Home Features 2025 BMW 5 Series
2025 BMW 5 Series
14
12038
Mid-sized luxury sedans aren’t what they once were – especially BMW’s mid-sized 5 Series sedan. Like its main rival, the Mercedes E-Class sedan, the BMW 5 used to come standard with a six cylinder engine – as people used to expect when they spent what it costs to buy a mid-sized luxury sedan. Both of them now come standard with 2.0 liter fours – and neither of them have gotten any less expensive.
This isn’t to say the BMW 5 Series isn’t still a very nice car. The problem is it’s less car – under the hood, at least. And it’s also less a BMW in the sense that a 5 Series used to be a very different kind of luxury sedan vs. a Mercedes E-Class sedan.
Now they’re much closer to being pretty much the same.
The 5 Series is – per above – BMW’s mid-sized, mid-priced (for a BMW) sedan. Though the base trim is still called the 530i, it comes standard with a 2.0 liter four cylinder engine, just as its main rival, the Mercedes E350 sedan does. It is interesting – in a telling kind of way – that neither BMW nor Mercedes has adjusted the name to reflect the change. In the past, a 530i came standard with a 3.0 liter six – just as a Mercedes E350 came standard with a 3.5 liter V6. They no longer do, but they still carry the badges that suggest otherwise. Probably because “520i” – denoting the standard 2.0 liter four – doesn’t sound like much when you’re spending $58,700 – which is the base price of the rear-wheel-drive 530i.
You can opt for BMW’s xDrive all-wheel-drive for $61,000.
A 3.0 liter six is available – in the $65,800 540i (which comes standard with xDrive AWD). Interestingly, the badging in this case used to indicate a V8 under the hood. Consider it a form of shrinkflation.
The top-tier iteration of the 2025 5 Series is the $73,400 550e – the “e'” indicating a six amped up via a battery pack and motors to generate a combined output of 483 horsepower. This iteration of the 5-Series can be plugged in – to get a charge – or gassed-up, to avoid the wait.
What’s New For 2025
The plug-in hybrid 550e is new and heated front seats are now standard in the base trim.
Larger, roomier – especially in the trunk – and less expensive by several thousand dollars than its main rival, the Mercedes-Benz E350 ($62,400 to start).
Statelier looking than the Mercedes.
Plug-in hybrid version is about $15k less than the hybrid version of the E-sedan, which is not a plug-in hybrid.
Just shy of $60k to start is a lot to spend for a 2.0 liter four (and just 255 horsepower).
Not especially sporty anymore – which makes it a lot more like the Mercedes E, which has always been the more stately driving of these two.
Smartphone-emulating touch/tap/swipe interfaces are harder to use accurately while the car is moving than knobs, switches and buttons.
The BMW 5 – like the Mercedes E – comes standard with a a 2.0 liter, turbocharged four cylinder engine paired with a “mild hybrid” system – which means the engine shuts itself as often as feasible (as when the car isn’t moving or decelerating/coasting) in order to reduce fuel consumption and also to help BMW comply with government “emissions” requirements pertaining to carbon dioxide. When the engine isn’t running, it isn’t “emitting” anything. A high-powered (48 volt) electrical system is used to restart the engine almost instantaneously.
Interestingly, both the BMW’s 2.0 four and the Benz’s 2.0 four tout exactly the same 255 horsepower, effacing any meaningful mechanical differences between the two. Both cars come standard with rear-wheel-drive; AWD can be ordered optionally.
Also interestingly, both the BMW and the Mercedes have the same type of optionally available engine – a 3.0 liter straight six, also paired up (in both cars) with a “mild hybrid” system. Once again, both of these inline sixes tout exactly the same 375 horsepower.  BMW’s xDrive AWD system is standard with the bigger engine.
The newly available plug-in hybrid drivetrain in the 550e marks the only major drivetrain difference between these two contenders. The first being that the BMW is a plug-in hybrid – which means it can be recharged without driving it (in a conventional hybrid, the running engine is used to generate electricity to recharge the battery pack as you drive) and the second being it can be driven for about 33 miles on battery power alone.
The hybrid version of the Mercedes E-Class is oriented more toward burning gas – for the sake of performance. Its hopped up version of the inline 3.0 six/hybrid setup touts 577 horsepower; the 550e touts 483. It’s not quite as quick as the hot-rod hybrid Mercedes, which can get to 60 in just under 4 seconds. But it’s not far behind and it will leave the Mercedes behind if the latter’s tank is empty and the former has a full charge on tap.
