Home Features Blank Screen
Blank Screen
52
2356
The nice thing about non-digital things is they don’t just disappear. Digital things sometimes just do. Like the information that was being displayed on the digital instrument panels of about a quarter-million new/nearly new Ford Broncos and Bronco Sports that are now being recalled. Their displays stopped displaying – which means the driver no longer knows how fast he’s going, how much gas he’s got left and other important things.
According to Ward’s Automotive, “Ford’s Critical Concern Review Group was alerted to instances of blank instrument panel cluster screens on some 2025-2026 Bronco and Bronco Sport vehicles manufactured with SX2 instrument panel clusters.”
It’s not just the Broncos, either.
“Between September and October, the Critical Concern Review Group reviewed the issue and found that the vehicles were compliant with federal safety rules when they were released to dealerships. However, Ford’s investigators also determined that the concern was similar to an August recall of more than 355,000 F-series trucks for blank instrument panel clusters.”
That’s a lot of clusters.
It is also something that never happened before dashboards went digital because needles and dials don’t just go blank. An analog speedometer might stop working; the cable might snap (if it’s a mechanically driven speedometer) or the electronic parts might fail – but the speedometer itself will still be there – and getting it to work again is a simple matter, if it’s mechanical. It’s either the cable or the speedometer itself and both can be physically checked to ascertain which is not working. The speedometer is also – if it is mechanical – a discrete (that is, separately functioning) instrument that, if it fails, will not result in the other instruments failing, too. In other words, if the speedo stops working, the gas gauge (and temperature and oil pressure gauges) will probably still work.
It is unnerving when – just like that – nothing works, as has been happening with Broncos and F-trucks that have the digital instrument clusters subject to the recall. It is even more unnerving because the recalled vehicles are new, or nearly new. This sort of thing rarely, if ever, happened in the past – before the advent of digital displays. If a speedometer failed, it was typically after many years and miles of driving, the result of mechanical wear and tear, or a failure of the electronics (if non-mechanical) after many years and miles of driving. And it was extremely rare – if it ever happened at all – for the entire gauge cluster to just stop working before the vehicle had entered its dotage.
Clearly, there is a defect here – as regards the Ford screens going dark. But it raises some questions that bear thinking about that go beyond defects. For one, digital screens inevitably go dark – or glitch. They are basically the same display tech you’re looking at when you watch TV on a flatscreen display or view your phone’s screen but very different in one really important way.
They are not inexpensive to replace – and you may not be able to replace them.
Flatscreen TVs are cheap because they’re all basically the same; size being the main difference. Phones are just cheap. They are literally throw-aways after about three or four years, because it’s not worth fixing them because it’s so cheap to replace them.
The digital display screens in vehicles are not like that, because each is specific to a particular make and model of car and (probably) particular to a specific year and configuration, too. It is not like it was once, when you could swap out a broken speedo from newer model year car and replace it with one from an older model year (or the reverse).
Also there are no generic replacements; if the LCD screen goes dark, you must buy a replacement from the dealer and that’s not going to cheap. It may not even be possible – if the manufacturer no longer makes replacements, a possibility that is not improbable once the vehicle in question is older than about a decade (or even less) and the supply of replacements has gone away.
Then you have an even more expensive problem – because a vehicle with a blank screen for a display isn’t going to be easy to sell or worth much as a trade-in. It might not even be legal to sell, because a vehicle without a working speedometer will probably not pass state safety inspection. You probably wouldn’t want to drive it anyhow, if the gas gauge and odometer aren’t being displayed anymore – because it’s not very fun not knowing how much gas is left in the tank. If the warning lights don’t work, you’ll have no way of knowing whether the engine’s overheating – or lost oil pressure – until you find out the hard way.
Ford says “the issue can occur when the vehicle’s internal network attempts to ‘wake’ the instrument panel cluster from sleep mode within a narrow timing window, triggering a memory protection fault that prevents the display from powering up.”
Maybe we were better off when we just had gauges that didn’t “sleep” – or need to be “powered up.”
52 COMMENTS
  1. At one time I was considering purchasing a RV. I noticed they all seemed to have cheap tv brands and asked about it.
    Well, you may show up somehwere and the tv doesnt work. Just go to walmart and get another cheapie. Cant really do that with automobiles.
