Home Features 2026 Mazda3
2026 Mazda3
11
5159
In case you didn’t know, Mazda only sells two cars now – and one of them (the Miata) isn’t exactly what you’d call a family car.
Everything else Mazda currently sells is a crossover.
Except for one other.
It’s the 3 – still available as a sedan or a five-door hatchback. Both are an alternative to a crossover, which for some of us is worth a look on that account alone.
As mentioned, the 3 is Mazda’s last remaining car – other than the Miata, which is a sports car. The 3 is available as a compact-sized sedan or five-door hatchback that’s also one of the most affordable new cars available. And it’s also one of the very few new cars that you can still get with a manual transmission.
Prices for the sedan start at $24,500 for the base 2.5 S trim, which – as the designation suggests – comes standard with a 2.5 liter four (no turbo), a six speed automatic and front-wheel-drive. Sixteen inch wheels and cloth covered seats are standard, along with an eight speaker audio system. The similarly kitted out five-door hatchback lists for $25,550 to start.
The $25,440 Select Sport upgrades to 18 inch wheels, synthetic leather upholstery, rain sensing wipers and Alexa AI voice assistant.
Moving up to the $27,090 Preferred adds a sunroof, seat heaters and power driver’s seat.
The $30,210 Carbon Edition comes standard with AWD, plus an upgraded red leather interior, special paint and a wireless charging pad.
If you want more power, the $36,740 gets a turbocharged version of the 2.5 liter engine, along with AWD, larger (10.25 inch) touchscreen, paddle shifters, heated steering wheel and navigation.
If you want to shift your own gears, the $31,450 Premium (hatchback only) comes with a six speed manual, along with a premium 12 speaker audio system, leather seat covers, the larger LCD touchscreen and a wireless charging pad.
What’s New For 2026
Automatic stop/start “technology” has been deleted – thanks due to Trump – along with cylinder deactivation. Both of these were compliance technologies designed to help Mazda (and other car companies) deal with federal regulations pertaining to C02 “emissions” as well as gas mileage mandatory minimums. Trump’s EPA has throttled back on these, so Mazda and other manufacturers no longer need to equip their vehicles with these compliance technologies.
Also, even the base trim gets a standard eight speaker audio system.
Two bodystyles – and neither’s a crossover.
Standard 2.5 liter engine doesn’t need a turbo to make good power.
Available manual transmission.
Manual is limited to the hatchback – and to the fairly pricey Premium trim only.
Mazda’s push/rotate knob controller interface for the stereo is awkward to use.
AWD is limited to the Carbon and Turbo Premium Plus trims.
The Mazda3 stands out from the crowd not just because it’s not a crossover but because it has more under its hood than a motorcycle-sized 1.5 liter (maybe 2.0 liter) engine that has to rely on a turbo to generate adequate power. The Mazda’s standard 2.5 liter engine is a kind of latter days “big block” engine – old school muscle car reference – relative to the motorcycle-sized engines that are being put in so many new vehicles and even luxury-brand vehicles.
It makes 186 horsepower without relying on boost – which is literally pressure. The problem with that is engines that are under pressure are engines that – generally – do not last as long as engines that lead a less pressured life. The pressure is compounded in small engines because internal wear surfaces such as bearings are also smaller. There is less area to absorb the pressure. This is why turbos were once found mostly in high-performance cars, where even more power was wanted – even if it came at the cost of shorter engine life.
Another plus is the standard six speed automatic. It is also unusual in that so many car companies have gone over to either continuously variable (CVT) automatics or automatics that have eight (or even nine or ten) forward speeds. Both of these kinds of transmissions are compliance transmissions – of a piece with the small, turbocharged engines that they’re paired with. They are designed to help vehicle manufacturers cope with federal emissions (principally CO2) regs and also Corporate Average Fuel Economy (CAFE) regs that require every car company to achieve a certain “fleet average” miles-per-gallon figure. It is currently about 35 MPG. CVTs – and transmissions with more than six forward speeds – help with that, but at the cost of complexity, cost and less-than-ideal driving feel. CVTs can feel like they’re slipping – and transmissions with all those forward gears can sometimes feel like they’re searching for the right gear.
