Sports cars are supposed to come with manual transmissions. America’s Sports Car – the Chevy Corvette – has not even offered one as an options since it was redesigned to a mid-engined layout back in 2020. It became something other than a sports car at that point, arguably.
Yes, it’s true – the automatic shifts quicker and all that. It is beside the point. If, at any rate, we are talking about sports cars. An automatic-only car can never be one – just as an electric “muscle car” is an absurdity, no matter how quickly it runs the quarter mile.
But there is good news – kinda sorta – if you are wanting a Corvette made since 2020 with a manual transmission. Tremec – which makes great ones – is reportedly going to make one that will bolt into a 2020-up Corvette. It is technically a transaxle, since the current Corvette is a mid-engined car. But the point is it will be a manual and it will physically fit – and it will be able to handle as much as 1,000 horsepower and 800 ft.-lbs. of torque.
But will it electronically fit?
The 2020-up Corvette is programmed for the automatic it comes with. It is not programmed for a manual, which means – absent a reprogramming – Tremec’s manual probably won’t work even if it physically fits. More finely, the rest of the Corvette’s drivetrain and related systems (which includes pretty much everything) won’t work. The data the ECU – the big computer that runs the drivetrain – gets from the automatic won’t be sent and that would likely cause many “codes” to be “thrown.” Some of these will probably be related to the car’s emissions control systems. Remember: The main reason the Corvette – like so many other cars – has gone automatic-only is Because Compliance. It is much easier to program the shifting of an automatic and thereby fine-tune emissions; a manual is shifted by an erratic human and this affects emissions – and that can affect compliance.
No doubt there are also issues as regards warranty coverage, too.
To Hell with all that – as Arnold used to say (before he said Screw your freedoms).
It used to be so much easier. I could convert my ’76 Trans-Am to a manual in a weekend because there are no electronic issues to sort. It is a simple matter of bolting up the parts. In part because my car was originally available with a manual, so the parts are readily available. (I have most of them already standing by; the big one is the Super T10 four speed, which isn’t cheap and that’s why my car still has an automatic.)
But the main thing that makes it easy is that the rest of the drivetrain in my pre-computer-controlled car does not care whether there’s an automatic or a manual bolted to the rear of the engine. The carburetor doesn’t have to be altered, let alone changed. All that needs to be done is to disconnect and throw away the kickdown linkage for the automatic. The rest is just a matter of bolting up the manual flywheel, bellhousing, pressure plate and clutch. Plus of course the new pedals.
This kind of swap was also possible (and just as easy) with pre-computer-controlled Corvettes, too.
People sometimes talk about “plug and play” – but with electronically controlled cars, it is often anything but that. It is often necessary to “pair” a new part – a stock replacement part – with the car’s computer. A non-stock part may not be recognized by the computer and may not work – even if it ought to work, in the sense that everything bolted right up.
Put another way, new cars are designed to be what they are rather than what you might want them to be. This is getting to be much more fine-tuned, by the way, than as regards major changes such as replacing a factory automatic with a manual.
Factory-installed audio systems are now part of the rest of the car’s systems, too. That is to say, they are no longer easily removed and replaced because they are integrated with the “infotainment” screen, which is the control interface for other vehicle systems (such as the climate controls, in many instances) and the LCD screen is a proprietary thing, meaning the aftermarket isn’t (legally) allowed to offer replacements unless they are “authorized.”
You might be able to physically install a new audio system, but whether it will actually work is another thing. Also whether the vehicle’s other systems will work.
So, while it’s nice that Tremec is working on making the part available – one that will physically fit the new Corvette – whether it will actually work remains to be seen.
I can’t imagine Tremec would invest the time into making the part without taking the electronic rigmarole into account.
The idea of making this car controllable using a manual sounds very sweet. No matter how well and automatic can shift, it’s just not the same as being able to use engine braking to pitch the car and choosing the right gear for what’s coming up. Also, the physical interaction with the machine is unique to each vehicle. Upshifts are fine but, downshifts are where the fun is.