  2. This stuff is in aircraft too. A helicopter pilot told me how in the past a bad gauge was an easy fix. He told me how a newer chopper he was flying had the digital gauges go out prior to takeoff and it took a week to repair.
      • Part of flight training is to deal with that exact scenario. It’s remarkably stressful having your instructor cover the gages one at a time until your entire dashboard is blank and you’re flying by your senses.
        Of course, that’s nearly impossible with a cluster of mechanical gages, the most vulnerable are stuff like directional gyros and artificial horizons.
  3. In the past, third party products solved many automotive problems.
    So much so, at some point automakers actually start doing some of those things themselves.
    It truly sucks that electronics and software haven’t really followed this history. Automakers have made it very hard to reverse engineer these things, so no affordable replacements from entrepreneurs actually looking to make a buck actually solving problems.
    We need affordable and cheap third party products more than ever!
  4. I was a Ford customer for life. A low bar for them to keep and they fu**ed that up. If I ever buy a Ford again it won’t be one made in this century. Sure glad when we had to lease this year we picked a Subaru over a Bronco, or a Maverick. I get kind of tired of friends making fun of me for driving a dyke mobile, and its incessant beeping when it thinks I don’t see something in the road ahead. But it serves its purpose to not put excessive miles on our older cars, and, it will be going straight back to the dealer in exactly two more years.
    • “ get kind of tired of friends making fun of me for driving a dyke mobile “
      Look, just identify as a male lesbian, problem solved!
      Here in the PNW they’re known as: Lesbaru
    • Drove my SIL late model subi, and couldn’t handle the constant beeping “PUT YOUR EYES ON THE ROAD”
      No…………
      The good news is she recently drove my grand cherokee and she said ‘this is much better, getting one’
  5. Well the aftermarket supplier finally shipped my replacement screen for the ‘18 Grand Cherokee, 3 weeks late. There is a very high demand from Jeep owners since a few years in you’ll get blank center screen, surface blisters, and or “ghost tuning” the radio changing stations randomly (me). The entire radio/info module I believe is around $1800. Screen is $200 which per the owners forums is the problem.
  6. The other advantage of an old school mechanical speedo and tach – even if the faceplate is changed by model year the guts behind the plate stayed the same. Carefully remove the pointer, and the two tiny screws, replace with a working unit, done!
    The lost art of boneyard parts swapping. I needed a radiator for my 70 Firebird. Boneyard had a many years newer Camaro, the guy assured me it would fit just needed an adapter for the different size upper hose fitting. Yep, $75 bucks for a nearly new radiator back on the road no leaks.
  7. ‘That’s a lot of cluster[f***]s.’ — eric
    Indeed. It reveals the engineering bankruptcy of the cell phone as a human interface model for vehicles.
    Electromechanical systems used in pre-2005 autos were more resilient to failures. As Eric points out, even if the speedometer breaks, the gas gauge, the odometer, and other instrument panel indicators do not. Whereas a cheap and nasty digital instrument cluster fails in ‘show stopper’ style.
    I vigorously and categorically reject the digital human interface design of all contemporary vehicles, including the idiotic douchescreen. To paraphrase ol’ Ralph Nader, it is ‘unacceptable at any speed.’ Burn it down!
    • Yup, after the warranty is up, usually 3-5yrs.
      Our Durango bad screen was $5K to fix, under warranty.
      My daughters bad screen (7yrs) died, and the car ran, but she had to trade it and lost big $.
  8. This is no accident. The complete tech-ing of everything, is meant to ensure that NOTHING works in the serfs’ favor anymore.
  9. This goes back to the old saying “If it’s not broke, don’t fix it”. What was wrong with analogue dials? Manual, roll-up-windows? Two keys for you vehicle (one for the trunk, one for the ignition)? Not a darn thing! But, the government always was about fixing everything not broken, breaking it, and then declaring how brilliant they are for fixing what should have been left alone in the first place. I can be quite content having a vehicle with the old school stuff, and minus the saaafety “features” and expensive touch screens.
    Oh, and Eric, speaking of screens, did you see this gem? Subaru owners outraged when ads are now being shown over your touch screen while you drive! As the saying goes, you cannot make this up. Some headlines write themselves! https://www.thedrive.com/news/subaru-owners-are-ticked-about-in-car-pop-up-ads-for-siriusxm
    • This is why most 2013 and newer vehicles with telematics are unacceptable at any speed.
