Home Features Efficiency, Efficiency, Efficiency!
19
2181
Einstein, they say, said that evidence of insanity is repeating the same thing over and over and expecting different results. By that standard, the ongoing “commitment” to the manufacturing of electric vehicles is exactly that.
Insane.
Or is it?
Nissan just brought forth its third-generation Leaf EV, notwithstanding the prior two generations of failure (if making money selling these devices is the measure of success). The launch was accompanied by the slogan: Efficiency, efficiency, efficiency!
But what is “efficient” about this device?
It does go farther in between waits than the previous device, Nissan points out. About 300 miles now vs. about 150 previously. The “about” part being important to bear in mind when it comes to devices, as everyone who hasn’t been living under a rock for the past five years ought to know by now. The actual range of a device is often a lot less than the advertised range. The latter being based upon assumptions such as that the weather is neither very hot nor very cold (which taxes the battery, via the thermal management system that uses electricity to keep the battery from getting not-too-hot ad not-too-cold as well as via the use of accessories such as the heat and AC to keep the passengers from not getting too hot or too cold) and that the road is mostly flat and you don’t drive faster than about 60 MPH – because if you do, the distance you can actually drive will be less-than-advertised.
Sometimes a lot less.
That circles us back to this “efficiency” business. How is it “efficient” to needlessly waste the one thing that is particularly precious because it cannot be replaced?
Time, that is.
The next-generation Leaf, like most new devices, goes farther in between waits but those waits remain the same. It does not take any less time to charge up. You must still wait at least 20-30 minutes at what continue to be referred to with extreme disingenuousness as “fast” charger kiosks to instill a partial charge in any EV. Even if you only have to do this once a week, that is still several hours per month you will never get back. Several hours that could have been spent doing some other thing instead. Several hours you would not have had to spend if you hadn’t bought an EV.
It is not astounding that so many people willingly buy vehicles (EVs) that costs them time – and money – they do not have to spend?
Automotive News – which stopped publishing news a long time ago, in favor of Pravda-predictable editorializing – had this to say about the latest Leaf:
“Engineers used a host of tricks to boost the maximum driving range about 40 percent to 303 miles, giving fresh legs to the car that pioneered the affordable EV segment 15 years ago.”
Italics added.
The “affordable EV segment”? The current (2025) Leaf’s base price is just shy of $30,000 ($28,140) and that’s with the standard low-range battery. Equipped with its longer-range (sic) battery, the cost of this device soars to $36,190 – which places it squarely in what used to be considered the entry luxury segment. No matter what you call it, “affordable” it isn’t. The next-generation Leaf is certain to be even less so given it is new and that always costs more and because it comes standard with the longer-range battery pack.
The general rumor is “low 30s.”
It’s the New Affordable – as far as vehicles – like ten ounces is the new pound at the grocery store.
Meanwhile, you can still buy – for a little while longer – the very similar Nissan Versa for $17,190 and for that price you don’t have to spend much time. It can be fully refueled in about three minutes and it comes standard with more than 300 miles of advertised driving range that is congruent with how far you can actually drive, irrespective of how hot or cold outside it is and even if you drive faster than 60 MPH. The range touted by Nissan and every other vehicle manufacturer had better be congruent with actual driving range because if it turns out not to be, they will be hounded by the Feds and sued by customers who correctly feel gypped.
This never happens with regard to devices, for reasons that have to do with politics and denial. The dynamic is similar to that displayed by the battered wife who makes excuses for her man when the cops show up.
But why is Nissan putting all this money into another time-wasting and almost certainly money-wasting device? The possible answer is unsettling in that it isn’t because Nissan’s management is insane. It may well be that they know we’re merely enjoying a temporary interregnum. Trump has not, after all, repealed the federal regs that impose a de facto EV manufacturing mandate – since the only way to comply with the regs is to manufacture more devices. And he has most certainly not dismantled the regulatory apparat that emits these regs.
Ergo, the regs are still in effect. Ergo, the apparat is still empowered. It is merely sort-of quiescent, for the moment. But what about a little more than three years hence? What will happen then? Or – more finely – after Trump is replaced, in the usual Hegelian course of things, by an outright Red running as a green?
Nissan – like all the others – can read the leafs, you see. And that’s why this device is being manufactured.
More to come, too.
Meanwhile, the actually efficient – and affordable – Versa is being discontinued. More finely, it will no longer be available in the United States. For essentially the same reason you can’t get a $23,000 50-plus MPG TDI diesel-powered VW Jetta that can be driven 600 miles on a full tank.
