There are lots of SUVs on the market – but very few 4x4s. What’s the difference? Well, it’s the difference between a professional fighter and a guy who hits the bag at the gym on weekends. Both throw punches. One of them hits harder.
Like professional fighters, there are only a few 4x4s in the ring.
One of them is the Ford Bronco.
The Bronco is a 4×4 rather than an SUV – which means it is made specifically to be capable of taking on un-paved roads, deep water and rugged terrain generally. Unlike most SUVs, which offer 4WD, the Bronco comes standard with it and it’s different from the systems found in many SUVs because it has 2WD High (rear-wheel-drive) and 4WD High selectable ranges, as well as automatic 4WD and 4WD Low. The majority of SUVs have automatic 4WD and some do not come with Low range gearing.
The Bronco also offers something else no other SUV on the market in this country is even available with. A manual transmission.
Ford also offers the Bronco in two-and-four-door bodystyles and you can get a soft-top or a removeable hard-top. There are three engines to pick from, too – ranging from the standard turbocharged 2.3 liter four cylinder to the optional twin-turbo 2.7 liter V6 and the top-of-the-line 3.0 liter turbocharged V6.
Prices start at $38,995 for the Base two-door with the 2.3 liter engine and your pick of either the seven speed manual or the available 10 speed automatic.
The Big Bend ($40,420) is next. It adds a full-size spare mounted on the rear (swing out) door and leather trim inside.
The Outer Banks ($47,940) comes standard with the automatic plus running boards and 18 inch wheels with all-terrain tires.This trim is eligible for the optional 2.7 liter twin-turbo V6, which is available as a stand-alone option ($2,145). This engines comes only with the automatic.
The Badlands ($49,585) swaps out the 18 inch wheels and all-terrain tires for a set of 17 inch wheels and 33 inch knobbies, plus a heavier-duty suspension with Bilstein shocks, rock rails and skid plates, plus wiring for auxiliary switches to control winches and such.
The Heritage ($51,475) is essentially a cosmetic package that hearkens back to the original Bronco of the ’60s with white hardtop, plaid cloth interior and graphics unique to this trim.
The Stroppe Edition ($75,635) gets everything you’d get with the Badlands plus the 2.7 V6 as standard equipment and the Sasquatch package that’s optional with the Badlands. The Sasquatch package bundles 35 inch knobbies, a lifted suspension, locking front and rear axles and high-mount fender flares.
The Raptor iteration is the most expensive ($79,995) off-road-capable and most powerful Bronco. It is the only Bronco that comes with the 3.0 liter V6 and you also get 37 inch beadlock knobbies on 17 wheels, Fox off-road shocks. a heavier-duty rear axle and an electric decoupling front sway bar (to allow greater wheel articulation) plus all the stuff that comes with the Sasquatch package.
The Bronco’s only real rival is the Jeep Wrangler, which is also available in two and four-door bodystyles and is also a 4×4 rather than an SUV.
What’s New For 2025.
The Stroppe Edition is new; the previously available Everglades and Wildtrak trims have been retired. There’s a new March Gray matte paint option and a factory wrap option, along with some minor equipment changes.
Very much like the classic Broncos of the ’60s in that this rig is designed to go anywhere you dare.
Though it doesn’t come with a V8 like the classic Broncos of the past, its standard four makes more power than any of the classic Bronco’s V8s.
Available with a manual transmission.
Only the standard engine is available with the manual; you also have to move up to the more expensive trims to be able to get the optional 2.7 V6.
Though extremely capable, the Bronco’s 4WD relies on electronics to engage/disengage the ranges.
Jeep Wrangler’s MSRP is thousands less and you get a standard V6, as well as a standard manual transmission.
The Bronco’s standard engine is a turbocharged 2.3 liter four cylinder that touts 300 horsepower and 325 ft.-lbs. of torque. This is a lot more of both than a 1970 Bronco’s 289 V8 conjured – which was all of 205 horsepower. Ford has added a PFI circuit to the DI (Direct Injection) to prevet carbon fouling (an issue with DI-only engines).
The classic Bronco also came standard with a manual transmission – but it was just a three speed, with no overdrive gearing. The Bronco’s standard manual has seven, including overdrive – allowing for comfortable highway speed driving. Without overdrive, a classic Bronco was very uncomfortable on the highway – unless you kept your speed down to around 60 MPH. Even then, you were not far from a classic Bronco’s top speed.
You can also opt for a 10 speed automatic; this box can be dialed in (literally) via a rotary knob controller on the center console that lets you adjust shift timing and firmness, depending on the conditions.
The Bronco’s main rival – the Jeep Wrangler – comes standard with a larger, 3.6 liter V6 but it only makes 285 horsepower and Jeep says the Wrangler so equipped is only able to pull 2,000 lbs. The Bronco with the 2.3 four is rated to pull as much as 3,500 lbs. The Jeep also comes standard with a manual transmission – but it’s a six speed.
