Home Classic Cars Underpowered, Under-Stressed and Over-Built
35
2467
The power made by today’s engines – especially the small ones – is inarguably impressive. Some – with the boost provided by a turbo – make as much or even more power than most of the V8s found in performance cars like the Mustang GT and even the Corvette back in the ’90s. The current Mustang GT’s standard 2.3 liter four makes 315 horsepower and 350 ft.-lbs. of torque.
To put that in some perspective, back in ’95 I got to drive the Cobra R, which was the last Mustang to come from the factory with the 5.8 liter V8 and this one was tuned for racing. It had a hot cam and headers – and made 300 horsepower. The Cobra R was also not mass-produced. Ford made just enough to qualify the car for SCCA road racing – and you had to have an SCCA road racing license to even be allowed to buy one. The car did not have AC – or even a radio. There were no back seats. It had lightweight body panels, no insulation and a fuel cell rather than a production car gas tank.
Today’s base four cylinder Mustang is more powerful – and quicker. It can do 0-60 in 4.5 seconds. It also comes with climate control AC, a great stereo and a back seat. But is it as tough? That little 2.3 four is under a lot of pressure. It is also made of aluminum. The last-of-the-351s (that’s what 5.8 liter translates as in good old cubic inches) had a cast iron block. Almost all new engines – regardless of configuration – have aluminum blocks. They are so light – about 100 pounds or so – that even a V8 engine block can be picked up and carried by a reasonably strong man. The weight savings is a boon to gas mileage, too – especially if aluminum cylinder heads are also used.
A cast iron V8 engine block typically weighs more than twice as much as an alloy block. Only a very strong man (such as a powerlifter)  can pick one up and carry it. The increased weight is a liability as far as gas mileage is concerned. But there are offsetting advantages. One is that it is harder to hurt a cast iron block.
Another is that cast iron doesn’t require sleeves or liners for the cylinders; just machining – and this machining can be done more than just once. A cast iron block can be bored out during the rebuilding process because there is enough material in the block to allow this. Most cast iron American V8s, for example, can be bored and rebuilt two or even three times.
Most aluminum blocks don’t have enough material to allow for boring. They can sometimes be re-sleeved – but that is a more complicated and so expensive process. (Some aluminum engines got around this via individually replaceable cylinders; the VW Beetle’s air-cooled four being an example.)
Cast iron, low compression and cubic inches are great for making a torquey, understressed engine that will probably last a very long time – assuming the basic design is sound and it is put together properly, with quality materials. It won’t make a lot of horsepower – and it will probably won’t return the best gas mileage – but longevity and durability are sometimes their own rewards. Engines used to be made that way pretty commonly. Perhaps one of the best examples is the Slant Six. This engine was used in various Chrysler/Jeep/Dodge/Plymouth models from 1959 – the year of its introduction – all the way through 1991. It was an engine that routinely outlasted the vehicles it was installed in, which often fell victim to rust before the engine finally called it quits or even got close to that point.
High compression is great for making more power, but it also increases the pressure (another way of saying the stress) within the engine. High compression engines also tend to run hotter, which increases the possibility of overheating. Turbocharged engines are like high compression engines in the sense that the boost increases cylinder pressure, which increases stress and heat. There is also the turbocharger itself, which gets very hot and spins very fast (internally). Turbos help a small engine make big power but they also cost big money to replace when they fail.
Regulatory compliance pressures have made small, turbocharged (and aluminum) engines common in transportation appliance cars. Before the increase in regulatory pressure, turbocharged engines were found almost exclusively in performance cars, as power adders rather than a way to compensate for the power lost by making engines smaller (often too small for the vehicle, absent the turbo boost) and small engines were found chiefly in small cars.
Power – and performance – are great when you need the power and enjoy the performance. But there is much to be said in favor of engines that were designed to be simple  that made enough power and for that reason often lasted a long time and didn’t cost much money to buy or to maintain.
It was a thing, once upon a time.
