I just finished the hardest – so far – part of the transformation of my ’76 Trans-Am from automatic to manual and you might be surprised to hear it wasn’t removing the old transmission or installing the new manual flywheel, clutch/pressure plate and bellhousing (all of which were easy). Nor the installation of the manual clutch actuation linkage; i.e., the Z bar and the rods that connect to it.
That all went easy peasy; a simple matter of removing old things and installing new things. Just bolt removal – and bolt tightening.
But getting the original brake pedal assembly off – now that was challenging. Not because the job itself was hard. It was hard because the job was almost impossible (for me) to get at. It was just a nut and a bolt. But getting at both – at the same time – was something like successfully juggling five milk bottles in a 35 MPH headwind while standing on one foot.
Okay, maybe that’s a little exaggerated – but not much.
If you have ever worked underneath a car’s dashboard you will feel my pain. The parts tucked up under there were among the first parts installed when the car was being built. Everything else is built in top of those things, which makes them hard to see – let alone remove. Some were designed never to be removed, like the bolt and nut that serve as the swing perch for the Trans-Am’s brake pedal. The designers assumed – correctly – that the brake pedal (and its lever) would never need to be removed because it is not something that wears out and is almost impossible to break. If one has ever broken, I’d love to hear about it.
But it needs to be removed, if you’re doing a transformation from automatic to manual – because you need to install a clutch pedal and a new (smaller) brake pedal. These two new pedals swing on a new – longer – bolt that must be installed in place of the original (shorter) bolt and that entails removing the old bolt, so as to get the old, automatic car’s brake pedal out.
Sounds easy, right? It isn’t – because it’s very tight under the dash and (naturally) the bracket that the bolt goes through is shaped in such a way as to make it impossible to see either the nut on the one end or the bolt head on the other head. You have to figure out how to get a wrench or socket on both, because if you don’t all that will occur when you turn the nut or the bolt on one side is that the whole thing will turn. You must prevent the bolt (or the nut) from turning on one side in order to be able to loosen/remove the nut and thus the bolt. This has to be done by feel – and it’s hard to do that because it’s difficult to reach one of the two – let alone both at the same time.
It is also impossible to have a helper help, because two people cannot fit under the dashboard at the same time.
It took me three days of intermittent sessions to get the nut off that bolt. I removed the driver’s seat so that at least I could lay mostly flat on my back and look up (and sigh) at my despair. I experimented with various combinations of wrenches and sockets. I settled on a slightly modified socket mounted on a non-ratcheting extender bar, held at the correct angle with duct tape, to secure the bolt head and a long, angled-handle ratchet on the other end. The circus trick was getting them both on their respective nut and bolt and then holding one tight to prevent the whole mess from turning while trying to turn out the other (the nut).
An agile teenager probably would have had an easier time of it. But I am neither a teenager nor agile. Both of my shoulders are stiff and it took some time (and purpose-driven masochism) to figure out how to twist and angle myself in such a way that I could use both hands at the same time in that tight space. I’d try for awhile, then quit. Drink some coffee, sullenly – and think. Then try again.
And then once more.
At last, my efforts were rewarded. I felt the nut coming loose. That is an ecstatic feeling because it means you are going to get it. I didn’t stop. I overcame the pain. At length – to put it as Poe might have – the nut came off. I extracted the bolt and the pedal came out!
Installing the new (smaller) brake pedal and the new clutch pedal will be much easier because the bolt is longer. It clears the bracket on on side such that you can see the end and get a tool on that end much more easily.
They did go on easily. Also easy was drilling the hole in the firewall for the clutch actuation rod that secures to the new clutch pedal because GM thoughtfully built in a template for where the hole goes – in the form of a trim plate that’s the same for both factory automatic and factory manual cars, with the same slot for where the hole goes. Drill here.
There are still some things yet to do – the main one being cutting the hole in the center console for the Hurst shifter. But I’m well past the halfway point.
I still have to buy the shift linkage and the Hurst shifter to be operational.
Hoping I can afford to do that soon!
Hardship brings understanding. May your suffering bring enlightenment as it does me. I work on old BMWs, so I am a good friend with pain. It draws the the bad juju out of the soul. Cleansing!
RE: “pain. It draws the the bad juju out of the soul”
I’ll have to mull that one over.
This one, it seems true: “Hardship brings understanding.”
Most, today, myself included, live a life a soft life.
The Plandemic, it could be said, was a hard patch, much like breaking a frozen bolt free, only to get a few bloody knuckles for the effort?
What’s that got to do with rust Never sleeping, Idk?
