Home Features Slate Ain’t a’ Goin’ No Damned Where
44
You may remember when the Toothless Hillbilly said that to Ned Beatty in Deliverance. And then what happened next. That’s essentially what’s going to happen to people who buy the Slate electric truck, which “estimates” claim will have a fully charged driving range of 205 miles. Since the truck isn’t actually available yet, those “estimates” might be optimistic.  Even if they are accurate, the Slate truck’s fully charged driving would be akin to the driving range of a Ford Maverick hybrid with its tank about two-thirds empty.
The Maverick hybrid carries 14 gallons and that’s fuel enough to keep it rolling for about 580 miles in “city” driving and about 480 miles on the highway. Put another way, about 4 gallons of gas is sufficient to give a Maverick hybrid about the same driving range as the “estimated” range of the not-yet-available Slate – which Slate says will be priced at about $25 to start. That would make it about $3,200 less to buy than a Maverick hybrid, which lists for $28,145 to start.
Such a deal!
Well, it kind of is as regards the Maverick – which is a practical little hybrid with truck-ish features, most notably its truck-ish bed. It isn’t actually a truck – if “truck” is defined as a vehicle with more than just a bed. Trucks are commonly understood to be vehicles that are more ruggedly built than cars (and crossovers), typically with ladder-style frames onto which a body (and bed) are bolted, with the engine installed front-to-back rather than side-to-side and primarily driving the rear wheels. There is typically a driver-selectable (sometimes, automatic) four-wheel-drive system available and sometimes standard; this is not the same as all-wheel-drive – which is a feature the Maverick (and many other crossovers) offer. Both turn all four wheels when engaged, but 4WD usually routes all of the power to the rear rather than the front wheels and there is also usually a two-speed transfer case and 4WD Low range (some AWD crossovers imitate this function via a gear-reduction feature but it’s not quite the same thing; the chief difference being it’s not as heavy duty and not designed for the hard-slogging trucks are expected to be able to handle).
Anyhow, while the Maverick hybrid isn’t exactly a truck, it’s useful as a “truck” in the everyday way many people use trucks. You can fill the bed with groceries, mulch, a couple of dirt bikes or a wet dog. It is better in the snow (on paved roads) than most cars and crossovers because it sits a little bit higher off the ground (clearance is as important as having AWD – or 4WD – if you want to avoid getting stuck in the snow).
The big thing, though, is that you can use it.
The Slate not so much. Literally. If the “estimates” are accurate, the short-leash driving range limits the usefulness of this vehicle in a way that’s similar to the limit imposed by the 25 MPH maximum speed that limits the usefulness of the Scion (Toyota) KEI-001 in that what’s the use of a vehicle that can’t realistically be driven on most roads – or very far on them? The Slate can go faster than 25 MPH but the faster it goes, the faster its range goes. This is true of all EVs, which lose range (charge ) faster the faster they are driven.
A paradox, isn’t it?
EVs get their best driving range when they are not moving at all – or not very fast. That works ok when you are stuck in stop-and-go “city” traffic – and the Slate could be useful in that context. But its usefulness plummets once traffic eases up and maybe you need to be able to drive farther than the thing can go on the gasoline equivalent of about 4 gallons of gas.
Sure, of course – you can always recharge the battery, but that means having to stop and wait for it. Meanwhile, the Maverick hybrid continues to be useful and not wasteful of your time.
How much is that worth?
Well, about $3,200 – if you want to put a number on it. That’s the price you pay (vs. the Slate) to not have to stop and wait after every short-leash drive. Factored over the average six year new car loan, it works out to about $45 more per month to not have to be leashed.
The Slate – like the KEI-001 is cute and both could be useful as “city” vehicles if they were priced accordingly. The KEI-001 could be – because it is, just not here. In Japan, these things are available for about $12k to start – and they’re also not limited to 25 MPH. Here, the limited iteration will apparently list for $22k, which makes the $25k Slate – which isn’t speed limited – seem pretty useful. But then the comparison shifts over to vs. the very useful Maverick, which costs about $45 more per month to buy.
The big point to make, though is that only reason the Slate is so expensive is because of its battery. Take away the electric drivetrain and put a small engine in the thing and this little truck could probably be sold for $15k and it’d be useful, too.
That would likely sell.
This battery-powered Slate? It ain’t a goin no damned where.
Literally as well as figuratively.
