Home Features 2025 VW ID Buzz
2025 VW ID Buzz
33
12329
The VW ID Buzz is interesting in that it looks like the old VW Microbus of the ’60s and ’70s but is nothing like it.
This has its good – and bad – points.
The ID Buzz is a kind of visual reincarnation of the Microbus of the ’60s and ’70s that’s entirely different in just about every other way. It has working heat and AC, for openers. And it does not take 60 seconds to get to 60. It has a battery pack and powerful electric motor(s) rather than a struggling an air-cooled four in the back. It also weighs nearly three times as much as an old Microbus – and costs about three times as much, too.
The base Pro S trim, which is rear-drive and has a 282 horsepower all-electric drivetrain powering the rear wheels (the one functional commonality it shares with the original, Beetle-based Microbus) comes standard with three rows of seats, standard dual-sliding doors, a nine-speaker audio system, heated steering wheel and a 12.9 inch touchscreen stickers for $59,995.
The Pro S trim ($63,495) adds a better 13 speaker sound system, hands-free operation for the side doors and liftgate, a surround-view camera and the option to upgrade to a more powerful (335 horsepower) dual-motor system that VW markets as 4Motion, which is bundled with other upgrades that include a heated windshield and second-row captain’s chairs.
A top-the-line Ist Edition lists for $65,495 with the rear-drive EV drivetrain (and 282 hp) or $69,995 with the dual motor set-up and 4Motion AWD. The 1st Edition gets a unique-to-this trim two-tone paint job, roof rack and panorama glass sunroof.
VW says the Buzz has a best-case range of about 234 miles on a fully charged battery.
What’s New For 2025
The ID Buzz is VW’s latest model – based (at least insofar as how it looks) on the classic VW Microbus.
As distinctive-looking as the original Microbus, which is a huge departure from everything else (that looks pretty much like everything else).
Does’t take 60 second to get to 60.
Has cold AC and heat that works.
Modest range is a problem compounded by the time it takes to recharge.
VW charges  almost $700 extra for a home-charge cord.
Front quarter windows don’t open, so you pretty much have to use the AC to stay cool – which saps range. Ditto the heat.
The ID Buzz doesn’t have a hood – another point-in-common with the classic Microbus. The latter had its engine mounted in the rear, over the rear wheels. The ID Buzz has an electric motor mounted back there, directly driving the rear wheels (the Microbus came standard with a four speed manual transaxle).
This motor makes about four times as much power (282 horsepower) as the air-cooled four cylinder engine that powered the Microbus made – and it’s a necessary thing, given the ID Buzz weighs just shy of three tons (5,968 lbs.) which is just shy of three times as much as the classic Microbus weighed (about 2,500 lbs.). So even though the Buzz is extremely heavy – chiefly due to the weight of the massive energy storage device; i.e., the battery pack – it can still get to 60 in just over 7 seconds. An original Microbus gets to 60 . . . eventually.
With its optional dual-motor set-up, the 0-60 time falls to about 6 seconds. That’s very quick, especially for something that was designed to recall the Microbus, which was infamous for being slow.
On the other hand, driving range with either the single or dual motor set-up is about 234 miles, which isn’t as far as the old Microbus could go on a full tank of gas. The more relevant thing, though, is arguably how long it takes the Buzz (like all EVs) to recharge. Some say the 15-20 minute wait for a partial charge at a public fast charger isn’t very long to wait.
But it can ruin your plans if you hadn’t planned for it. Or if the charger isn’t working. Or won’t let you charge. This latter happened to me after I’d discovered the first place I wanted to charge the Buzz was “undergoing maintenance.” The second place would not accept my credit cards. Plural. I tried several. No charge..
You can, of course, charge at home – where the wait isn’t so bad because you are home and so can do other things (like sleep) while you wait for the Buzz to charge up. But in order to be able to do that, you’l have to spring for the extra charge charging cord. This is a $646 option, if you can believe it. But you pretty much have to spring for it because without it, you have to stop (and wait) at public fast charger stations and plan around that. Also, you are entirely dependent upon the sometimes iffy public fast charger network.
Why VW chose to charge extra for an essential piece of equipment is a hard thing to understand. Well, it’s not hard in the sense that VW wants to increase its profits on each Buzz sale. But it’s pretty cheeky to do it this way. A charge cord for an EV being as essential an item as a fuel-filler in a gas engined car. Also, this is a very expensive car to begin with. VW is likely to discover that people who spend just shy of $60k on an EV like the ID Buzz expect not to have to pay extra for a charge cord.
On the plus side, the Buzz is quick. It easily keeps pace with traffic, something the classic Microbus struggled to do. It is also quiet and rides like a Cadillac, two other attributes the classic Microbus lacked. Also, the AC blows ice-cold and the heat is both hot and doesn’t include fumes.