Our donate button is here
35 COMMENTS
  1. When I was 14, my dad bought his grandpa’s 1975 Dodge Dart for me to drive when I turned 16. It had a 225 ci slant 6. It easily handled this 16 year old’s abuse. I put that thing through the wringer, driving it like a hotrod, though it was about as far from a hotrod as you could get.
    Several years later, because I wanted a V8, I swapped the 225 for a 360, and the car was never reliable again. Got married and sold it a few years later.
    It shaped my life long love of Dodge vehicles.
  2. Eric,
    I don’t believe that the famed Slant-6 ever made it into any of the Jeep products.
    Of course, Jeep had their own ultra-reliable, inline 6: the trusty 4.0liter/242cid.
    And we can’t forget what was probably the best one of all: the mighty Ford 300cid inline 6.
    But your point is a good one. There is no way these new, small, highly stressed engines can match the durability of previous larger, far more sturdy engines. Particularly on 16 weight oil.
    • Roger that, Laconia17!
      Those old sixes were brilliant. There are many other examples. GM’s pushrod 3.8 V6, for instance. I get furious when I re-watch videos of those engines- made in the millions – being deliberately destroyed by pouring silica into them during Cash for Clunkers.
      • General Motor’s 3.8 liter ohv V6 certainly belongs in the pantheon of Great Engines. Powerful, utterly reliable, and durable.
        It is both mystifying, and infuriating, that GM can go from making one of the best engines ever, and definitely the best V6, the 3.8 ohv, to making one of the worst: the 3.0 liter OHC V6.
      • That rock-solid Buick 3.8 V6 was based on an earlier design intended for the first Buick Skylark (used the same body as the Chevy Corvair, Olds F-85, and Pontiac Tempest from 61-63) and was also sold to Jeep, just before AMC bought them. Very tough engine.
    • In the before times, the market and customers determined what sold and didn’t…
      In these collapsing times, the (((government))) mandates what can be sold and bought….
      Kind of like the mark of the beast, eh???
      YMMV…
  3. 1965 power wagon 4wd 4spd, 318 wide block W200
    Nickname = Blue Beast
    underpowered by today’s standards, yet still runs strong
    rebuild = piece of cake, parts dirt cheap
    bolt ready for a 225 slant 6
    sissors hinged hood = folds back to windshield = no removal for rebuild
    fenders = parts tray; also seat, can put feet into engine bay and rest/step on frame
    weight 4500 lbs
    HD winch 5/8″ cable = PTO shaft drive bolted to transfer case
    engine, transmission, transfer case = cast iron
    dashboard = painted metal still like new
    headlamps = (2) 8″ GE bulbs buy at Walmart for few bucks
    wiring = extremely simple, requires no book, no internet search, no specialty expertise
    alternator = can be easily rebuilt, twin pulley belt drive, long extension arm means many sizes of v-belts can fit
    transfer case = hd cast iron, twin levers on the floor
    MSRP = $2000
    current value = as is 5,000 to 100,000 restored
    longevity = forever
    crime = scrapping any truck like this
    liberals = hate it
    wood truck = one of the best ever made
    the truck will last lifetimes. even outlast the nation
    the only truck that beats it is a WM300
    https://www.vintagepowerwagons.com
    • >The only truck that beats it is a WM300
      Nearly bought one of those once, a long time ago.
      lifetime = “forever” as you have noted.
      Great choice if you are keeping it in the woods,
      but they were designed primarily for off road usage.
      Required removal of several bolts per wheel to engage/disengage front hubs.
      Since I needed on road/ off road capability, I opted for a ’60s ‘binder.
      Thrashed former government truck.
      IH 304 V8, 2bbl Holley, 2 speed transfer case.
      Paint job: spray can blue over government gray.
      Front bumper: W4x13 wide flange steel section
      A real stump puller. 🙂
      Previous owner had evidently run the rear differential dry.
      Could have shaved with the pinion gear – no land left.
      Rebuilt with new ring & pinion. All done, right?
      Wrong. One of the side gear shafts broke. Brittle, you see, from being run hot & dry.
      Second rebuild w/ ANP (All New Parts). Spicer, all parts in common w/ Fords of the same era, except different ring & pinion ratios. For a short while, I had (probably) the only front wheel drive PU around.