Theoretically, you could drive to work and back on battery power alone – assuming your trip is about 15 miles or less each way. This sin’t going to save you much money given what the car, itself, costs. But there’s a novelty factor there that may appeal to some.
It’s a little disappointing driving the 5 with its standard 2.0 liter engine. Not because there isn’t enough power to get you going quickly; the 530i can get to 60 from a dead stop in about 5.5 seconds – and that isn’t slow.
The problem is that it doesn’t sound like a BMW – a nearly $60k BMW – ought to sound, because a small four cylinder engine does not sound like a six cylinder engine and that’s what a car of this stature – a car at this price point – ought to come standard with. The Mercedes E350’s 2.0 liter four has the same lack-of-gravitas.
How did it come to pass that nearly $60k-to-start mid-sized luxury sedans now come standard with engines the same size – and not much more powerful than – the small fours that come standard in $25k crossovers? It isn’t because that’s what people who spend nearly $60k-to-start crave. And it isn’t because these little turbo-hybrid fours get good gas mileage. The idea that people who spend nearly $60k-to-start on a BMW or Mercedes care about a 5 MPG difference in gas mileage – for the better or the worse – is just silly.
But BMW and Mercedes have to care about gas mileage – because if they don’t, the government will make their cars even more expensive (via heavy fines for “guzzling” more gas gas the government says is permissible) and that makes it harder to sell cars, including the luxury brand ones. The government also makes it hard to sell cars with engines – at all – because they “emit” carbon dioxide (the gas that isn’t a pollutant) when running. So it is necessary to shut the engine off as often as possible.
Thus the “mild hybrid” thing.
On the upside, the “mild hybrid” thing is pretty seamless; the engine shuts off and restarts with little-to-no-indication this is happening. It’s a swift and quiet process. But it raises – again- the question: Of what benefit is this to the vehicle’s owner? If he were free to choose, would he prefer to have a six that stays on until he turns it off – or a “mild hybrid” four that shuts itself off and comes back on to “save gas” and “reduce emissions”?
The optional six makes the rights sounds – but you do have to pay extra ( a lot extra) to hear them.
So equipped, the 5 offers 0-60 in about 4 seconds – as well as the proper sound – but even so, there’s not that much difference anymore between a 5 Series with a six and Mercedes E with a six – especially since they now both have in-line sixes that are exactly the same size and make exactly the same power. There used to be more difference between a BMW 5 and a Mercedes E. The Benz was less athletic but more stately. The BMW was elegant – and much more athletic. Nothing is wrong with either; in fact a lot was good about these differences because they were exactly that. You had a meaningful choice to make. A BMW was the driver’s car while the Mercedes was the car for the buyer who just wanted to drive a very nice, very serene luxury car.
Now driving either is very similar.
Neither car is noticeably more (or less) sporty than the other. Back when BMW offered the 5 with a manual transmission – something Mercedes never did – there was a very noticeable difference. But those days are gone.
Here we come to some meaningful differences!
The BMW 5 – though classified as mid-sized – is much closer to being a full-sized sedan than its main rival, the Mercedes E-Class sedan. It – the BMW – is 199.2 inches long vs. 194.9 inches for the E-Class sedan. Thus – ironically – the 5-Series is the more stately looking of the two. It is also the more practical of the two – another interesting difference – because unlike the Mercedes, the BMW has a large 18.5 cubic foot trunk whereas the Mercedes’ trunk is only 12.7 cubic feet. That’s a smaller trunk than the current Honda Civic sedan’s – and the Civic is a much smaller car than the E-Class sedan.
To put a finer point on it, the Benz’s trunk only has slightly more room for whatever you need to carry than a Ford Mustang (which has a 13.5 cubic foot trunk). And the Mustang is not a practical car. It’s a fun car. But it’s not a lot of fun to own a sedan that isn’t very practical as it’s kind of contrary to the point. Why have the extra doors – and passenger-carrying capacity – if you can’t carry more stuff in the trunk than would fit in the trunk of a two-door sports car?
So – if you prefer a more practical luxury sedan, the BMW is arguably it, vs. the Mercedes, at any rate.
Both cars have interiors dominated by huge LCD displays for both the main gauge panel and the infotainment stuff. The BMW’s differs in having a kind of trapezoidal tachometer and speedometer which is at least different from the Benz’s display. The secondary LCD screen is huge – just shy of 15 inches – and canted toward the driver. Some of the functions can be controlled via hand gesture rather than by actually tapping/swiping. Voice control is another way to avoid having to tap/swipe while driving.