      A vehicle without connectivity cannot be tracked via telematics (though it is tracked by ALPRs). Nor can noxious ads intrude.
      My vehicle’s interior is my private space. No digital douchebags allowed.
      I think I’m turning Japanese Cuban
      I really think so
      — The Vapors, Turning Japanese (1980)
    • “What was wrong with analogue dials? Manual, roll-up-windows? Two keys for you vehicle (one for the trunk, one for the ignition)? Not a darn thing! But, the government always was about fixing everything not broken, breaking it, and then declaring how brilliant they are for fixing what should have been left alone in the first place.”
      Sadly the blame for this rests squarely on the consumers and their insatiable appetite for geegaws and their abject laziness to manually adjust anything.
      These sorts of interior features (ie power everything) has nothing to do with government regulations.
      • How very true, Burn. It is just that the lazy seem to want to speak for the rest of us who were perfectly happy with old school analogue.
      • analog still exists in new vehicles, at least in central america when we visited.
        So the major manuf. (at least the Toyota’s I saw) still manuf. them.
  10. Farley was a successful sales guy with Lexus.
    Perhaps this recall program is simply a marketing scheme to get 8 million people (Ford has 135 recalls so far this year) into dealerships – in order to sell them another vehicle.
    Recall on Sunday, sell on Monday.
    • Are you likely to buy the same brand that has you in the dealer because it’s broken? I doubt it. Not a good sales technique in my book. In fact a terrible one.
  11. Smart TVs are cheap because the streaming services pay the manufacturers to include their icons in the list of online services. The services also receive surveillance/usage data from Samsung, Vizio, Sony, etc, and the manufacturers sell user information to other interested parties.
    Don’t assume that not hooking your TV up to your home WiFi makes a bit of difference. It doesn’t.
    Modern sail phones are even worse in terms of 24/7 surveilance.
    • I think you might have stumbled on the key to making cars “more affordable.” Sell ad space on the dash! As you drive down the miracle mile get ads for fast food restaurants. Running low on fuel? Pop up a Sheetz ad (with directions). Drive above the PSL? Run an ad for Valentine or a law firm… or bail bondsman.
      (sarcasm, obviously)
      • I see your sarcasm but NOOOOOOO!
        I moved from the South (heavy billboard advertising) to Alaska (no billboard ads) and the peace of mind and driving experience is amazing.
        Fuck Morgan & Morgan. They dont even practice here, hallelujah. Live nudes in the middle of nowhere, bet they are hotties. Jesus allows U-turns! Pregnant? Scared? Only 200 more miles to Buc-ees! Thirsty? Hot girls holding ARs selling beer while scantily clad ahead.
        • Morgan & Morgan is based in Florida.
          Alaska has Buc-ee’s?
          The Beaver is all about the tax breaks. Beware if they come to your town to buy real estate. They keep the bathrooms clean, but it is hardly pure capitalism.
      • I drove a BMW X5 rental in Wisconsin two years ago which featured trademark icons for various gas stations and convenience stores in the navigation system, displayed on the map as the vehicle rolled down the freeway.
  12. I’ll be retiring soon. One of my post gm employment goals is to find some dope or dipwad dealer from the south or southwest to to take my 18 Z71 “modern” truck in trade for a “worn out” older truck. Before most people decide to do the same.
  13. If the cluster dies on you it’s easy to use the GPS in your phone or a Garmin to tell you how fast you’re going unfortunately that won’t tell you if the engine is overheating or let you turn on the car’s heater but least you’ll get home without getting a speeding ticket.
    Since everything goes through and is part of the CANBUS nowadays failure in one is in a failure in all. Better hope you’re radio doesn’t break or there goes your taillights. Progress…
    All that said, with the correct scan tool finding a failure in a modern car might be easier but unfortunately it might not be usable until you fix it.
  14. My mid-90s Chevy Lumina’s dash lights would randomly shut off. The check engine light would stay on (because it pretty much was always on), but no speedo, tach or fuel gage. They were still working just couldn’t see them. Very disconcerting on a dark highway. A few people in one of the Chevy newsgroups said it was the dimmer switch. Swapped it out ($150 IIRC), and everything was fine after. GM had some sort of microchip on the thing that must have had a bad batch or something.
  15. This is why I’m too terribly concerned about AI taking over the world. A simple discharge of static electricity can disable the most advanced computer these days. And you can’t run down to O’Reilly’sAdvanceAutoZone to get a replacement.