You can opt for a V6 in all but the Base Bronco trims; it’s a small one – just 2.7 liters – but it touts 330 horsepower and 415 ft.-lbs of torque. The power come not so much from size or cylinders but from boost. This engine has two turbos. It massively outguns the Jeep’s V6, which is the only engine you can get in the Wrangler unless you can afford spend $100k for the Rubicon 392 version or want a turbo-hybrid four drivetrain called 4Xe; the latter only offers 270 hp.
If the 2.7 V6 isn’t strong enough for you, the Raptor’s 3.0 liter turbocharged V6 ought to be. It makes 418 horsepower and 440 ft.-lbs. of torque and it’s a steal relative to the $100k Rubicon 392, which lists for nearly $25k more.
Equipped with this engine, the Bronco is rated to pull up to 4,500 lbs.
All Broncos come standard with a 4WD system that can be set for 2WD High, 4WD High, 4WD auto and 4WD Low range via push-buttons located inside the drive-mode ring on the center console. Front, center and rear locking diffs are available or standard – depending on the trim/packages you buy.
Driving the new Bronco is like being young again – if you’re not young anymore. It is a pleasant reminder of how much better things were – or felt like they were – when some of us were young.
They were certainly more interesting – in the sense that there was much more variety back when the original Bronco was new. There were rear-engined/air-cooled VWs, rotary-powered Subarus, great land yachts with huge V8 and strange (but interesting to see) things like the AMC Pacer – and it was just one of many that weren’t all the same, as it looks and seems to be today.
The Bronco is interesting before you even drive it – because it is so interesting to look at, especially the variants with three-tone paint jobs. But the really interesting thing is much deeper than that – and you have to go for a drive to understand that. Open the door – which feels heavy and solid rather than thin and flimsy – and sit down and look out through the nearly vertical front glass over the scalloped hood with the grab handle things on either side. If you close your eyes – and don’t look at the LCD dash display – it’s not at all difficult to imagine that you’re getting ready to drive a ’70 Bronco rather than a brand-new one.
Then you get going and realize that while the visuals are an excellent conjuring of the early ’70s, the drive is updated in all the right ways. There is power – and acceleration – for openers. The old Bronco was under-engined, even when it was equipped with its available V8. It was great for slow-trekking fire roads, but on the road it was very clear you were driving a 4×4. The thing was geared for slow-motion tenacity, not high speed cruising much less on-road cornering.
This Bronco is adept at all three.
While the standard turbo four is more than powerful enough, the optional V6 is worth the extra charge because of the sounds it makes. It’s not the sound of a V8 – but Ford didn’t have to fake that kind of sound (as some car companies do) because this little V6 makes a great – if different – sound. It’s wonderfully belligerent when you ask it to be. On the other hand, there is something equally – if differently – pleasant about being able to shift for yourself (with the standard 2.3 liter engine). It’s part of what makes the new Bronco compelling. It is as far from being one-size-fits-all as almost everything else new is.
Yet – to channel (and parody) Ricardo Montalban – it is off pavement where the Bronco best answers my demands. This thing has the clearance, the angles of approach and departure and all the other equipment needed to take you wherever a dirt bike can go, assuming there’s room between the trees to squeeze by. It’s as real-deal as it gets and it’s all factory-equipped. No need to modify the Bronco.
Other than the tire/wind noise you will hear (especially if you get the knobbies) it is like driving an SUV.
Just one that’s not.
The Bronco’s existence proves it is possible to design a new vehicle that is both visually (and otherwise) interesting as well as compliant. Though the new Bronco looks like it time-travelled from 1970, it meets all 2025 federal “safety” standards, outside and in. Yet it doesn’t look like a compliance mobile and that is hugely compelling if you’re weary of the way compliance pressures have made almost everything new look as if they were all stamped out of the same mold, then given different badges as they left the factory.
Like its main rival, the Bronco is available with two or four doors – and with a removable hard-top or a soft-top, as you prefer.
The two-door version is 173.7 inches long; the four-door version is 189.4 inches long. The chief difference – other than length and whether there are two or four doors – is how much room there is in back and for cargo. The two-door has 35.7 inches of backseat legroom and 20.6 cubic feet of cargo with the back seats up. Fold them down and the available space increases to 52 cubic feet. The four door has a bit more legroom – 36.3 inches – and a lot more room for cargo: 38.3 inches with the back seats in place and 77.6 cubic feet with them out of the way.