All trims come standard with a very good Harman Kardon audio system and (finally) heated seats for the driver and front seat passenger. Astoundingly, they were extra costs options last year.
The plug-in hybrid 550e gets standard upgraded brakes and is eligible for an adaptive  suspension and rear-wheel-steering. Most trims can be ordered with an exceptionally good Bowers & Wilkins surround sound audio system.
Nearly $60k-to-start doesn’t buy as much as it used to. And you can thank the government for that.
14 COMMENTS
  1. The Start/Stop function on the BMW X5 40i is not what I would call “smooth” or “barely noticeable”, and it has the little hybrid helper.
  2. The One That Got Away. S
    1978 I was on the verge of buying a 530 manual. A bad business decision put the kibosh on that, however. I remember the great feeling of that I-6, so smooth. It fit well with the gearbox.
    Now?
  3. I bought an X5 M60i. I love it. They should be more affordable, so that we don’t have to hear all the rants from envious libtard Subaru drivers.
  4. After owning two Bimmers and two Beemers one comes to understand that BMW stands for “Bring More Wallet”.
  5. One could make the case that a Lexus ES – for one more year, as it still rocks the 3.5V6 – is an alternative to the 5 series and E class. Which appears to be the case in the Chinese market.
    Similar in size, but you trade RWD and handling for longevity, durability and value.
    But that all ends next year.
    Hybridized means bastardized to me.
  6. Except for the price, there is nothing “luxury” about a 4-cyliner BMW.
    For a third, or lower price, a Toyota or Mazda, et al, are more than
    competitive. In 2024 models, BMW was charging $500 for
    what is standard in many vehicles, a cell phone charger.
    Charged extra for leather and metallic paint also.
    BMW – Break My Wallet
  7. Buy a Caddy CT4 or CT5, or their sportier variants the V series or their best Blackwing Series.
    My wife and I drove them all. Caddy won for value, hands down.
  8. Takes a lot of chutzpah to charge more for a whole lot less.
    But they get away with it. People need to leave these cars on the lot until the price comes down a lot, or the V6 and V8 come back.
  9. As someone who was a teenager in the ’80s I remember being fascinated by the 5 Series and E Class. I thought they were so cool. Whenever I would see one, I would go check it out. But in 2025 these cars seem so boring. Both BMW and Mercedes have fallen so far in my opinion. Nothing special about their cars anymore. Back then you would see Mercedes’ with those badges on the grill for achieving varying levels of high mileage. You won’t be seeing that anymore.
    • RE: “But in 2025 these cars seem so boring.”
      Same here, my fellow Gen X.
      Up, is Down.
      Also, I thought about your comment, “Nothing special about their cars anymore” that it pretty much applies to just about Everything built these days: from computers, to buildings, to art, to TeeVee shows & commercials, to cars & trucks …only in the nooks & crannies & barn finds, do you ever find anything unique or special, & usually, it’s only a very old, ‘something’.
  10. ‘Nearly $60k-to-start doesn’t buy as much as it used to. And you can thank the government Donnie Fubar for that.’ — eric
    Yesterday Donnie Fubar’s cockamamie 25 percent tariffs on auto parts went into effect, supplementing the 25 percent tariff on imported vehicles from Germany.
    That $58,700 base price won’t last long … if the 530i with its mighty 2.0-liter lawn mower engine remains available at all.
    Donnie Fubar and German auto makers: Teutonic morons all. They deserve each other.
    p.s. The drivers-seat-view photo showing BMW’s ugly lozenge-shaped instruments, with a tasteless digital zero glowing in the middle, and a great hulking Clownscreen looming above the center console, make me heave in disgust. So does what appears to be a toggle switch gear selector for the eeeiiiiight-speed automatic, with an electric parking brake button below it.
    This overpriced p.o.s. makes me yearn to take a sledgehammer to it, then toss a Molotov cocktail through the window. Burn, baby, burn!
  11. “when you’re spending $58,700 – which is the base price of the rear-wheel-drive 530i.”
    That’s a lot of money for a four cylinder. The wheel and wheel options are downright ugly. The 3.0 only costs about 7 thousand more. I would opt for that plus I would get aftermarket wheels. $58,700 plus 10% tax plus increased insurance costs and you’ve got quite a bill. You gotta be a doctor, lawyer etc to afford that. BMW is turning into a rich man’s car.