    I can see it now, the AI robots screaming, “Don’t taze me, Bro!”
  16. I just had to get a new computer. Financial institutions were rejecting my old one because its security was not up to date. The new computer wants my face photo and fingerprint for “ease of logging in”. Isn’t going to happen.
    • Hi Baby Killer,
      I still have my same old Apple IPad that I use for a few apps that I have (e.g. one grocery store, a few retail stores, etc.). The grocery store had logged me out and “recommended” that I use facial ID to log back in. Absolutely not. It let me log in without it, but that they even suggested it has me looking at alternative methods of shopping. I refuse to participate. The Mark of the Beast is here, but we must draw a line in the sand.
      • Ditto, RG!
        If I have to, I will grow beard and become Amish. This “mark of the beast” stuff is something I will not bend the knee to. I am not religious – but I know evil when I am faced with it.
        • It is going to be hard, because I think a lot of companies are going to implement it at the same time and this will leave a few people scrambling (looking for alternatives) and many willing to go along with it. The people that truly care about their privacy and refuse to participate (you, me, and probably many on this board) need to have our parallel economy already in place. It will be too late to try to implement one when this rolls out. And that is what will happen. One day we will wake up and find our banks, grocery stores, jobs, etc. have locked us out and the only one way to enter is to provide our biometric data.
          Have a plan in place now.
          • And what plan is that? Everyone is cagey, being vague and secretive about things, so when the curtain drops it’s going to be chaos because the resistance is disorganized and distracted arguing over the precise academic economic definitions. If you put 3 libertarians in a room you’re going to end up with two political parties.
            Gold? Silver? Cash? Brass?
            Who exactly do you think you’re trying to out think? The first thing they’re going to do is clamp down on exit ramps. FDR already paved the way for recalling all the gold. It’ll be for the children. You don’t want grandma to starve because you’re hoarding hard currencies, do you?
            Trade? Barter?
            Roving enforcement and walls with ears reporting to the American Stasi. Doors will be kicked down. They are already poisoning our land with geo-engineering. When they say “No home gardens” it’ll come with over flights of herbicide that will mean only GMO corn and soybeans from protected argi-businesses in your gruel.
            As the recent slaughter of the flock at Universal Ostrich Farms in B.C. proves the Stasi have no boundaries and no humanity. They will be relentless in their appointed duties.
            COVID was a test run. The next time won’t have the holes in the net.
            • This is my concern as well. COVID and Jan 6 showed their true colors. They also make an example of resistance groups attempting to organize and the lap dog media can’t wait to lead the news with “right wing extremism group corralled by the FBI”.
            • What plan is that, Karen? How about establishing relationships with your neighbors, your local farmers and fishermen, and other small businesses that have the ability to service and provide what the community will need? How about setting up watchful eyes that will be able to alert others when something is heard or seen? How about learning to can, setting up greenhouses, root cellars, and starting to stockpile now while one is able to do so. How about keeping your defense skills and shooting skills up to date? Loading up on ammo, cigarettes, and booze for trade and bartering?
              This country is almost 3.8 million square miles. Do you think they are going to take out 320 million of us through ChemTrails and poisoned water supplies?
              I guess for those that do not wish to prepare they can sit in a corner, suck their thumb, and cry how a bunch of narcissistic, coked up addicts, who have no idea how to cook or even wipe their own asses with assistance perpetuated a fear so deep and consuming that the majority of people quit before they even tried.
              • You’re parroting the talking points. Maybe you’re doing these things, I don’t know.
                What I do know is I grew up on a dairy farm in Weld County in Colorado. The family was being hemmed in by our neighbors selling out for homes and grandpa and dad could not afford to outbid developers for more land even if they wanted to grow. So my father made the decision to go straight to the consumer with raw milk. We did fine for a while but drip by drip extra rules (in Colorado you they change the rules so you couldn’t just buy direct from a dairy, you have to buy a cow share and be on paper an owner), more inspections and finally the property taxes did them in. When mom passed he offered to transfer the farm us kids. I was still in college but neither of brothers were in a position to run it full time either. So we had no choice but to cash out. Dad had taken loans on the equipment and there was a mortgage on a strip of land he bought in the 90s.
                We’ll be fine, we still have enough land to run our own livestock and converted one of the barns into a greenhouse. It’s now even more of an island, although we were already the only true farm left in Windsor. The house is still there but not occupied currently. Maybe one of us will move back in.
