Home Classic Cars Flappers and Scoops!
22
2561
Have you ever seen a flapper? Not in black and white photos of 1920s jazz clubs – but opening and closing, on the hood of a performance car?
Probably not – because they went out of style when carburetors did, which is going on 40 years ago. The last new car that had a flapper door may have been the early iterations of the third generation (1982-1992) Chevy Camaro Z28, though there may have been some others.
It has, after all, been nearly 40 years.
But what is a flapper, specifically? It is a little door mounted on the hood – or on a hood scoop, as in Pontiac Trans-Ams of the early-mid 1970s – that opens to admit gulps of outside air that are sucked into the engine by the carburetor. The carburetor is the key element because even though flapper doors were usually activated – opened – by an electrically actuated solenoid when the driver floored the gas pedal – it was the open-to-the-outside world of a carburetor inhaling that made the system sing.
You may have heard the term, Quadrajet Moan. It refers to the sound made when the enormous secondaries of a Rochester Quadrajet carburetor tip open (due to negative air pressure) and the engine inhales mightily, directly – the whole apparatus literally open to the outside world. The neat thing was that other brands of carburetors – such as Holleys and Carters – and other types of carbs, such as multiple two or even twin four barrel set-ups – produced their own distinctive bellow that the ear of the aficionado could tell one from the other. Kind of like car people can tell when an old VW Beetle is out and and about even without seeing it.
A Quadrajet – used chiefly by GM but not exclusively – produces a wide-open-throttle sound that is instantly identifiable to people who know that sound, which no other carburetor makes.
Modern, fuel injected engines do not make such distinct, identifying sounds because fuel injection is essentially the same, regardless of the make/model of the engine it feeds. The injectors pulse, in time with electronically sent signals.
The flapper amplified the wonderfully mournful, angry mechanical song made by a wide-open Qudarajet as well as the different pitch roars produced by double pumper Holleys and dual AFBs (there are some who know about such automotive arcana). Not just at wide-open throttle, either. Some were responsive to engine vacuum and you could tease the door to open just a crack by blipping the throttle. Keep in mind that in the Before Time, the throttle was controlled mechanically rather than electronically – so it was you (rather than a computer) that determined how much the throttle opened and the connection was physical and immediate rather than divorced and disconnected, as it is now.
Some of the really fun flappers were driver actuated. As for example the Air Grabber system you could order with some Dodge and Plymouth models in the Before Time. I had a buddy in high school who owned one of these, so equipped. It was an early ’70s Plymouth GTX. Normally, the hood was flat, like a normal car’s. But you could activate a switch that caused the scoop to rise up. It had shark teeth painted on either side, to add to the affect.
Of course, technically, it wasn’t a flapper but a scoop. Still, the function was essentially the same – which was to grab/such/induct as much outside (cooler/denser) air and feed it to the engine, to make maximum power and – the really important thing – maximum noise.
This made the car feel faster and stronger than it actually was. As for example the 1980 Camaro Z28 I owned once. 1980 was the first year the second generation (1970-1981) Camaro came from the factory with both a hood scoop and a flapper door. It said “Air Induction” on either side of the scoop, which is just what the mechanism did when activated by your right foot. Though the ’80s Z28’s 350 V8 (that’s “5.7 liters” expressed in modern, metric-system homogenous terms) made just 190 horsepower – which is about as much power as a current Honda Civic’s 1.5 liter four makes – it sounded ferocious when you floored it.
Modern performance cars are far more actually ferocious, of course. A 2026 Mustang GT’s 5.0 V8 makes more than twice the horsepower made by my ’80 Z28 and can get to 60 from a dead stop twice as quickly, almost. And yet, the ’80 Z28 had charms the new GT lacks – one of them being those little doors just ahead of your line of sight that flopped open when you floored the pedal.