Because efficient and affordable vehicles are not what’s wanted in the United States – by those who control the United States.
19 COMMENTS
  1. The wife and I just bought a pair of EVs.
    Bicycles that is, to tool around the beach this summer and the campgrounds.
    That’s the only EV that is practical for us to own or that we would even want to.
  2. Nixon said it best. That was the most faggy goddamned thing you could ever imagine.
    But they did get the efficiency thing right. They can charge these EVs for free by harnessing the spinning of Mr K’s grave.
  3. “…by those who control the [so-called] ‘United States’.” Now you’re onto something.
    It takes time to Wake Up after realizing you’ve been lied to about basically Everything.
    There used to be quite a few HoloHoax references being used around here.
    Yes, we noticed. The ‘United States’ isn’t what you think it is – depending upon which of the Three legal definitions are being used.
    It’s ALL about Time, you got that right.
    “If you love your life, don’t waste time, for time is what life is made up of.” -Bruce Lee
    I’d never even think about buying any of the pieces of shit they are making now.
    https://citizenwatchreport.com/new-cars-are-literally-falling-apart-in-2025/
  4. When it comes to their time, private jets and motorcades speeding through downtown. Because their time is precious and valuable. When it comes
    To our time, once you’re off the clock it’s worthless.
    Unless you’re a teacher or college professor, then any chance to waste time is priceless (especially if it offers a chance for moral superiority over you Philistines).
  5. The only advantage I could see for a small EV is that you can probably charge it at home easier. Other than that it has no real advantages and many disadvantages.
    Depreciation will of course be a major problem as the batteries suck even worse as they age.
    • How many people are using 10 year old laptops. Or even 20 year old ones?
      Or any consumer electronics that age with rechargeable batteries?
      (*not even taking into consideration the necessary software updates that will no longer be offered.)
      And most of those items are kept indoors under relatively stable temps.
      Now throw in devices parked outdoors (or maybe a garage) with huge temperature, weather and atmospheric swings.
      Not to mention how all these new device batteries with thermal management systems which require them to ALWAYS be powered in order to properly work.
      All of this makes zero sense when held up to the most basic scrutiny.
      • Hi Flip. My laptop is over 10 years old and while it’s battery has seen better days, I’ve got a better battery just as old that I use if I don’t have a spot to plug it in.
      • 2013 Dell E6540 here. Battery condition reports at 53% but it’s still functional, just runs down in a hour or so. At least it doesn’t die immediately unplugged so it’s not bad technically, just lost most of its capacity. It’s running Debian 12, so it’s current in 2025 as far as that goes. Dual boots Win7 for some legacy stuff.
      • It absolutely makes no sense. Wife and I decided some time ago we will never participate in the EV grift. Have a neighbor 5 or 6 houses down, both his cars are EVs. All the garages on our street face due west. This time of year 1OO* outside means it gets over 125* in the garage. A few weeks back a giant flat bed tow truck was backed up into his. EV wont start, or hold a charge, have to haul it off to get it going again. Where as my old MB 5OO SL wouldn’t start recently from not driving it for a month. Tried jump starting, no go. Simple trip down to auto zone and swap out the battery, good as new.
        My Mac Book is from O8, its on its third battery. Works for about an hour and a half on a full charge. A few of the keys don’t work from the cat spilling coffee on it, other than that, and operating system so old some GH websites don’t load, its A-1 double plus good.
      • I’ll add to the chorus of proud, vintage laptop owners.
        Mine is about 13 years old. I’ve had to replace the battery, but it seems like it’s time for a new one yet again. Lasts for maybe an hour if nothing is happening. If you’re watching a video or something demanding, it lasts for maybe 25 minutes.
        You can revive nearly anything with the proper Linux distro. Well, maybe not a bricked EV…
  6. That video is peak fake and gay. Hell, even Emelia Hartford is mystery meat. They should just rename Nissan to Miscegenation Motors. They even have a Japanese woman miscegenating with a white man in the advertisement. The Jews are forcing diversity down Japan’s throat, whether they want it or not.
    One interesting feature with the Leaf (at about 9min) is that apparently you can use its battery to time shift your electricity consumption, although it is not stated how much this option would cost.
    Many electric utilities across the west now use variable pricing models where one can see the electricity price online for the next few days. This would allow owners to use the car battery for heating/cooling/etc when the electricity prices are at their highest, while loading the car battery off peak. This could be a significant savings, potentially hundreds of dollars in a month. It would also work well with a stand alone solar system as a reserve power system for when there is a stretch of cloudy weather.