                This mythical “know your farmer” isn’t reality for most people. There’s a few boutique options, either farm direct or at markets. But it’s such a tiny fraction of food production.
                If you believe the USDA then here’s some numbers. There’s roughly 2,029,200 farms in the USA total. Of those 1,034,892 gross $10,000 or less annually. Our farm business was higher than this, so this number represents farms that are personal farms or hobbies and such. As far as I know the land we have left would count, it’s still zoned agriculture anyway. These farms surely are not for primary income and generally do not factor into national supply in volume.
                The next step is $10,000 to $350,000. The vast majority of family farms in the way you think of them fall here. There are 785,300 of them in the USA. Total annual production into the national supply is 21.3% of the supply. A lot of the cash crops are grow here, veggies, fruits, nuts, etc. A few ranchers would fall here but it’s doubtful a primary livestock operation would just based on the expense and feed requirements. Maybe small livestock operations that rely on BLM grazing do.
                That means the remaining 209,700 farms produce 78.7% of your food. This is the industrial agriculture. To further explain, the USDA calls 166,394 of these “family” farms and they probably are owned by a family corporation, but the family very likely doesn’t do much actual farming. They may run some small part of the operation but they own a lot of land they lease out. By volume these are corn, wheat, soybeans and decent sized ranch operations.
                So that means, when you boil it down, 42,613 farms in the country produce most of the food. In total these plus 36,526 of the family farms (in total 79,139 farms out of 2,029,200) manage to gross $1 million or more.
                So my point is that for a variety of reasons, mostly economic squeezing for a couple of generations, they’ve managed to consolidate the food production in the USA into the hands of a small number of people. Trying to buck the trend probably stressed my mom to death, we’ll never know. What you dazzling urbanites are asking is farmers to do the work for you, to be your insurance policy. They can’t do it and in larger numbers are deciding they don’t need the headache.
                • I am parroting what talking points, Karen? My own? Yes, I am very much doing these things.
                  Dazzling urbanites? LOL. I have never lived in a city. My paternal grandfather purchased a couple thousand acres in Central Virginia in the 1970s. I grew up on a beef farm. Although, my grandfather’s farm was a hobby and not an actual business. He was retired from the sheetmetal’s union and had enough time, energy, and funds to keep it going.
                  I am truly sorry to hear about the dissolving of the local farms in your area, including your family’s.
                  While, I appreciate the thorough research in your numbers nowhere in my post did I believe, or even mention, that local farmers should have the capability to feed 320 million Americans. This is impossible.
                  My post’s intention was that we prepare on a local scale. Statewide, or nationally is not feasible.
                  Do I have current relationships with local farmers. Yes, several in fact, but I also know I am extremely lucky in the area that I live in. I live in a region where weather does not evolve to the extremes (e.g. tornadoes, earthquakes, hurricanes, droughts, etc.) and remains pretty consistent throughout the seasons. I also am lucky to live in an area where a lot of people have the means to pay $10, $12, $15 a pound for hamburger meat. I just purchased a turkey for Thanksgiving from a local farmer who lives three miles from me. The turkey (27 pounds) was $220. Not everyone has the ability to afford this and several do not even have local farmers in their area. Our country is quite large and food deserts do exist.
                  My aim was that individuals work together I as a family, neighborhood, or community correlating resources and skills as a means of survival for the years ahead.
              • I grew up on a dairy farm in Weld County, Colorado. My grandpa bought the farm and ran it with my dad. Being one of the last farms near Windsor we were getting hemmed in so by the 2000s even if they wanted to grow they could not afford to outbid developers any longer. They moved to a raw milk, direct to consumer, which ended up not being financially viable. It’s difficult to sell direct to consumer in Colorado at any scale, especially raw milk which we hoped would widen margins (it doesn’t).
                If you want numbers, how about the USDA? They say there’s 2,029,200 farms in the USA. They say 1,034,892 gross $10,000 or less annually. These are hobby or personal farms, if they sell anything it’s at a small table at a farmer’s market. Maybe. They don’t even show up statistically in food production.
                The next category is $10,000 to $350,000. This encompasses 785,300 farms. Most family farms fall here, ours did. The USDA figures about 21.3% of national food prouction comes from them, at a total of 1,820,192 farms. The bulk of these are higher profit like vegetables, fruits, nuts.