The Buzz does not feel fragile and out of its depth on any road where traffic is moving at faster than 45 MPH.
When you first sit down in the driver’s seat, you feel almost as if you’re behind the wheel of a tour bus because the windshield is so huge – both tall and wide. There are also fixed quarter windows on either side, which is a shame – in that they don’t open – because if they did, you could use them to cool off the interior without running the AC (and thereby conserve some range).
On the upside, VW can provide you with a battery powered, hand-held fan that you can use to avoid using the AC.
An interesting thing is you do not sit on top of the front axle, as in the old Microbus – though from the outside, it looks as though that’s where you’d sit. VW did a very clever designing job on that score. The cab forward design of old Microbus would never pass muster with today’s Safety Cultists.
The chief downside is that the Buzz hasn’t got much driving range. The touted 234 miles isn’t much to begin with – equivalent to about half a tank of gas, in terms of the range of just about any current car or (for a closer comparison) minivans, which if you take away the retro look is what the Buzz is.
A current-year Chrysler Pacifica minivan – which is about the same overall size and has dual sliding doors, etc. – has a highway driving range of more than 530 miles and even in stop-and-go city driving, touts a range of 361 miles. Granted, it is not as distinctive-looking as the VW, but the point stands.
And 234 miles is best-case.
It assumes light-load conditions so not uphill and not driving fast and definitely not using the AC full tilt on a hot day (or the heat on a cold day). All of those things can greatly reduce the actual driving range you will get. If there’s say a 20 percent difference between the best-case and the worst case, you’d only have about 188 miles of range and you’ll probably want to always leave at least 20 miles in reserve because it is common to find that the public fast charger you were planning to use isn’t working and then you’ll have to drive to the next one.
The iffy nature of EV charging infrastructure is arguably more the problem than the relatively short range of most EVs. If people could safely assume that there fast charger kiosks pretty much everywhere and that they’d be working then range anxiety wouldn’t be as much a thing. A V8 Dodge Charger Hellcat doesn’t have much range, either. But it doesn’t matter because it’s so easy to get more gas.
The VW’s range is actually fairly impressive given its weight. This thing is only slightly lighter than a Ram 2500 dualie pickup. The old Microbus, in contrast, was light enough that a couple of Hippies could push it down the road.
The Buzz’s looks have created a Buzz. Like the New Beetle did, when VW brought it back back in the ’90s. Many people – as in millions of them – have fond memories of owning and driving classic VWs such as the original Beetle and the Microbus. That nostalgia exerts a powerful pull.
But can it sustain sales?
The ID Buzz may look like a classic Microbus, but have a look at the MSRP. This is a bus for affluent elderly hippies, chiefly – because there are not many people in the Woodstock age range. When VW was still making the original Beetle (last offered in the late 1970s) and the original Microbus, both were very affordable relative to other cars. That is why they were people’s cars. Models like the Buzz are affluent people’s cars and that’s fine, if you can afford it.
Most can’t.
There’s also an underlying issue there in that VW is not considered a luxury brand, irrespective of how luxurious the vehicles it sells may be. The Buzz is certainly that. It is even available with massaging seats. It’s as “luxurious” as any price-equivalent Audi or Mercedes. But (like the Phaeton of the ’90s) it is not an Audi or a Mercedes and that’s a problem for VW, probably.
In this case, it is a problem that chiefly arises from the fact that the Buzz is an EV and there is no way known to make an in expensive EV that isn’t also a slow and small one (like the Chinese make).
The dual sliding doors have mini-windows that can be opened, but there are no window switches for the driver to open them with.  VW offers an optional storage bin system for the rear cargo area that’s helpful for organizing (and hiding from view) small items. The main instrument display is small and not-distracting; the large secondary touchscreen can be aggravating to use and you pretty much have to use it to operate the sound system and the climate controls.
In addition to the extra-cost home charging cord, be aware that you will probably need to have an electrician come out to your house to wire up a dedicated 240V outlet (and circuit) somewhere in your garage, if you want to be able to home-charge in faster than overnight. This is a cost worth the expense, though – and not only because it enables you to charge at home in a reasonable amount of time. It is generally much less expensive to recharge an EV at home than it is at commercial fast charger kiosks, where it can be nearly as expensive to charge up as it costs to gas up.
Nostalgia is always fun. But how many can afford it?
33 COMMENTS
  1. I bought a lime green and white micro bus in 1988 in high school for $1,500 it had a 4 spd manual and a pancake porsche motor, i could smoke the tires in 1st and 2 nd gear. If they even made this as a hybrid, i would be looking at one, wcrew this noise, me and my hippy bros drive full size trucks, old aports cars now anything with V-8s, or inline 6s…. Le sigh.