      But wait….there’s more.
      IH did *not* use left hand threads on the right front hub, only a flanged keeper ring.
      You guessed it. Flange broke, wheel fell off on a city street. Loads of fun sitting on the pavement with a jeweler’s file, repairing the damaged threads so the wheel could be remounted.
      Most hilarious incident was having it valet parked at the Five Crowns in Corona del Mar:
      https://www.lawrysonline.com/five-crowns/
      GF & I were on our way back from a rugby match in Del Mar (I played #7 for the Unicorns, at the time) & decided to stop off for a drink. Parking guy *did* have a sense of humor. 🙂
  4. Four valve heads, that woke up the traditional V Twin Harley Engine. The difference between the cammed and tuned but two valve 2004 Harley and bone stock 2018 four valve Harley was shocking. My third Harley and finally one that has excellent throttle response and gobs of power with no tweaks.
    I’d bet an old V8 with modern four valve heads and a throttle body injection system would be a dandy motor.
  5. Eric,
    FWIW, the original VW beetle (Kafer) had a magnesium, not aluminum, 2 piece case. The “jugs” (individual finned cylinders) were, of course, steel. So did the classic Porsche 911s.
    The VW cases were easily machined to fit oversized pistons and cylinders, nearly doubling the displacement in some cases.
    BMW used magnesium/aluminum composite construction in their classic N52 engine:
    https://en.wikipedia.org/wiki/BMW_N52
    which was the standard powerplant in U.S. market E90/E91 produced from 2006 through 2011. DOHC 24 valve straight six, w/ 10.7 compression ratio, it was he last normally aspirated BMW straight six. High compression ratio required 91 octane gasoline.
    I owned a 2006 E90, which I drove for several years before trading it for a 2013 F30 328i, which had an N20 4 cylinder turbocharged engine. Smooth as silk; nicest car I’ve ever driven. GF who lives in CT is still driving her 2011 E91, which she bought used. She is a licensed professional (PhD clinical psychologist) who could, very likely, buy a newer car if she chose to do so, but chooses to live frugally.
  6. You might want to explore why the use of aluminum in engines. It’s true that cast iron blocks and heads were bulletproof but manufacturers went to aluminum heads long before they really needed to for any compliance reasons. Not to mention so did race car builders and hot rodders.
    The reason is weight of course but it’s as much performance. Aluminum transfers heat better and in the case of heads that allowed higher compression and reduced detonation. Aluminum heads though presented a real reliability problem, Toyota having famously major ones with the 3.0L V6 blowing head gaskets. But even when there wasn’t a fundamental fault head gaskets on iron block/alloy head engines don’t last. In the old days of boat anchors you could expect a head gasket to last as long as the engine itself, replacing it only because you had to rebuild the engine due to worn rings, valve seats, etc. Going to an aluminum block helps with weight but it also helps with the block and heads again having similar heat expansion characteristics, helping with lifespan potentially.
    The ability to bore a cylinder is an economic question, there’s no reason other than cost to how thick the lining can be, it can be thick enough to allow some number of overbores. Another thing they’ve found using aluminum blocks for racing (this is common for the weight advantage) is they can sleeve the bores with exotic alloys of steel that are much harder than doing a cast iron block could ever allow. So it’s entirely possible to make a hybrid block that is lighter while conducting heat better and being much better wearing.
    The downside is cost, which for a production car is without doubt an important consideration. But even there some have found ways to coat the wear surface of the bores rather than using a liner sleeve, which makes them cost competitive.
    • Chevrolet tried not using a steel sleeve on their Vega four-banger and it turned out DISASTROUSLY. Aluminum simply doesn’t provide a suitable wear surface, I don’t care how many silicon nodules are in the casting matrix.