                That means 209,700 farms provide 78.7% of the food in this country. Of them 166,394 are still classed as family farms, although this is mostly family farm corporations where the business is as much managing land leases and contractors doing the work. So to call them family farms is not what most people have in mind. That means 42,613 entities are not family controlled. If you further refine this you have 79,139 of these farms grossing $1 million or more. They are the bulk of food production.
                The family finally had no choice, we sold about 3/4 of the land to a developer. We still have the house, most of the buildings and enough land for our own livestock. But I think we’re like a lot of farmers at this point. The urbanites don’t understand the pressure to keep a farm going when the system is rigged against you. The mythical direct to farmer is going to feed a tiny number of people.
                My point is the production of food in this country is consolidated to the point that it isn’t hard to see how it’s easy to control. Farmers are cashing out, they’ll still farm but it’ll be for family and friends. We’re still a business on paper but we’re done with farmer’s markets for the time being.
                • Hi Karen,
                  I’m seeing this happen in my used-to-be-rural corner of SW Virginia. The small farms (100-150 acres) are selling to developers, who build huge “estate” homes on the land. This drives up the property taxes, pushing people who have normal-sized houses on 20 or so acres to sell, to the same developers. Before you know it, the place looks just like Fairfax County, which is where I grew up – and where there used to be farms, back in the ’70s.
              • Forgot to mention, the same USDA says the average farm is 443 acres and total acreage under production is 899,500,000 acres. Putting this in different numbers, it’s 1,405,468 square miles. The totality of the USA is 2,954,841 square miles. The land under farming does not include leases by the BLM for grazing.
                I’d also make the point that if there’s 330 million people in this country and 785,000 fully functioning farms that’s 420 people per farm. That’s not a picture of “know your farmer” ratio. We had 300 cow shares and served about 200 to 250 of them each week on 160 acres and we had routine feed purchasing. Managing milk pickup and the store was a full time job for mom and it was only open 4 days, which was a major reason we couldn’t keep it going when she passed. Neither of my brothers could do it, they had jobs and families. I was still in school so either drop out or close the store. And the reality is the actual number of farms like you’re thinking are probably half of that. There’s a lot of factory farms that grow commodities or feed stock for industrial livestock. They’re not going to be interested or equipped for direct sales. But they do control the majority of the land (and a lot of it is in the Midwest, so isn’t suited for a variety of crops, it’s large corn/wheat/beans and livestock operations). So figure about 500,000 farms and perhaps 25% of the land are going to be meet the requirements for this storybook system.
                • Hi Karen,
                  I very much appreciate your insights in re farming – and apologies for your post getting hung up in the Moderation queue. The site is under constant assault by spam and so we’ve had to be pretty aggressive with the filters. Thanks for bearing with!
            • Well, Karen, the gloves didn’t come off during the damn panic, but they were clearly becoming prepared to.
              If your ear is to the ground you can hear the herd becoming restless, to scramble a metaphor.
              Communism/Satanism are burned beyond salvage, the disarmed EU and Canada are the last gasps and they’ve cut their own throats and are bleeding out.
              When all is said and done individual, family, tribe, and clan are bottom up organizations, and national and internationa top down communist/democracy orgsl only work while the real units go along.
            • When they come to kick in my door they may not like what is on the other side. I will be going down like William Cooper as in not taken alive. You can only die once and will be on my terms.
          • You’re taking about Canaduh, Karin. What time is left should be spent educating people in the philosophy of Solzhenitsyn. Most people are beginning to realize the dark future the elites have planned for us. The chaos you speak of will be the time to unleash hell every form of institutional authority. If you aren’t able to do that, at least realize they hate you, and act accordingly when they begin rounding people up.
      • Apple mobile device processors and integrated memory packages have become so powerful that Apple will shortly introduce a sub $600 (rumored) laptop based on surplus components from a recent model year iPhone/iPad line, with performance numbers supposedly exceeding their first generation of “Apple Silicon” laptops from 2020.
        Apple wants to “wet their beak” in the segment currently dominated by Chrombooks, a surveilance state nightmare all their own.
        Capo Gecko’s largest single stock holding is Apple. Never forget.
      • Capo Gecko’s Nebraska Furniture Mart has a really nice Apple section in the Dallas store, with surprisingly low pressure sales minions which is somewhat unusual for that place.