Also, their long-term reliability is not as good as the proven track record of simpler automatics, such as the Mazda’s six speed.
You can also get a six speed manual, which is becoming as hard to find as an engine that isn’t tiny – and turbocharged to make up for it.
Something you won’t find anymore – in this Mazda – is the obnoxious stop/start system, which is also a compliance technology. Mazda dropped it after Trump dialed back the compliance pressure (by rescinding fines for non-compliance). Also gone – for the same reason – is the cylinder deactivation system that Mazda used to include as standard.
If you want a turbo, you can get that. It’s standard in the Turbo Premium trim and it’s not there because the 2.5 liter four needs more power to adequately propel the car. It is there to propel it more than adequately. The turbo boosts the output of the engine to 250 horsepower (and 320 ft.-lbs. of torque) which is output comparable to what a Corvette’ 5.7 liter V8 made in the mid-late 1980s. Performance is comparable, too. The turbo’d Mazda3 can get to 50 in about 5.6 seconds.
The non-turbo’d versions can make the same run in about 7 seconds.
Interestingly – impressively – there’s not much difference between the mileage touted by the non-turbo’d 2.5 liter engine – 27 city/36 highway – and the 23 city, 32 highway touted by the much more powerful turbocharged version of this engine.
It’s nice to drive a car for once. The formerly ordinary becomes something special when that something is no longer ordinary.
Crossovers have numerous practical virtues, but they are generally transportation appliances, with all the driving verve the term suggests. This car is also particularly fun to drive because it’s a Mazda – and Mazda tries to imbue all of its models with some of the Miata Spirit. That fun-to-drive quality that defines Mazda’s popular little sports car. It is a kind of eagerness to go – like a horse that responds to the rider. Mazda knows there are many people who’d love to have a Miata but have to have something with more than two seats and a tiny trunk. The 3 sedan – and especially the 3 hatch, with the available six speed stick – are designed to be the “Miatas” for people who need the extra seats (and doors).
The 2.5 engine is a different kind of fun.
It is bigger than the Miata’s 2.0 liter four and though it makes roughly the same horsepower as the Miata’s four, it makes it sooner (at lower RPM) and it makes a lot more torque – 186 ft.-lbs. vs. 151 for the Miata’s four – and so it feels stronger at lower RPM, which is ideal for the daily drive.
Because there is no turbo – with the standard version of the 3’s 2.5 liter four – there is no sense of the engine having to gather a head of steam before the car jumps when you ask it to. The six speed auto is also one of the best automatics currently on the market, in part because it has six speeds – which is plenty for driving (vs. complying). The six speed manual is even better, if you’re wanting the Miata experience in something that can accommodate more than just you and one passenger. The shame is Mazda has been effectively forced – by the regs – to limit the manual’s availability to the hatchback and then to just one trim. The reason why is the manual-equipped 3’s slightly worse gas mileage (23 city, 32 highway) which creates problems for Mazda as regards . . . compliance.
The turbo’d version of the 3 is what the MazdaSpeed3 used to be in just about every respect except for the name. Its 5.6 second to 60 timeslip makes it pretty much the quickest car in the class (besting the VW GTI) and its standard AWD and grippy suspension makes it a kind of stealth alternative to the Soobie WRX that cops are less likely to pick out of a crowd and that goes for the insurance mafia, too.
If only it weren’t for the awkward push/turn rotary knob interface on the center console that you have to use to access the stereo controls, it’d be difficult to find anything substantive to complain about. You have to push the knob to open various menus, then rotate it like a dial to find the thing you want to access and then push, again. It’s a multi-step process to do what can be done far more sensibly (quickly, easily) by turning separate smaller knobs. Mazda seems to know that because there’s still a dedicated small knob for the volume that does not require going through multiple menus to increase or decrease the volume – as you must do if you want to change the station you’re listening to.
The sedan is a good-looking, even sexy-looking car.
