If you’ve been driving a diesel long enough, you already know the EGR cooler is one of the most failure-prone components on any modern emissions-equipped truck. Whether you’re running a 6.7 Cummins, a 6.6 Duramax LML, or anything in between, the question isn’t if your EGR cooler will give you problems — it’s when.
And when that day comes, you’ll face a choice that a lot of diesel owners get wrong: do you replace the cooler and keep the EGR system intact, or do you delete it for good?
This guide breaks down both options with real numbers, real trade-offs, and no fluff.
What the EGR System Actually Does and Why It Fails
The Exhaust Gas Recirculation system routes a portion of your exhaust gases back into the intake manifold to lower combustion temperatures and reduce NOx emissions. In theory, it’s a clever emissions compliance trick. In practice, it introduces hot, soot-laden exhaust into a cooling circuit that was never designed to handle it long-term.
The EGR cooler is the component that chills those exhaust gases before they re-enter the intake. Over time, carbon deposits build up inside the cooler passages, coolant passages crack from thermal cycling, and you end up with one of two failure modes:
- External coolant leak: You’ll see white smoke and a dropping coolant level
- Internal failure: Coolant enters the intake, mixes with oil, and if you’re unlucky, causes hydrolocking
On the 6.6 Duramax LML, internal EGR cooler failure has been documented extensively in forums. On the 6.7 Cummins, cooler cracks combined with carbon-choked EGR valves are a well-worn story. Neither failure is cheap, and neither is a one-time event. Replace it once, and the same failure mechanism is still in place.
EGR Cooler Replacement: What It Costs and What You Get
A straight OEM EGR cooler replacement on a 6.7 Cummins runs $400–$700 for the part alone. Labor at a shop typically adds another $300–$600 depending on your truck year and access difficulty. Aftermarket coolers are cheaper upfront but often use the same design as the part that failed.
Here’s the real problem: you’re fixing the symptom, not the root cause. The same soot accumulation, the same thermal cycling, and the same failure mode will return, often within 50,000 to 80,000 miles on a high-use truck. Many owners who’ve gone the replacement route report doing it two or three times before finally pulling the trigger on a delete.
That’s $1,500 to $3,000+ in repairs before you’ve solved anything.
EGR Delete: What It Actually Involves
An EGR delete removes the EGR system from the loop entirely. On a properly executed build, this means installing a delete kit that blocks off the EGR ports, eliminates the cooler from the coolant circuit, and requires a corresponding ECM tune to prevent fault codes and ensure the engine management system runs correctly without EGR input.
The delete is typically an off-road use application, something that’s done on trucks used for towing on private land, competitive pulling, farm use, or track-day builds where emissions compliance isn’t a requirement.
Done right, the results are consistent:
- Intake temperatures drop significantly: There is no more hot, sooty exhaust recirculating into the intake.
- Coolant system runs cleaner and cooler: The EGR cooler is no longer acting as a stress point.
- Engine response sharpens: This is particularly noticeable at lower RPMs where EGR interference is most prominent.
- Long-term reliability improves: You have eliminated a known failure point entirely.
For Cummins owners, a quality 6.7 Cummins EGR delete kit paired with a proper ECM tune is one of the most cost-effective reliability upgrades available for that platform. The upfront cost is typically comparable to a single EGR cooler replacement, but you don’t repeat it every 60,000 miles.
Cummins vs. Duramax: Platform-Specific Considerations
6.7 Cummins (2007.5–present)
The 6.7 runs a relatively accessible EGR layout, and the market for delete components is mature. Parts availability is strong, and tuning support is well-established. The EGR cooler on these trucks is a repeat failure point, particularly on higher-mileage examples. Owners running the truck hard see accelerated cooler degradation. A full Cummins EGR delete setup removes the cooler entirely from the equation and brings intake temps back in line.
5.9 Cummins (1998.5–2007)
The 5.9L ISB is in a different situation. Earlier generations ran without DPF systems and with simpler EGR configurations. For owners of these trucks, the conversation shifts more toward full emissions system delete to maximize the platform’s well-known longevity. The 5.9 already has a reputation for 400,000–500,000-mile engine life; removing emissions hardware that was bolted on late in the model run is often part of preserving that reliability. Quality 5.9 Cummins delete parts are widely available and the tuning ecosystem is mature.
6.6 Duramax LML (2011–2016)
The LML is arguably the most problematic Duramax from an emissions-system reliability standpoint. It runs both EGR and a Diesel Particulate Filter, and the two systems interact in ways that accelerate failure in both directions. EGR soot loads up the DPF faster, and DPF regeneration cycles stress the EGR cooler. Owners dealing with this combination are often better served by a full Duramax delete kit that addresses both systems together rather than chasing individual component failures.
The Cost Comparison That Actually Matters
| Approach | Upfront Cost | Expected Repeat Interval | 5-Year Total (Estimate) |
| OEM EGR Cooler Replacement | $700–$1,300 (parts + labor) | 50,000–80,000 miles | $2,100–$3,900+ |
| Aftermarket Cooler Replacement | $400–$900 | 40,000–70,000 miles | $1,600–$3,600+ |
| EGR Delete Kit + Tune | $500–$900 | One-time (off-road use) | $500–$900 |
The math is straightforward for any truck that sees significant annual mileage. The delete isn’t the expensive option — repeat EGR cooler replacements are.
What to Look for in a Delete Kit
Not all delete kits are equal. The components that matter most:
- Billet aluminum block-off plates over stamped steel: They hold up better to thermal cycling and don’t warp
- Coolant reroute kit included: This is critical for pulling the EGR cooler out of the coolant loop cleanly
- Matching ECM tune support: The delete kit alone doesn’t eliminate fault codes; the tune is what makes the truck run correctly
For Cummins owners specifically, the aftermarket parts ecosystem through platforms like EngineGo carries platform-specific delete components with fitment guides organized by year and engine code — which matters because EGR system configuration changed meaningfully across model years on the 6.7.
If your EGR cooler is failing for the first time on a truck you plan to keep, it’s worth having an honest conversation about which repair actually solves the problem. A cooler replacement buys time. A properly executed EGR delete removes the failure point permanently.
For most high-mileage working diesel owners, the decision usually comes down to this: how many times do you want to pay for the same repair?