So, how come the flapper went away? Well, there are (of course) government regs that say a car cannot emit more than so much loudness. These are drive-by noise standards, meaning requirements. They are why Pontiac had to rivet shut the Trans-Am’s scoop after 1972, which was the last year the flapper door opened – unless it was modified to do so by the owner, later on.
But it is more fundamentally probably because modern performance cars are all fuel-injected and computer controlled and the airflow is very strictly managed and calibrated – because it has to be, on account of federal emissions control standards. Flapper doors are kind of sloppy, which is of course part of the fun – a big part of the entertainment value you got with the old stuff that’s just not as much there with the new stuff.
My ’76 Trans-Am is no match – through the quarter-mile – for a new Mustang GT. But when the shaker scoop’s flapper door opens up and the Quadrajet moans, it makes me feel something that getting to 60 in 4 seconds doesn’t – and will never be able to.
22 COMMENTS
  1. OMG, that QuadraJet moan!!! I know this! I’m not old enough to have really appreciated big block cars of yesterday, but for a short while years ago, I did own a 1973 Oldsmobile Cutlass Supreme that had been rear-ended (before I got it). I made a website for a car repair shop, and they pulled out the frame for me and got it all fixed up.
    I did some things to it to get it running really nice, taught myself how to tune the secondaries so it didn’t bog down, etc… and when I would stomp on the gas… the Oldsmobile motor sounded EXACTLY like that… it was so awesome. I have a low-res (good for the time) video of me driving it around…
    https://www.youtube.com/watch?v=Hjx37G59XOE
    Man, I love that sound!
  2. Daughter has a customer named Carter. I really have to resist calling her “Carter AFB” as trying to explain myself would result in a lost customer and me getting sent to the home. FYI, ‘AFB’ = Aluminum Four Barrel
  3. “ Modern, fuel injected engines do not make such distinct, identifying sounds because fuel injection is essentially the same, regardless of the make/model of the engine it feeds.”
    You’ve got to broaden your automotive world my friend. There’s a lot more to the world than V8’s and Quadrajet’s though there is nothing wrong with those.
    Fuel injection via a set of ITB’s has a unique sound of its own. Very similar to carbs and nothing like conventional plenum setups.
    And speaking of carbs on V8’s a full set of 4 Weber IDF’s has a whole different sound than Quads or Holly’s or dual Carter AFB’s.
    Mechanical fuel injection on a 911 engine makes its own unique fuel injection sounds that are equally as wonderful as Quadrajet moan.
    It’s a big, interesting world out there if you take the time to look around.
  4. Few newer cars have them still but most don’t actually work just for looks personally I always think there terrible looking on most cars I don’t like anything sticking out of the hood especially on newer cars there hard to see out of to begin with.
    • Hi Angelo!
      Yes – fake (decorative) scoops are still to be found on some new cars. They are of a piece with the fake (decorative) dual exhaust cutouts just about every new appliance has as well.
      • Or none at all. I noticed that many carmakers are hiding the fact that their cars have exhast pipes possibly because carmakers are embarassed that their cars still burn gasoline. Or they are conditioning the “consumer” to the idea that cars won’t have them as they will be electric in the future.
      • “fake (decorative) scoops”
        Sad to say, the scoops on my 79 Formula are fake, just for looks… but it’s better than the flat hood.
        • Indeed, Philo –
          For the non-Pontiac people: Formula scoops were originally functional (like the TA’s shaker). Even up to 1975, the Formula scoops could be retrofitted to “Ram Air” status!
  5. ‘… when the shaker scoop’s flapper door opens and the Quadrajet moans …’ — eric
    “Q: What’s the difference between an enzyme and a hormone? A: You can’t hear an enzyme.” ― Dorothy Parker
    Bring on the flapper girls! 🙂
  6. The good old days….
    A great example of the sound described in this article was captured by hollyweird in the Burt Reynolds movies white lightning and gator. Music to my ears. We called it the ‘quadrabog’ sound when we were kids. One of my friends still rebuilds Qjets and helps keep that part of the old car hobby alive.