“•In trials, it is almost impossible to report adverse reactions occurring that are not “expected reactions” being monitored for (typically minor side effects like fever or fatigue)—something we also saw through the COVID vaccine trials and within the CDC’s system that was created to monitor the vaccines for safety (and thus what we were lead to believe were the only complications of the vaccine).”
https://www.midwesterndoctor.com/p/dissecting-the-religion-of-vaccines?utm_source=post-email-title&publication_id=748806&post_id=179877342&utm_campaign=email-post-title&isFreemail=false&r=9atnc&triedRedirect=true&utm_medium=email
…Is it, drawing the bad juju out of the soul? Idk.
“Ford blames Trump’s tariffs as it crashes to worst-ever loss… but failed EV bet is really to blame”
Lost $11 billion in third quarter:
https://https://www.foxnews.com/politics/gop-lawmaker-shocked-after-anti-ice-sheriff-stumped-fifth-grade-civics-questionwww.dailymail.co.uk/yourmoney/article-15550543/ford-tariff-loss-electric-vehicle-push.html
Money quote:
“Ford said it expects profits and cash flow to improve this year – though it warned its electric vehicle division will continue losing money until at least 2029.”
[…] https://www.ericpetersautos.com/2026/02/11/trans-am-transformation-update-part-vi/ […]
I know that feeling of finally getting something in or out that you can’t see and have been working at for a long time.
Usually hits after a few feelings of just giving up.
Good job!
Thanks, Dan!
She’s nearing operational status. All that’s left to do is cut the hole for the shifter linkage, install the trans and driveshaft and button everything up! Funds permitting, I hope to have this done by March
Next time take it to Rhonda…
https://share.google/n86b5hfWSIqEkSv1m
Taking a front seat out is almost a must for this kind of thing. Ive never done work on the brake pedal, but I had to go under there to clean out all connectors/grounds and hopefully resolve electrical issues before they happen. Its so annoying under there, then you need goggles for the 40 years of dust that starts to rain on your face.
Not sure if this is all old cars or a military truck specific issue, but my army k5 blazer has live wires down there even when off, so its good policy to disconnect the battery or else you get a surprise spark show over your face with the wrench you shoved up into the nest of wires
Getting those pedals out is a true bane. There is a wild sense of accomplishment and relief once you’ve succeeded. From here on the challenges should be much smaller.
The only big block 4 speed muscle car I’ve owned was my 70 Buick GS stage 1 convertible. When that thing came onto the cam and the Ram air started working it was magical- wish I’d kept that one!
Nothing worse than working under a dash. Didn’t mind when I was young and had my eyes. 👍Eric.
Thanks, Ant!
I’m having fun… mostly!
“… and had my eyes.” So true, but those Harbor Freight rechargeable mag mount LED work lights are game changers. They fit in tight spaces, anywhere and any orientation, and make it BRIGHT.
Tetelestai!!
Hi Hans!
Later today, time permitting, I’m gonna remove the factory automatic center console and the mounting point/related hardware for the stock automatic gear selector; then mark off the hole to be cut in the tunnel for the Super T10 shift linkage. It may be awhile before I can proceed to installing the transmission itself because I still have to buy the shift linkage and Hurst shifter itself for the T-10 and it’s a few hunnert bucks I’ll need to hoard up first before I can pull the trigger. But it’s getting there!
I might try to sell the original center console and bits and pieces, all of which are in excellent/near-new condition.
You aren’t kidding Eric the price of the shifter alone without the linkages is a lot more than I thought it would be.
HUZZAH!!
Working upside down and backwards under the dash is one of life’s little pleasures. Did you have the bonus treat of having the seat mount points on the floor jabbing you in the back?
El Guapo is right about “special tools”. One of the most important things you learn early on is how to make do without those factory aids. The more creatively you can think the better. Because you don’t want to be muttering, as the Bard of Mayberry once did, “Dag gone, Opie. We almost had that thang fixed.”
That’s where a 1″ thick roll.of foam rubber is worth 100x it’s weight in GOLD!
RE: “a 1″ thick roll.of foam rubber is worth 100x it’s weight in GOLD!”
I Wish they had those Back in the Day!
I saw some roofers using them. It seemed like a super-serious tool.
I feel your pain and your joy! My ‘63 Mercury Comet, which was NOT intended from the factory to be a V8 or C4 automatic definitely required some modified tools to button up.
When my step-grandfather passed away, he left me his collection of tools consisting of virtually everything Snap-On, Mac and KD made from the late 40’s to early 80’s, and there are so many specialty tools designed to overcome these challenges that it isn’t even funny. Looking through these boxes just illustrates how much we have devolved as we went from “mechanic” to “tech”.
I wonder how many people are thinking, should they feel insulted, “how much we have devolved as we went from “mechanic” to “tech”.”
I dunno, for the most part, the two words mean the same thing. Idk.
Tomato, Tamato. ?
…Seems like, the big difference is: respect & pay, vs. same duties.
Again. Idk.
Goodnight, Gracie.
