Home Features Most Unused and Unwanted New Car Features?
30
1784
How do you get people to buy a new vehicle? The main way, historically, has been to tempt them with features and amenities that their old vehicle lacked. In other words – and put plainly – to sell them something better than what they’ve got.
The problem has become that new is no longer better – and in some important ways, such as long-term durability and reliability – worse. That may be why so many new vehicles have features and amenities that are at best useless and – at worst – annoying.
For instance, gesture control
The ideas is to make it easier to operate controls that have become less easy to use, because they have been integrated into tap/swipe “menus” on the now-ubiquitous LCD touchscreens that all new vehicles come with now by not having to to tap/swipe the screen that replaced the buttons and knobs that were easy to use. Instead, you’re supposed to twirl your finger – to the right or the left – to increase or decrease the volume of the stereo. Or wave your hand like Luke Skywalker using his Jedi powers to select some item on the screen.
It might be neat – if it worked. If it worked well, I mean.
The problem is that most of the time it only sort of works. You twirl your finger and the volume does increase – or decrease – just too much (or too little) and then you have to try twirling again, to dial it back some (or up some). It also sometimes takes awhile for the system to register your twirling, which leaves you sitting there making strange gestures in the car – during which time you could have just turned a knob to the left or the right and adjusted the stereo’s volume exactly right.
How about those fake dual exhaust tips/cutouts?
Dual exhaust tips once indicated the vehicle had a dual exhaust system. There is an important distinction there. Generally speaking, the only vehicles equipped with dual exhaust are performance vehicles and trucks that have V8 engines, both because it enhances the performance of the engine and because it makes sense in terms of the packaging. The V8 has four cylinders on one side of the “v” and four on the other. It has two separate exhaust manifolds (or headers) bolted to each side of the engine; each manifold/header dumps the exhaust into a separate exhaust pipe that takes the exhaust downstream to a muffler and from there, to the outside world via an exhaust tip on either side of the rear end of the vehicle.
When you were behind such a vehicle and saw those twin tips, you knew you were behind a performance vehicle equipped with a V8.
Now just about every vehicle – including crossovers with tiny four cylinder engines – has a pair of huge dual exhaust cutouts molded into the lower rear bumper, to make it look as if the vehicle had duals when in fact these are just dummies. They are kind of like the sock David Lee Roth reportedly stuffed into his spandex pants to make it look like he had more than he did.
Then there’s the in-car AI voice assistant –
Arnold famously said “talk to the hand” in one of the Terminator sequels. Many new vehicles have something similar. You’re supposed to talk to the AI – which is supposed to serve you as what they style a virtual assistant. By which is meant an assistant who isn’t human and not really there. What is there is a microphone that’s supposed to hear your commands – as for example to call someone in your contacts list (many people foolishly give their vehicles access to their phones, which means they are giving the vehicle manufacturer access to the data on their phones, which will be sold to marketers in order to try to sell them things they aren’t interested in) and a computer that is programmed to respond to them.
The trouble is the system has a hard time understanding commands as well as discerning normal conversations you may be in the middle of with voice commands. You’ll be saying something to someone you’ve already called who is on speaker and the AI assistant will butt in with something like, “I’m sorry, I couldn’t understand” – and you’ll then have to deal with getting it to stop butting in while you’re trying to talk with the actual human you were talking to.
Those “racy” paddle shifters
Like the Start/Stop ignition button that has replaced the ignition key you used to insert and turn to start/stop the engine, paddle shifters are a gimmick inspired by race car systems applied to minivans and crossovers.
In a race car, a key is superfluous because no one parks race cars on the street; in an open wheel race car, electronic shifting is used in part because it lets the driver keep his hands on the extremely tiny race yoke as opposed to using one to shift gears. Things happen extremely fast in open wheel/F1 racing.
Anyhow, someone in marketing thought it would be a sell to put paddle shifters in minivans and crossovers – never mind that the supposed “manual” control of up and down shifting is mostly illusory, since the computer only permits up/down shift control within certain programmed parameters and besides, just leaving it in Drive will result in the quickest 0-60 times and lap times, because the transmission is already programmed to shift faster and better than you can.
Worst of all, arguably, is that paddle shifters are marketed as “better” than shifting for yourself; i.e., they are a consolation prize for the general disappearance of manual transmissions, even in sporty cars.
They are perhaps amusing for a few days/weeks. But the razzle-dazzle wears off quickly precisely because you quickly figure out that you might as well just leave it in Drive.
Finally, the whole host of “assistance” technologies –
Among the most egregious being the so-called  drowsy driver monitors that harass you if you don’t “sit up straight” and “keep your eyes on the road” – The sit up straight part sounds like a scolding kindergarten teacher and the “keep your eyes on the road” means you’ll be hassled if you maintain awareness of what’s to your left and right as opposed to tunnel-visioning straight ahead. You are being watched by infrared cameras built into the dashboard.
The worst part?
Almost no one actually wants all this stuff – yet it’s become standard in most new vehicles. It is like buying a cheeseburger and discovering someone thought it would be “good for you” to sub out the hamburger patty with a soy patty.
Our donate button is here
30 COMMENTS
    • Dang, I wish I could afford to buy the old cars I used to be able to buy very cheaply back in The Day.
