Home Features 2026 Infiniti QX60
2026 Infiniti QX60
8
3724
Now that every “car” company sells mostly crossovers, how do you get the crossover you’re hoping to sell to stand out from the crowd? One of the ways Infiniti has come up with is to offer a crossover that has an engine that’s different than the engine you’ll find in any other crossover.
A variable compression engine.
Normally, an engine has a mechanically set compression ratio, determined by piston shape and combustion chamber volume. High-compression engines make more power, but they generally require high-octane gas (to avoid premature combustion caused by the high compression; high octane gas is more resistant to premature combustion, which manifests as engine knock – and eventually, big repair bills). Low compression engines can burn regular unleaded safely, but they’re not as powerful or responsive – because the explosion within the cylinders ins’t as powerful.
Infiniti – Nissan’s luxury division – figured out a way to combine high-and-low-compression in one engine. The Variable Compression (VC) engine.
The QX60 comes standard with this engine, which can be powerful when power is needed and more efficient when more efficiency is wanted.
On the other hand, the QX60 isn’t available with the 3.5 liter V6 engine that it used to come standard with – and which is still standard in its much-less-expensive Nissan-badged sibling, the Pathfinder.
The QX60 is a mid-sized, three row luxury crossover that’s related to the Nissan Pathfinder. It features the variable compression engine mentioned above as well as features and amenities that are not available in the Pathfinder, such as a 20 speaker Klipsch premium audio system, quilted leather dashpad/trim and ProPilot Assist, which bundles adaptive cruise control and a Blind Spot Intervention system that steers the vehicle back into its travel lane if you try to change lanes while there’s another vehicle in your blind spot.
Another big difference is the price.
The QX60 starts at $51,590 for the pure trim, with FWD ($53,600 with the optional AWD system) vs. $37,500 for the base Pathfinder, which also comes standard with a V6 that’s more powerful than the QX60’s 2.0 liter variable compression four. But the QX – being an Infiniti rather than a Nissan – does come standard with three-zone climate control, 20-inch wheels, a panorama sunroof, a digital main gauge cluster (and 12.3 inch secondary touchscreen) as well as a heated steering wheel, power rear liftgate and wireless phone charge pad.
The $56,900 QX60 Lux ($59,000 with AWD) gets roof rails, heated second row seats, ventilated front seats and a 16 speaker Klipsch audio system.
The $62,190 Sport trim comes with AWD standard as well as second row captain’s chairs and a removable second row center console, plus special five-spoke, 20-inch wheels and dark chrome exterior trim.
A top-of-the-line Autograph QX60 also comes with AWD and upgrades to a 20 speaker Klipsch audio system, plus adaptive headlights that turn in the curves, a heads-up display (HUD), the quilted leather trim/upholstery upgrades, massaging front seats, a household 115v power outlet and a towing package that includes a transmission oil cooler and trailer sway assist.
Properly equipped, the QX60 can tow up to 6,000 lbs. – which is about 1,000 lbs. more than most same-sized crossovers are rated to pull.
What’s New For 2026
In addition to a revised front clip with a new-design grill (with an illuminated “Infiniti” badge) all trims now come standard with 20 inch wheels and the Autograph trim gets a new puddle lamp system that comes on automatically as you approach the vehicle, projecting “Infiniti” on the ground on both sides of the vehicle.
Handsome outside and plush inside; a cut above its merely Nissan-badged sibling, the Pathfinder.
Variable compression engine develops a pleasant swell of low-and-mid-range torque, making the QX60 feel responsive without having to floor the accelerator pedal.
Can tow almost as much as some truck-based SUVs.
About $14k more expensive to start than the closely related Pathfinder – which comes standard with a V6.
Variable compression four sounds tinny when pressed.
Pure and Lux trims are not available with captain’s chairs.
Usually, when you have a luxury and a mass-market version of the same basic vehicle, it’s the luxury badged version that gets the bigger/stronger engine. For example, the Cadillac Escalade comes standard with a 6.2 liter, 420 horsepower V8 while the closely related but merely Chevrolet Tahoe comes standard with a smaller, not-as-powerful 5.3 liter V8.
The QX60 comes standard with a 2.0 liter four that touts 268 horsepower while the closely related Nissan Pathfinder still comes standard with a 284 horsepower 3.5 liter V6. This engine used to be standard in the QX60, too. It was replaced last year (2025) by the new variable compression (VC) four, which has a crankshaft/connecting rod system that allows the compression ratio to be adjusted continuously, in accordance with the driver’s expressed demand for more power. More pressure on the accelerator pedal increases the engine’s compression ratio (by increasing or decreasing the stroke of each of the four pistons as they travel up and down within the cylinders) and the power/responsiveness of the engine. When the pressure is eased, cylinder compression is reduced. The system works in conjunction with a turbo, with the idea being to provide on-demand power and sharper throttle response and maximum efficiency. The system is capable of varying compression from as low as 8:1 to as high as 14:1.
In theory, this ought to dramatically increase gas mileage – but in this case, there’s very little actual difference between the Infiniti’s 22 city/28 highway and the V6-powered Pathfinder’s 21 city, 27 highway. This isn’t so much the fault of the VC engine as it is a consequence of the weight of the QX60 – which is a beefy 4,671 lbs. That’s a lot for any engine to lug around but especially a small, four cylinder engine. Because the QX60 is so heavy, the little engine is running at high CR (and boost) most of the time it’s moving. The Pathfinder’s V6 doesn’t need to work as hard to move the same weight, which is why – paradoxically as it may seem – the much larger engine hardly uses more gas than the much smaller engine.