  7. I have a 2017 Mustang Pony with the Ecoboost. The turbo gets light use because I know how to drive quickly and efficiently with using the turbo much if at all. I am mindful of the issues stated here. My city driving is close to highway driving: point and drive with few stoplights. The car is being operated well within its limits. I am more worried about the wife with the AWD Escape with the 1.5 liter engine. She is not a fast driver but she punches the accelerator and the RPM do go above 3,000 often. The engine had been replaced at $28K due to a manufacturing defect. That car is being driven closer to its limits. I wonder whether this is all part of making it more difficult to be mobile
  8. Ah, yes. The old Slant Six. Great engines. I hated the location of the exhaust and intake manifolds on the same side, though. It was difficult to change the oil filter on a hot engine right underneath that exhaust manifold without burning your hand.
    The “overbuilt, under-stressed” design was true of the straight sixes from all the manufacturers, including Ford and GM. And it was also true of a number of four-cylinder rigs as well.
    I recently scrapped a rusted out second-gen Dakota with the AMC-designed 2.5 liter four, mostly used in Jeeps. Underpowered for sure but still ran like a Swiss watch when it went to the boneyard with over 200k on it.
    • I had a ‘75 Dodge Dart with the slant six, so much room in the engine compartment and all the components easily accessible but wasn’t fond of the oil filter being mounted upside down so that removing it would let the oil inside run down over the engine. Too bad the car itself rusted out after only about six years.
    • The Slant Six was originally designed to be just for the planned “A” body cars (Valiant, Lancer, later Dart, early Barracuda) in the 170 cube version. Not only was it first thought that’d be all the engine the new small car would need, but that the larger cars would be exclusively V8s, starting with the 318 “Poly”, or early “A” engine, which debuted in 1957. Dodge actually thought that truck buyers would, for basic pickups, be content with the venerable flathead six, in either 230 or 251 cube form, but once Ford introduced their OHV Six to replace both flathead inline sixes and the famous Flathead V8, they realized the Mopar flathead had run its course. THat’s when, in mid-1958, which just about year before the Valiant would debut (the Dodger Lancer followed in 1961), Mopar decided to make a larger Slant Six, which still used the same bore diameter, cylinder spacing, head, and accessories, the main differrent being a taller block, different crank, and different rods to accomadate a 1″ longer stroke. This made for a more “torquey”, but also slower-revving, undersquare engine, which was considered not a handicap for either trucks or, when installed as an “economy” engine on the larger cars. I saw a Freiberg video where he bought a 1960 Plymouth Belvedere (not the “B” body version, this was a full-sized car!) with the 225 Six and a push-button iron Torqueflite automatic. The car was as “Plain Jane” as even a Plymouth of that era could be, but it was clean and ran well, just not terribly fast! However, it was for a time, as “Uncle Tony” puts it, where most Americans motored in a “50 mph world”, that is, the Interstates we freely use today had yet to be built. So that old, underpowered Plymouth might get up to 70 mph on a level raod, and a good tailwind helps!
  9. 4 cylinder turbo engines:
    While the core engine block, pistons, and crankshaft
    can easily last 200,000 miles, supporting components
    will likely need replacement first. You should expect
    to replace the turbocharger itself, plastic coolant pipes,
    and various electronic sensors somewhere between
    120,000 and 150,000 miles
    long life requires never missing an oil change,
    use synthetic oil & After hard highway driving
    or towing, let the engine idle for 1–2 minutes
    before turning it off. This keeps oil flowing
    to cool down the glowing-hot turbocharger.
  10. The old Ford 300 6 cylinder engines would idle all night through the winter, making a pleasant whirring sound that would lull the night watchman to sleep on the F series bench seat. When it was time to turn them in after many years of service they were driven to their final destination. So much has been lost.
    • My 1989 F150, bought new for cash in 1989, is still my daily driver.
      Got 240,000 (25 years) out of the original 300 C.I.D. straight six. About 70,000 so far on the remanufactured NAPA replacement. Original Borg-Warner T-18. Full synchromesh means I hardly ever use the clutch.
      Aftermarket paint job is clear coat over metallic, far superior appearance to factory single coat baked enamel. Ford forever.
  11. Nissan installed its KA24DE 2.4-liter four in first-gen Frontier pickups. I’ve got one, and believe Eric does too.
    Reportedly the KA24DE has been jacked to as much as 500 horsepower without self-destructing. The block, crankshaft and bearings are designed to take it.