I converted an automatic VW TDI drivetrain into a manual. This was as part of swapping a 1.9L TDI into an old Toyota truck, so it was now mated to a Toyota 5 speed. The engine needed the ECU and it needs to pass smog.
It’s not that hard to deal with an ECU, which in my case just required finding a donor ECU, replacing variables (yes, you need a OBD cable and software, all in that was $200) to make it match my VIN and make the emissions nazis happy.
Since Tremec is an OEM and supplies drivetrain ECUs for new cars I assume part of the kit will be either a replacement drivetrain controller or a re-programming service for yours.
It’s not magic, lots of companies offer ECU changes and many are completely above board and even have Fed and California’s CARB-EO approval documentation.
https://www.sema.org/news-media/magazine/2022/04/sema-announces-first-ever-emissions-certification-program
One I’m familiar with is Overland Tailor Tuning. They make engine and transmission (automatic in this case) changes that primarily are intended to enhance driveability. It tightens up shift patterns, changes fuel map a bit.
It’s got a CARB number so people in all 50 States can use it without failing emissions visual or diagnostic checks. This includes trucks 2016 to 2023, so not old ones by any stretch.
https://overlandtailor.com/faqs/#collapse-e25047d690df8c5d0397
It would def pass visual at the local Oregon deq sttion I used to use. Some of the workers there actually help edgy cars pass. . .
Some.
Skip the 4-speed Eric, go for a TKO 600 with an overdrive.
Hi Enemy,
My buddy Tim the mechanic says the same! However, I really like the Super T10. I have owned other Trans-Ams with this transmission; the gear whine is fantastic! I know it’s not got an overdrive but I don’t care because I only drive the car around my local backcountry roads. Highway legs are an irrelevance for me.
Aftermarket transmissions and gearing are specialized and expensive. I would be willing to bet a lot that Tremec will offer/include a programming flash to make it work, though it will likely be an “off road use” item.
These things work really well, tuning and deleting a modern diesel is easy and very effective. But it’s expensive, and I just don’t get the satisfaction I do from mechanical tinkering.
I see little difficulty fooling the ecu by combining three pair of 9 closest ratio auto gears into 6 usable feedback words to ecu. IF the coding language is known AND some idiot greentard engineer hasnt specifically flagged such changes as no go at a deeper firmware level.
‘the rest of the drivetrain in my pre-computer-controlled car does not care whether there’s an automatic or a manual’ — eric
This is also known as ‘robustness.’ A fault, if one occurs, does not propagate catastrophically in cascade fashion — as occurred recently when Amazon Web Services cloud servers glitched, and a wide swath of communications services were disrupted.
If a breaker trips in your electrical panel at home, the other circuits aren’t affected. Whereas if GM’s ‘gratuitous over-tech’ iPhone fanboys designed it, one ground fault would darken the whole house, shut off the water, lock the doors, and notify
OnStar911.Isolating computer-controlled subsystems from each other is critical for reliability. Auto makers and anti-car fedgov regulators don’t care. They just want cars to disappear, and then us as well.
Maybe Tremec is going to make it or say they are going to make it so they can sell it to GM?
Just for you Eric
https://www.youtube.com/shorts/nxVAterx9C8
Another point to consider is if you live in a state with emissions testing they might fail it because you put in a manual transmission whether the check engine light is on or not. For that reason I suspect this tranny will not be getting CARB certification any time soon.
Perhaps this tranny will be sold for track use only and it will be on you if you drive it on the street which would severely limit sales making it not financially viable. Nice if it happens but unlikely to happen in today’s regulatory climate.
If that becomes the case, you keep all of the original parts and bolt everything back up before going in for a smog check.
But in my state, they just check your gas cap (if you have one), check the computer for codes, and send you on your way. And this is once every other year.
Some states on the west coast are much more stringent and have check stations out on the highway, but that is pretty much just in/near major cities.