The two-door Wrangler is significantly shorter than the two-door Wrangler; it is 166.8 inches long and has only 12.9 cubic feet of cargo capacity with its rear seats up and maxes out at 31.7 cubic feet. The four-door Wrangler is about the same overall size as the four door Bronco and comparably spacious for passengers and cargo. But both versions of the Jeep lack an engine upgrade that isn’t a six figure upgrade. The 4Xe plug-in hybrid is only an upgrade if you value this variant’s electric-only (for about 22 miles, fully charged) capability.
The Bronco’s argo area is accessible via a swing-out rear door or via a lift-up rear glass section; each can be opened separately, as you prefer. A nice touch that people who like vehicles like this will love are the not-hidden pinch welds that can be seen when you open the doors or the rear liftgate. The spot welds on the integrated roll bar are ruggedly visible, too.
It speaks to the Bronco’s serious retro demeanor that even the tested Stroppe Edition comes standard with manual-adjust seats. There’s a grab handle you pull to move them forward and back. It’s simple – and that’s good – because simple is less likely to break and even if it does, mechanical is simpler to deal with in a pinch than electrical.
It’s also faster. Moving the seats forward and back manually takes less time than waiting for electric motors to move them.
Ford might have pursued the same simple-is-better approach insofar as regards the 4×4 controls. A retro shift lever for engaging 4WD High (and 4WD Low) would have gone nicely with the thematic revisiting and also been more rugged and simpler and easier to deal with off-road if that ever becomes necessary than the electronic switches (and engagement) you get.
Same, arguably, goes for the gauge cluster. It’s LCD and so that is just like everything else. You do get more info – such as the grade (ascending/descending) of the road or trail you’re on. But some analog gauges would have been as emotionally interesting as the rest of the Bronco.
SUVs – and crossovers are as common as minivans were not too long ago, which is why this 4×4 stands out like SUVs used to, before they became (effectively) the modern minivan of choice for most.
Here’s a very different choice, for once.
Thanks for the video look at that Bronco. Never saw one like that here, it looked nice. I was thinking more along the lines of $13,000 for it, but that video-bling-flashy-dashboard kind of ruins it for me. It seems so damn cheep & non-durable.
Can they be replaced with gauges? …And, drive-by-wire swapped with a carb, or at least, TBi?
$75,000 is the upper limit of low-cost houses, here. I guess I’m, Little People?
I was disappointed you didn’t take a Stage Left and take it off-road, even gently so. That would have been super cool, to get it dirty. But yeah, almost no video skills, watching your garage door while you talked was tragic, walk around the vehicle or pop the hood while ya talk, man. Ha. Poke a stick at it. That said, you spoke good stuff.
When I read, “The Bronco’s only real rival is the Jeep Wrangler”. I wondered how you would compare the Bronco to an FJ?
…You really should-if-you-could do a video of getting all 3 dirty & muddy. Jmho. …A couple of girls,… some blue steel,… a fire afterwards? ‘They’ should pay you to show us That.
The new Bronco has had a problem with front suspension since it came out years ago.
Tie rod ends break very easy and something causes wheel bearing to wear out very fast.
You can find comments from people with $70K Broncos who aren’t happy it barely handles dirt roads without leaving you stranded.
Interesting comment there, FarmerChet. Perhaps, that’s one of the reasons I see so very few of them in these parts, and I see sooooo very many UTV’s all over the place? The price (and utility) being the other reason(s).
…Do you think we’ll ever see Eric test drive a UTV?
I’ve never looked into the new Bronco’s, but – if true – this has Got to be about The Worst type of feedback they could get, “You can find comments from people with $70K Broncos who aren’t happy it barely handles dirt roads without leaving you stranded.”
That whole, ‘time will tell’ thing.
Anyway, thanks for making me feel better about owning an FJ.
Never left me stranded,.. and analog gauges. (‘Cept the odometer. But, that’s okay, who cares about that?)
These had a recall for screens shutting down. And I thought I read that these Broncos crumbled like a cookie in an accident. Or which “retro” vehicle am I thinking of?
“a recall for screens shutting down” ?
Wow.
…Do many other brands of, “highly advanced” vehicles do that?
If so, I wonder how many?
…Durability. It’s why I buy most sheet.
Simpler is better. I recently wanted to upgrade my 84 f-150 300 I-6 four speed with something more reliable for long distance hauling. It took me a while but I finally found what I wanted, standard cab, V8, FWD, 3/4 ton, manual shift lever for 4wd with manual locking hubs. The Bronco is intriguing but repairs will be expensive down the road I think. My 73 CJ5 will still do for my off roading, very simple and easy to repair.
I agree, John – I am going to do an in depth look at the original Bronco vs. the new one.
A rare 2 door!! Guessing its body on frame?
You are so right about how expensive it is. Even if I could afford it, it’s just still too expensive for what it is, so I wouldn’t. Even its crossover little brother the Bronco Sport is priced higher that what the full Bronco should be.
If it wasn’t for the EPA, I bet it would have a 5.0 V8 option or maybe even a diesel. Did the original ever have a diesel?