    No, I’m not gonna try it. The Fronty’s primitive, farm-wagon suspension can’t even handle the puny power the KA24DE produces in stock configuration. Now if it were installed in a Z-car, it might be a different story. Vroom, vroom!
    • Hi Jim!
      Yup, I have one – in my ’02 Frontier. After I get done with some “little things” the TA still needs, I am going to try to remove the factory exhaust manifold, which as you know houses the primary catastrophic converter. My truck is almost 25 years old now and I expect the converter is at least partially clogged. If I can get the old manifold off – without breaking off studs – I will replace it with a tube header and I bet that’s worth 5 horsepower, at least!
      • I put a header on my Toyota 22R and went back to a manifold. You’re being tongue-in-cheek about the power (didn’t really notice) but what I did notice is the serious increase in under hood temps, particularly in this case where the exhaust runs under the firewall and floor on the driver’s side. It made the cab quite a bit hotter, especially right under the dead pedal where I ended up resting my foot mostly. The only reason I’d go back to it is if (when) the manifold cracks, they are nearly impossible to weld or braze and have it hold. YMMV
      • It will probably add a little horsepower, but the bigger deal is the engine FEELS stronger across the powerband. I like em but quit using headers years ago because they do add heat to the engine room (wraps help this) and they always seem to leak either at the head or the collector.
        I’ve had good luck getting rid of the cats in various ways and doing good correctly sized pipes downstream with big crossovers on the duals. Breathing is similar and the sound is great.
  12. That must be a Dodge pickup with a Slant 6. It probably has a three-on-the-tree. What a great engine.
    It looks like it has no power steering, no AC, and not even power brakes. I certainly would not want to drive it across the US in summer even it had wing vents and was geared to cruise at 60mph.
  13. I had a 225 slant six with an overdrive 4 speed in my 1980’s Dodge pickup. It got around 18 1/2 miles to the gallon year round. Slow as f*ck but dependable. I miss it.
    • “with an overdrive 4 speed in my 1980’s Dodge pickup.”
      Did Dodge ever have the overdrive as an option? Wiki implies it was a 3sp with a high ration 4th gear.
      https://en.wikipedia.org/wiki/Dodge_D_series
      “For 1976, the D/W series saw several mechanical changes: the frame-mounted fuel tank was raised, Sweptline boxes received enhanced corrosion protection, and a glide-out spare tire carrier became available. The rear suspension was revised for added stability under heavy loads, and 4WD models featured raised tie rods for higher ground clearance. Bench seats were modified with hinges for easier access to the rear of the cab. For models up to 5,500 pounds GVWR, a four-speed manual overdrive transmission was introduced with the slant-six for improved fuel economy. “
      • It had an A883 4 speed with overdrive if I remember correctly but I don’t know if it was original to the truck or added afterwards.
        • Jeep Gladiators used a separate solenoid activated Borg Warner Overdrive so they had in effect 5 speeds. This is what I would classify as a “4sp overdrive”. These used the arguable superior Tornado OHC 6
          https://en.wikipedia.org/wiki/Jeep_Tornado_engine
          https://hermtheoverdriveguy.com/overdrive-types-2
          The 883 was 4sp:
          https://www.junkyardmob.com/misc/mopar-a-833-transmission/
          “The most significant change to the Mopar A833 transmission occurred in 1975 when it received an aluminum case and added an overdrive gear (the third gear ratio was reduced to .73:1 so that it could be used as an overdrive, and the fourth gear became the new third gear). The changes increased the A833’s usage, as fuel economy became a concern for the buying public (having just gone through an oil embargo).”
          The incredibly poor english aside this was a 4sp with 4th being “overdriven” with a high gear ratio.
        • The gear ratios were a true O/D, but that was so, for A and F-body cars with the 4-speed manual, or trucks, a “lower” axle, like 3.23:1, could be used to help with hills and acceleration from a dead stop. The long-standing “Three on the Tree” was also going out of favor, even in pickups with a bench seat, by then.