  2. You can, of course, charge at home – where the wait isn’t so bad because you are home and so can do other things
    The wait is extremely bad, simply because the wait is so ridiculously long. EV manufacturers should definitely not be given a free pass for failing to address this outrageous design flaw merely because people can be conditioned into putting up with it because in someone’s opinion they can.
    The “you charge your EV while you sleep” bromide really needs to be put to bed, as it were.
  3. So it doesn’t come with a house charger cable. Does it come with a spare tire? Even a donut would be something better than fix-a-flat.
  4. “And it does not take 60 seconds to get to 60”
    To be fair the old Microbus operated under low load conditions and low vehicle weight conditions.
    The new Microbus needs for power for obvious reasons. Two reasons being the weight of the car and the weight of itz passengers. Four passengers days might easily tip the scales at 1,000 lbs.
  5. My first experience of a type 2 bus was as a wee sprat of about 6 in about 1970, when dad got one for some reason. Maybe a trade, maybe payment for some mechanical work, maybe just a wild hair.
    We were living in Alaska, and he parked it on the street, and even back then some commie fuck bitched about it, so he parked it over a street, where it was promptly stolen. Hopped in one of his buddies bush planes (my first plane ride!) and scanned the ground until we found it.
    When recovered, the body had been torched off at about 2 inches above the “frame”, leaving a truly odd looking vehicle with a couple low back buckets and a long spindly unsupported steering column in front, a big flat platform, and a 40HP upright VW engine in the back. I can’t remember what we did for a gas tank, but dad stuck a pair of huge paddle tires on the back and ,” et voila!” Possibly the original sand rail. An absolute blast on Alaskan beaches and back roads. All the creatures comforts a real outdoorsman needs, a stiff breeze and a place to carry a dead moose.
    Try that with an ID buzz. I double dog dare ya… I’m envisioning a massive toxic beach fire with paddle tires unable to keep a 2500 lb battery from sinking slowly into the cold wet sand.
  6. Oh, and at the very least, the dumbasses should have made it FWD so it would have better rear cargo space and front drive traction. Being a RWD has to be the most idiotic move of the century, as if the century isn’t full of that already!
    • This reminds me of the VW phaeton, when it came out it was around $75K or so, depending on options and engines. But it had a V10 diesel and W12 gas option available. How far we have fallen to have this dreck presented to us as the latest and greatest. I’ve ridden in one of these in Germany,and while fun, there’s simply no way I’d actually buy one, especially at these prices. Not only is it not affordable, it doesn’t perform up to what’s required!! If this was a diesel hybrid electric, maybe worth considering though.
      • Amen, Saxons!
        The Buzz is sitting outside right now and will sit there until it gets picked up on Weds. I can’t drive it because I can’t charge it (at home) and there’s not enough charge left to risk driving it into town and hoping I could charge it there. So it sits, a 6,000 pound paperweight. Meanwhile, my 24-year-old truck is ready to go and can go for hundreds of miles anytime I need it to.
        • You should insist that the device be fully charged. Maybe there was a problem with communication. When I rented cars I had to top off the gas tank to the level when I picked it up.
          • The manufacturers can’t get some of the EVs out to Floyd with any more than 1/2 charge, sometimes less. They have trouble, or don’t bother, to fully charge it in Roanoke. Of course, it just proves that when time is money, they are not going to waste their time fully charging their own product for a decent review. If they can’t bother, why would anyone in their right mind pay $60K to be aggravated themselves?
            The virtue signalling doesn’t pay for the hours lost hunting for a charger and/or being stranded without power.
  7. I keep wondering about the name. ID BUZZ. Really. TH Id, in psychology, is the subconscious drive of desires, sexual, pleasure seeking, instinctual.
    I don’t think this is a coincidence.
    The original ( I grew up with one in the 70s) was practical, economical, sexy in a hippy-sort of way. but more down-to-earth.
    It never was this $60K pretentious piece of virtue-signalling garbage they offer up today!
    I find it equally pretentious that this EV poser has fake rear ‘air vents’ for the non-existent air-cooled motor, just to imitate the original. What a hideous piece of disingenuous Euro-Trash!
    • “fake rear ‘air vents’”
      Just like the fake exhaust sounds emitted from the Dodge Charger. Still haven’t seen a single new Charger in the wild yet around these parts.
      • Hi Philo!
        In re the EV Charger. I haven’t seen one yet, either – and they haven’t sent me one yet, either. Prolly ’cause it might not make it here (or back).
  8. The dealer will always have parts. I.E. the one that never sold. Should call it a timebomb.
    The one thing I find interesting is it has a heat pump, or so I’ve heard. Auto A/C technicians know nothing of this. I should know, heat pumps were not on the test. So if the A/C goes out, it’s probablly straight to the dealer with it.
