Home Features Selling an EV? A Few Things to Consider
40
If you’re getting ready to sell an electric vehicle, it helps to think about what someone shopping for your car will want to know. The year, mileage, and model are a starting point, but EV buyers often have questions that a basic used car listing doesn’t answer.
Which version is it? What equipment does it have? Are the software features shown on the screen included with the car? Does it come with charging equipment?
You don’t need to turn your listing into an owner’s manual. A clear description and a useful set of photos can answer many of those questions before someone contacts you. Taking a little time to gather the details also helps you avoid having to look up the same information for several prospective buyers.
Know Which Version You Have
Include the model, trim, and drivetrain rather than just the name on the back of the car. Is it rear-wheel drive or all-wheel drive? A standard range, long range, or performance version?
Two cars that look nearly identical can have different equipment. Make sure you describe the vehicle you actually own rather than copying specifications from a newer model or a different trim.
Start with your vehicle records and the information available through the car’s display or manufacturer account. These can help you confirm details that may not be obvious from the exterior badges. If a previous listing or dealer description conflicts with those records, resolve the difference before repeating it in your own ad.
Use the full model and trim name where possible. An enthusiast may recognize an abbreviation immediately, but someone buying their first EV might not. A straightforward description makes the listing useful to both.
Seating configuration is another detail worth confirming, particularly when a model was available with more than one layout.
Be Clear About Software Options
Does your Tesla have basic Autopilot, Enhanced Autopilot, or Full Self-Driving? Was FSD purchased outright, or are you paying for a subscription?
Those are useful distinctions for a buyer. Having a feature available while you own the car does not, by itself, explain what the next owner will receive. Check the current status and applicable terms before describing software as included with the sale.
The same principle applies to other EVs with optional connected services or subscription features. Be specific about what is included and what requires a separate payment.
It also helps to distinguish hardware from software. Describing the equipment installed in the car is different from describing which functions are currently enabled. Where you have that information, explain each separately rather than assuming a buyer will know what one means for the other.
Avoid using broad phrases such as “has everything” or “fully loaded” in place of an actual description. Naming the options gives a buyer something concrete to review and ask about.
Mention the Equipment Buyers Might Overlook
Wheel size, seating configuration, towing equipment, and other options can help distinguish your car from similar listings. Interior details are useful too, including upholstery, heated seats, and any equipment specific to the version you own.
Has anything been added or changed? Mention aftermarket wheels, suspension changes, window tint, or other modifications. If you still have the original parts and plan to include them, say so.
Be clear about what the photos show. If the car is pictured with a roof rack, a second set of wheels, or another accessory that you intend to keep, explain that in the description. It is easier to establish what comes with the car at the outset.
Charging equipment is worth mentioning as well. Let buyers know which cables and adapters are included rather than leaving them to guess. Photographing those items together is a simple way to make the list easier to understand.
You don’t need to describe every standard feature. Focus on details that help explain the particular car you’re selling.
Give Useful Information About Condition
Describe the condition of the tires, interior, and exterior. Include clear photos of any noticeable wear or damage, along with the parts of the car you want to show off.
Specific information is more helpful than simply calling a car “excellent” or “like new.” If the tires were recently replaced, mention when. If there is a scuff on a wheel or wear on the driver’s seat, show it clearly.
If you have service records or documentation for repairs, mention them. A short explanation of the work performed is more useful than a vague statement that the car has been maintained. You can keep supporting records available for interested buyers without filling the listing with every document.
For battery condition, share any available assessment or service information and explain what it is. Avoid treating the range shown on the dashboard as a complete measure of battery health.
If you describe your own driving experience, make the context clear. Your usual commute and charging routine can be useful background, but they should be presented as your experience rather than a promise about what every buyer will get.
Show the Features You’re Describing
Photos can help explain equipment that isn’t obvious from an exterior shot. Include useful views of the vehicle’s information screen, seating layout, controls, and other features mentioned in your description. This gives buyers a clearer picture of the car beyond its model name.
Start with clear exterior photos from several angles, then move inside. Show the front and rear seats, dashboard, cargo area, and any additional storage. If you mention a particular accessory or option, include a photo that helps identify it.
Take the photos in good light and check them before posting. Reflections, shadows, and tightly cropped images can make it difficult to see the details you intended to show.
Arrange the images in a sensible order so a buyer can work through them without jumping between unrelated close-ups. A useful photo set should complement the description, with each providing information the other may not capture.
Put It in Front of Interested Buyers
General classified sites are one option. A specialist marketplace such as Find My Electric focuses on used Teslas and other electric vehicles, giving sellers another place to reach people shopping for an EV.
Wherever you list, use the available fields to describe the vehicle accurately. Then use the written description to explain anything the standard fields don’t cover, such as included accessories, modifications, or relevant service history.
Keep the information consistent across your listing. The mileage, equipment, and description should agree with the photos and any details you provide when answering questions.
Selling an EV does not require a complicated pitch. The goal is straightforward: help buyers understand what makes your particular vehicle different from the next one they’re considering. Clear information gives them a useful starting point and can make the conversations that follow more productive.
