the things the Jag also has over its rivals is stout (and standard) towing capacity. Even with the 2.0 liter four, the F-Pace is rated to pull 5,300 lbs. The Benz GLC’s standard tow rating is 3,500 lbs. The BMW X3 is rated to tow 4,000 lbs. with its standard 2.0 liter engine and 4,850 lbs. with the 3.0 liter six.
The Porsche Macan – which also comes standard with a 2.0 liter turbo four – is rated to tow 4,400 lbs. with that engine.
This Jag does a fine job of handling like a Porsche. It can be regarded for just this reason as the bargain alternative to the Macan, which stickers for about $6k more to start – and which you’re likley to pay even more for, because it’s a Porsche and the F-Pace is an aging Jag and dealers are hungry to sell them – because they have nothing else to sell at the moment.
It is also more Porsche-like than its price-competitive rivals from Mercedes and BMW insofar as its underhood offerings, particularly as regards it available V8 engine, which neither they – nor the Macan – are available with.
The BMW X3 and Benz GLC top out at 3.0 and 2.0 liters of six and four, respectively. The Porsche’s largest engine is a 2.9 liter V6.
What’s particularly fun about the Jag is that it’s not known to be a Porsche in Jaguar disguise, which makes it easier to make use of what it can do. When you’re driving a Porsche – SUV or sports car – other drivers know what you’re driving and some of them are merciless about not giving you any room to make use of what you’ve got. And – of course – passing a cop running a radar trap when you are driving a Porsche (any Porsche) is like swimming in a freshly chummed shark tank.
The Jag is the shark.
You owe it to yourself, if you’re considering a Macan, to test drive an F-Pace first. Especially the P400 with the turbo-supercharged inline six. It offers the inherently desirable sound an inline six makes along with the absence of lag a just-turbocharged engine typically has. This version of the F-Pace is also price-competitive with the 2.0-equipped Macan and the Jag’s inline six is stronger as well as better-sounding.
Though the F-Pace has full-time AWD, it is set up to allow for a little bit of rear wheel slip under hard acceleration; if you punch it from a dead stop and turn the wheel hard left or right – as to enter the main road from a side street – you can almost get a chirp on the 1-2 upshift (and would get one were it not for the stickiness of the Jag’s standard 19 inch wheels and steamroller tires).
The Jag also comes standard with 8.4 inches of ground clearance, which is as important (arguably, even more so) than having AWD if the roads have snow on them. The Macan comes standard with 6.7 inches of ground clearance and maxes out at 7.8 inches. It leans more toward being a sport sedan that looks like a crossover.
The F-Pace is sized interestingly in that it is close to being mid-sized vs. the closer-to-being-compact-sized BMW X3 and Benz GLC. While all three have comparable first and second row legroom, the Jag has the most cargo room – 70.4 cubic feet with its second row folded vs. just 56.3 for the Benz GLC and 67.1 for the X3. The Jag also has the most cargo space behind its backseats – 32.1 cubic feet vs. 21.9 for the Mercedes GLC and 31.5 for the BMW X3. The Porsche Macan has the least of the three – just 17.2 cubic feet – which is a function of this one’s lower/sharper roofline.
Porsche doesn’t publish headroom stats but I can tell you from personally sitting in a Macan that there’s less in both rows than there is in the Jag.
Though the F-Pace is not the newest vehicle on the market – the current F-Pace is pretty much the same as the one that made its debut back in 2017 – it is still new-looking. No, that’s not quite right. It is has enduring good looks, which is perhaps the thing it has most in common with the Jaguar cars of the past that will always look good, no matter how old they are.
That includes inside.
The F-Pace’s dash isn’t dominated by a huge LCD touchscreen. There is a touchscreen- but it’s mounted low and off-to-the-side rather than erupting from the dashboard like a Pop Tart.
There’s still a an instrument cluster – or at least, one that looks like one rather than a smartphone screen. There’s a handsomely stubby gear selector lever that feels good in the palm of your; it’s a natural interface. Tapping feedback-free buttons arguably isn’t. The overall look of the Jag’s interior is modern without being a slave to modernity. It’s nice to go back to 2017 – given that 2026 isn’t an improvement in so many ways.
One of the subtle niceties of this Jag is that you can get the massaging seats with any trim – as opposed to just the most expensive trims, which is the case more often than not. You can also get the adaptive suspension, upgraded brakes with red powder coated calipers and the superb 17 speaker Meridian surround-sound audio system as options with the base P250 trim.
It’ll be a shame if the F-Pace turns out to be the last Jaguar. But if so, it will be an honorable end for Jaguar.
Great read on the 2026 Jaguar F‑Pace — it’s clear this SUV still packs a punch with multiple engine options and a powerful lineup even as Jaguar transitions toward electrification.
Wasn’t this Jag model once offered with a diesel?
Hi Rich,
Yes – and it still is – in Europe.
Perhaps the delicious irony of why’s this Jag’s such a nice ride is that it’s almost 10 years old in its basic design.
Old stuff rules, and if there’s good deals on these, especially the straight 6 version, I may have to give it a ride.
Great well balanced review from Eric, as usual.
Ive had this car for 4 years now, but the pre-facelift version, and honestly it’s a pretty good car for what it is. It has issues (a bit more bugs than my X3, and a more expensive maintenance schedule) – but its a very decent twin turbo V6 diesel engine giving the power and drive of a more sporty car, with the economy of a diesel. It also has the best engine note of the lot – with germans complying to the letter with stricter EU nose regs (therefore sounding like a vacuum cleaner) Maybe I’m immature but this matters to me!. Interestingly, here in the UK it seems to be compared to an X5 and a GLE (though a bit smaller than those), but felt just as spacious. Infact I found it the most comfortable and spacious seating (including the back) in that class. Given the price is much less then them – I it was definitely the one to go for back then.
The biggest annoyance is how bad the service is at the JLR dealers – but thankfully I have found very good independent who takes care of everything at a reasonable price.
It’s kinda sad that this is a common expression from all brands of car owners these days, “The biggest annoyance is how bad the service is at [XXX] dealers – but thankfully I have found very good independent who takes care of everything at a reasonable price.”
I understand, you’re busy, got’s to make da Bucks & all that. Howevah,… no one has time to pet the ponies?
What — Jaguar still makes vehicles with IC engines? Who knew?
Actually the 3.0-liter six version sounds like a decent vehicle … though I wouldn’t buy it myself because of the eiggggght-speed automatic transmission.
Jaguar’s disastrous relaunch last year did permanent, Bud Light-style damage. As Lulu Cheng Meservey, co-founder of Rostra PR group, said: “Art school grads simply aren’t associated with elite engineering ability, I’m sorry.”
So is Jaguar. 🙁
RE: “Art school grads simply aren’t associated with elite engineering ability”.
I’m not following? Seems like, one & both, might be a bit interchangeable?
Or, are arches, not engineering?