    I’ve seen more of these propped up by the front door of VW dealerships than I have driving around (1). So the parts will be expensive, because nobody bought one. Straight away I knew the driver had more money than brains and I backed off and laughed from a distance. Ah white people.
    Maybe VW knew nobody would buy one, because we told them so. So they use this to cheat on eMPG the most to correct the fleet average.
    • My neighbor has a Buzz as the wife’s garage queen/daily driver.
      She used to have a 2002 Camaro convertible garage queen and a recent Cadillac crossover daily driver, but I assume the Camaro got sold as part of the deal with the husband to buy the Buzz.
      The van already disappeared for a week to the repair shop.
  9. Nostalgia is always fun. But how many can afford it?
    Ah – remember the early to mid 2000’s and the nostalgia inspired vehicles? Thunderbird, PT cruiser, Chevy SSR, Prowler?
    At least the PT and the Chevy me2cruiser were affordable. And thus, they sold millions of them.
    The Buzzkill will never sell in those numbers.
  10. The old VW buses will still be going strong when these new fangled high tech overly complicated shit are crushed for scrap.
    • Amen, Jack –
      The old Beetle I drove back in the ’90s was 20-plus years old when I bought it and it ran reliably for several years in DC traffic. When I sold it, it was still running great and probably is still running. That’s an example of a people’s car. This thing ain’t.
      • Like Anon says above, drop a flat 6 engine in, (I would prefer a 4 cylinder 2.4 liter), EFI, water cooled, 6 speed, and reduce the weight and price by half, and it would sell like hotcakes. EVs are a joke, they build them because (they believe) they are the future. Surrrrreeeeeeeee they are. What are you going to do in 10-15 years when the battery pack has to be replaced? In the real world, replacing a Prius battery pack makes it unwanted, and even if you buy a refurbished one, with a one year warranty, and do it yourself, how long will that last?
        It would be really cool to make a VW flat pusher motor, so it slides out on rails, so it can be serviced EASILY. Imagine that, a motor fully exposed, no need to disconnect the wiring harness.
        I have a hunting friend in central Idaho who still drives a 1968 VW van, the 23 window model, air cooled, and we used to freeze our ass off as it had no heat (the floor/heating duct was crushed from hauling firewood). So we would bring one of those propane heaters to warm our hands and feet. So water cooled is a must. It is a great vehicle, we would get a big bull elk, cut it up and pile the carcass into the back with the head and horns on top. Lots of space. A sight to see how poor rednecks get their forest beef.
  11. VW charges for the charging cable bcause the owner will want one for the McMansion near work and another for the vacation house.
  12. “This is a bus for affluent elderly hippies”
    Yep. The countercultural Left and the entire hippie movement for the past 50-60 years is based in affluence. Working stiffs making $25 an hour aren’t going to be paying $65k for that fucking thing. Dual-income lesbians “working” for for some government agency or university with a $200k household income will.
    The “Left” is not actually Marxist or proletarian, it is bourgeois.
  13. ‘This is a bus for affluent elderly hippies … nostalgia is always fun.’ — eric
    Weird: the ID Buzz looks strangely familiar … yet is not at all the same. It’s anachronistic — almost as if a heretofore unknown manuscript by Nietzsche just turned up in a musty Leipzig garret: Lives of the Sitzpinklers. Who knew, way back then?
    But like poor Linda Ronstadt, who made a fabulously sexy album cover half a century ago [link below], the old Microbus has porked out monstrously … as have many Boomers who might buy it.
    https://tinyurl.com/2uz3dkp8
    ‘The old Microbus, in contrast, was light enough that a couple of hippies could push it down the road.’ But it’s gone, and so are the hippies. 🙁
    And it’s up against the wall, redneck mother
    Mother who has raised her son so well
    He’s 34 and drinking in a honky-tonk
    Just kickin’ hippies’ asses and raisin’ hell
    — Ray Wylie Hubbard, Up Against the Wall, Red Neck
    • But he and all his kind get more endangered every day,
      And pretty soon the species will up and fade away.
      Like the smoke from that torpedo-
      Just up and fade away…
      Bellamy Brothers “Old Hippie”
  14. Perhaps the Buzz is the most emblematic of how the world has changed, and not for the better.
    It was inexpensive but, filled the needs of those who just needed something more spacious and easy to keep on the road. It was slow but, who’s in that much of a hurry anyway…we’ll get there. It had no luxury features but, it wasn’t intended to be “luxurious”, it was functional. (Does anyone remember “form follows function” these days?) Repairs could be done with simple tools and a minimal level of wrenching skills. Now you need a $100k computer to find out why the thing has bricked.
    We’ve gone from humble, functional and dependable to glitz and glamour with high maintenance. Everyone wants to date a super-model these days. They don’t care if she makes great potato salad. But, which one will be dependable for life?
    And they ask me why I drink…and why so many people are taking happy pills.