If it wasn’t so expensive, Ford wouldn’t be able to make enough of them. I know people would buy it!
Knowing Ford, probably not.
I wonder if Ford ditched the plastic oil pan that this new version originally came out with? I can’t imagine an “off road” vehicle having one, even with skid plates.
Wow, “the plastic oil pan that this new version originally came out with?” — really?
I’d never thunk it.
Thanks for conceptually changing how I see sheet flying off the assembly line these days. Wow, just, wow.
Indeed, Helot –
Most new engines have plastic intakes, too. As I type this, the big cast iron V8 in my Trans-Am is supported by a big block of wood under the oil pan and a three ton jack. If the oil pan were made of plastic, I expect there’d be a mess on the garage floor by now.
A spooky image (plastic intakes & plastic oil pans) vs. a harmonious image of organic carbon oil soaked woodblock supporting timeless aged steel.
Tight-ass cheapness newer technology vs. hardened & durable older technology.
Hmm,… which wins in the long run?
Anyway, nice image to end the day – or, start the day – with, Eric.
“supported by a big block of wood under the oil pan and a three ton jack.”
Git sheet, done.
The endearing thing about the classic Bronco is that it was simple. I think more vehicles should embrace simple, reliable tech. And a manual option is a total bonus.
I suspect things like manual seat adjust was put there for Ford to save $$, not customer demand. Doesn’t look like they passed that savings on.
If I were to buy, it would be base model 7 speed to fit my needs for it, and it would cost me over 40 with tax, title, etc. Geeze.
Sorry, as a musician, I see repetition with disdain.
Eric talked about a lot of stuff but all I kept seeing was the dash.
How did this get past spell check? “It is a pleasant reminder of how much better things were – or felt like they were – when som of us were young.”
So much interesting insight tonight: “as a musician, I see repetition with disdain.”
Why is that?
As a non-musician, I find the repetition from a song bird or a wave from the river to be soothing and quite pleasant.
Oh wait! You mean that flashing light on the dashboard? It was prolly a feature, not a bug. Wasn’t that annoying? I thought it was a visual destruction/distraction a hammer or black tape might solve?
Glenwood Springs Ford was selling these for $99,000+ in 2024. This year looks like they’re not moving as many but its still popular with the mountain jet set.
RE: Manual seats. Back in the early 2000s, a sign you were in a luxury car was power everything, but more telling was the seat memory. BMW still does this to an extreme, tying it to the key fob and basically reloading all settings. Wife left the seat up against the dash and Disney radio blasting? Just push the button and everything (seat, steering, pedals, radio presets, dashboard layout) goes back to where you left off. Very useful, especially in the case of power seats that take extra seconds to move into position.
Why hasn’t that trickled down to the masses yet? I’m sure the black box keeps track of that stuff.
RE: “$99,000+ in 2024.”
I noticed, that’s the same price as a brand new 3Bd/2Ba mobile home.
Also, I’m uncertain what you meant when you wrote, “Why hasn’t that trickled down to the masses yet?”
….”Just push the button and everything […] goes back to where you left off.”
Myself, I’d rather not have to push a button, and everything just stayed right where I left it.
Analog & levers,… all the way, baby.
“Technology” more & more, seems like it’s not leaving us all better off. Dependent, constantly fiddling with dials & buttons, and buying…
One of my neighbors has one in white: He calls it, so help me, OJ.
That’s, sad. On so many levels.
‘The Jeep also comes standard with a manual transmission — but it’s a six speed.’ — eric
Is that a bad thing? I own two 5-speed manual vehicles, and have never felt shortchanged. The Frontier has 4WD Low, so there’s no need for a stump-puller 6th gear on the low end. If it had adequate power, conceivably a second overdrive ratio on the top end (i.e., a 6th speed) would be useful for 100 mph cruising.
Frankly I can’t imagine what seven speeds are for, unless this too is a compliance transmission.
Yes, I agree, 7 speed manual is indeed “one toke over the line”. Same BS mistake with 12 speed analog bicycles nowaday.
Hopefully ratios were chosen to take best advantage of 7 choices, three sorta low for 4×4 time and upper 4 favoring typical highway use. These Bronco things definitely have the snob seal of approval in wealthy enclaves so far. Finally the 6 figure toy market has a Rubicon alternative. They’re obviously selling way better than that $13B loopa lazy lightnin mistake.
What’s a, “$13B loopa lazy lightnin mistake”?
Is it like this?: “Back in 1984, Donald Trump skipped buying the Dallas Cowboys for $50 million, calling it a losing bet. Instead, he poured money into the USFL, which collapsed. Four decades later, the Cowboys are worth $13 billion. A single missed move that reshaped his fortune.” – via some annoying website which overtakes your pc.