Even though it is not a rear-drive car its looks suggest it might be. The hood is long, as if to accommodate a front-to-rear mounted engine (rather than a transversely or sideways-mounted engine) and that sets the tone for the rest of the car’s dimensions. The downside is the relatively small (13.2 cubic foot) trunk – even though it is relatively large for a small sedan. As a point of comparison, the much larger Honda Accord sedan only has a 16.7 cubic foot trunk. In both cases, this accounts for the diminished mass-market sales volume of sedans as a class. They lack the cargo-carrying space many people need. Especially people who cannot afford more than one vehicle. That’s arguably the main reason why crossovers have largely replaced sedans – including Mazda’s. Even a small crossover will typically have much more cargo-carrying space than a full-sized car.
But it’s nice that the 3 sedan is still available – for people who maybe need the extra seats but don’t need the extra cargo-carrying space.
And for those who do, there’s always the hatchback. It offers 20.1 cubic feet of cargo-carrying space as well as the versatility of the hatchback layout, which creates more usable space.
There is a chance that Mazda might be able to offer the sedan with the manual transmission – and the turbo engine in more than just the one high-end trim – on account of the waning of regulatory compliance pressure. This would, arguably, greatly increase the 3’s appeal to a wider audience of people who’d like to have the option of shifting their own gears – and would like to have the option of more power without having to pay for all the other extras that are currently come along for the ride.
Sedan – or hatch – and with (or without) a turbo’d engine. It’s appealing to have such options.
Now, if only there were more of them.
11 COMMENTS
  1. Thanks Eric! I’m going to be in the market for a new car this year and have it down to either a Nissan Frontier or Mazda Cx 5, but the Mazda 3 is very tempting after reading your column. The only thing about it is that I’ll have an occasional back seat passenger and an elderly person who has an easier time getting in and out of trucks/suvs than cars. SO, like a Miata, it may not make it to a coin toss, dammit. PS I won’t even remotely consider anything from the big 3 or anything ruined by CVT.
  2. One of my favorite small cars. Bud has a sedan turbo version and it looks great and rips.
    He commutes with it.
    Tried to get my daughter to buy one, but she couldn’t find one (sedan) anywhere. I couldn’t either.
    Dealers don’t seem to keep the sedan in stock, or they sold out for the year?
    I am not as much a fan of the hatch version, just me.
  3. This is what I’ve decided on if the wife’s current car decides its time is up.
    Though that probably wont happen any time soon, so I hope Mazda keeps making these.
  4. The Hatch version of this car is about the ugliest vehicle I’ve seen since the AMC Pacer. It’s tiny window apertures limit visibility to the point of danger. There is no way I would drive one. I don’t like Mazda’s Key Blob’s either
  5. Something to keep in mind, the 3 sedan is made in Mexico while the hatch is still made in Japan. I have a 2014 3 sedan that was made in Japan, no problems other than the touchscreen went wonky (I think they call it “ghost touching”) and started calling people randomly. Some kind soul created a bit of software that disables the touchscreen part, so problem solved. I never used the touchscreen anyway. Personally, I like the rotary controller. And good to hear about awful start/stop and cylinder deactivation going away! Now if they’d get rid of the other crap like driver assistance and auto braking, I might reconsider getting a new CX-5.
  6. I drove a ’08 3 hatch for many years in the Before times. For a moderately practical car, it sure was fun to drive. The ’26 looks much the same. Great to see how quickly Mazda was able to start deleting compliance stuff.
    The rotary knob infotainment interface is *different*, for sure.
    But I’ve come to prefer it after driving a CX-50 for a while. Knobs and related buttons are easily worked with muscle memory without the awkwardness of trying to touch the screen or taking eyes off the road.
    An underappreciated feature of Mazdas.
  7. Eric, you have a typo there in the title though I wish the Mazda 6 was coming back! I see a good amount of 3s around here but I’m sure it’s not long for this world. And you’ll be missing that rotary knob once you see the new models like the upcoming CX-5. Giant touchscreens with no buttons. It’s sad.