Both engines are paired with a nine speed automatic and either FWD or AWD, depending on the trim and whether you elect to buy the AWD system.
The QX60 has a noticeably different driving demeanor relative to the Pathfinder. This has its good and its bad points.
On the good side of the ledger, the VC four feels stronger than the old V6. It takes less downward pressure on the accelerator pedal to elicit a lively response from the engine; sometimes, you’ll skitter the front tires (FWD models) if you push down a bit too hard. This imparts some real driving fun, if you’re into that kind of fun – and if you’re not, the important thing is the VC engine responds authoritatively, which is a quality that people spending $50k-plus on a luxury-badged vehicle expect to get for their money.
On the bad side of the ledger, the VC engine sounds tinny when pressed. This is, arguably, the big problem with these small engines that have become increasingly common in large (and heavy) luxury vehicles such as the QX60. They are not size (and weight) appropriate.
Or price-appropriate, for that matter.
Put another way, there is something incongruent about a $50k-plus luxury-badged vehicle like this Infiniti that has a smaller engine than its $37k Nissan-badged sibling and also one that’s about the same size as the engines found in much smaller vehicles, which is where such engines used to be found exclusively. This VC engine would shine much brighter in a smaller vehicle that weighed 1,500 pounds less than the QX60 does; it’d probably be capable of returning close to 40 MPG in such a vehicle while also delivering much better performance than the QX60’s 7.5 seconds to 60. That’s not a bad number, by the way. It’s just not an impressive one. The same can be said about the QX60’s gas mileage numbers. They are not terrible; but they are also not meaningfully better than the V6 Pathfinder’s.
One – or the other – ought to be.
Infiniti probably ought to have pumped up the power – and the performance. Because (a) people who are interested in $50k-plus Infinitis like the QX60 are unlikely going to be worried much about spending a little more on gas than the people who buy $37k Pathfinders and (b) because $50k-plus Infinitis ought to perform noticeably better than $37k Nissans.
Other than that, the QX60 delivers the overall experience it ought to. It is noticeably quieter (excepting the tinniness of the engine at full throttle) than its Pathfinder sibling and more comfortable, too. The seats are wonderful; you can feel your buns even after three hours of straight driving – and the available 20 speaker Klipsch audio system is exceptional as well as unusual in that a majority of luxury vehicles use Bose as their audio system provider; Bose makes good stereos, too. But the Klipsch system is really good. So also the available massage feature for the front seats.
If you didn’t know it, you might not be able to tell the QX60 and the Pathfinder are closely related. The latter has been styled to look like a 4WD SUV it isn’t while the QX60 looks like the luxury crossover it is.
It’s handsome – not obstreperous. Inside, it’s sumptuous – especially the top-of-the-line Autograph trim.
Both of these mid-sized fraternal twins are about the same size – the Infiniti is 198.1 inches long overall while the Nissan is 197.7 inches long – and both have comparable room inside for people and cargo, though the Nissan has a bit more of the latter: 16.6 cubic feet behind its third row and 80.5 cubic feet with the third and second row folded vs. 14.5 cubic feet behind the Q’s third row and 75.4 cubic feet all told. The reason why is the Infiniti’s second row has more legroom – 37.7 inches vs. 35.5 inches in the Pathfinder. This makes perfect sense given the QX60 is designed to be primarily a luxurious passenger-carrying vehicle while the Pathfinder is meant to be a more practical, family-oriented vehicle.
The QX60 has an interestingly different control pad for  the seat heaters (and coolers) as well as the HVAC system’s fan speed. It looks like a flat sheet of tap/swipe LCD but it’s pressure sensitive, so you can feel something – feedback – when you press down. The seat heaters/coolers have three settings – High, Medium and Low – and each is engaged by a gentle and intuitive finger push. This system is operationally superior to the feedback-free tap/swipe inputs found in many other premium vehicles that require you to look to see what the result is of your tapping/swiping.
Theres’ nothing fussy or annoying about this Infiniti – which is exactly as it ought to be.
As mentioned earlier, the QX60 – being an Infiniti – comes with more luxury amenities than the Pathfinder, which you’d expect given the price difference. That brings up the more relevant difference – which is the Infiniti’s price vs. the prices of luxury-badged rivals such as the Audi Q7 ($62,000 to start) and the Volvo XC90 ($61,050). Relative to those rivals, the QX60 is a smokin’ good deal, especially since you could get a top-of-the-line Autograph trim and not pay much more for it than the base trim Q7 and XC90 cost.
All that’s missing is a little more power. Or a bigger engine.
8 COMMENTS
  1. No hybrid powertrain option, no sale.
    Turbos still don’t last very long…*cough*…EcoBoost…*cough* versus NA engines.
  2. Just another compliance engine that will not be reliable at all.
    I want our higher displacement NA engines back with none of the BS, cylinder deactivation, etc…
  3. The idea of a car weighing 4,671 lbs and powered by a 4 cylinder engine, no matter how advanced it is will likely end in it needing a replacement engine a few years after the warranty runs out.
    As for the front end styling? Finally a grill that makes the Edsel grill look like a thing of beauty.