      I dream sometimes and look at this inventory up the road:
      https://kinionauto.com/
      The main salesman is Elvis. (He used to sing & do shows in the area.) How cool is that?
      • Morning, Helot!
        Amen that. The Trans Am is nearly done. I am wrestling with two things. One, the shift linkage. The forward gears all engage correctly, but Reverse keeps hanging up for some reason. Two, I got the wrong slip yoke. I foolishly ordered a new part and the damned thing has the wrong diameter U joint holes, with external clips (wrong for my car). I have a correct/original used yoke coming…
  1. Quite a few of those “dual” exhaust tips in the bumper are completely fake. Not only does the car not have dual exhaust, the one it does have doesn’t even go through the bumper. Both tips are fake, it just comes to an end underneath out of sight.
    I suppose the plus with that setup, if your bumper gets hit and damaged it probably won’t damage the actual exhaust. So there is that.
    Come to think about it, the “bumper” is a plastic cover and is also fake.
  2. I work in engineering for the lower case car company I was offered to drive a 25 GMC Sierra home for a day a few weeks ago. My drive is about 50 miles one way. All the hi tech garbage drove me crazy. I was utterly relieved to drive my almost 20 year old car the next day. All new vehicles are horrible.
  3. Most unwanted new car feature?
    A thousand-pound battery to propel it. And here is living proof:
    ‘Honda’s reassessment of its EV strategy and planned cancellation of three EV models for the North American market could lead to losses totaling approximately $15.7 billion for its fiscal year ending March 31, the company said in a news release on March 12.
    ‘It would be the first time Honda has posted an annual loss since its shares were first listed on the Tokyo Stock Exchange in 1957.
    ‘“Honda’s automobile business has fallen into an extremely challenging earnings situation due to various factors, including its inability to respond flexibly to these changes in the business environment, compounded by a decline in the profitability of gasoline and hybrid models due to the impact of newly imposed tariffs,” Honda said.’
    https://www.zerohedge.com/economics/honda-projects-first-loss-1957-157-billion-thanks-ev-strategy-fail
    Or as the Japanese emperor memorably declared some eighty years ago, ‘The EeeVee situation has developed not necessarily to our advantage.’
    HA HA HA HA … did y’all think ‘Joe Biden’ was an automotive engineer? Today they ask him, ‘How many fingers, Joe?’ as he stares blankly and drools on his bib.
  4. Rented a Hyundai for a road trip out west. By the time I got to Atlanta it had told me 20+ times to stop for coffee. I didn’t know Juan Valdez was Korean.
  5. Back in the day when I drove long distances I bought one of those gadgets that fit in your ear and made a loud whining noise if you fell asleep, I’m still here so maybe it saved my life but it was painful to wear.
    Back around 15 years ago I compiled a list of what I wanted in a new car that mine didn’t already have and all I came up with was heated side mirrors and maybe stability control for icy roads. Needless to say I didn’t buy a new car.
    • Heated seats (which actually are not hard to add or retrofit) and heated steering wheel would be it for me. Most likely if I was in a nice hot climate, cooled seats and wheel would make the list. Which is why I have a fleet of antiques. Though on many of mine electric wipers is a really nice upgrade. Vacuum wipers suck… pun partially intended.
  6. Just read an article on WSJ by a guy who’s leasing an EV, and he listed a lot of the downsides, especially the hassle of getting the rear bumper repaired after a minor accident. Cost him a bundle because of all the sensors embedded in there, plus the repairs have to be done by a “certified” EV technician. Even after dealing with all that he concludes by saying he would still buy an EV. Can’t fix stupid.
  7. I gave up on “voice command” in the 2018 Grand Cherokee. Apparently it will do all kinds of stuff, but only if you get the words and words in a phrase it will understand.
    I really miss levers and switches. My ‘79 Gran Prix heat/ac controls totally useful without looking away from the road. Temp lever? A thumbs width from the left stop for a morning drive to work. Mode select too, all the way right was defog, next to that the fan lever up and down. Remember the ac brothers? MAX and NORM
    • Still have all that in my first-gen RAV4.
      And yes, I can do it in the dark by feel without taking eyes off the road.
      Voice command? I shout into the void, but it never answers.
    • Hi Sparkey. Here’s the story on AC for those who missed it.
      How A/C was invented
      The four Goldberg brothers – Lowell, Norman, Hiram, and Maxwell – invent vehicle air conditioning. But they have a hard time marketing it.
      Well, on one 97-degree Detroit summer day, the four brothers walk into old man Henry Ford’s office and sweet-talk his secretary into telling him that four gentlemen are there with the most exciting innovation in the auto industry since the electric starter.
      Henry is curious and invites them into his office. They refuse and instead ask that he come out to the parking lot to their car. They persuade him to get into the car, which is about 130 degrees. Then Max hits the A/C and the car starts cooling down rapidly.
      Well, ol’ man Ford gets very excited and invites them back to the office, where he offers them $3 million for the patent. The brothers refuse, saying they’ll settle for $2 million, but they want the recognition by having a label, ‘The Goldberg Air Conditioner’ on the dashboard of each car in which it’s installed.
      Now old man Ford is more than just a businessman, he’s a smart businessman. And there’s no way he’s gonna put the Goldbergs’ name on two million vehicles – what about his competitors? They haggle back and forth for about two hours and finally agree on $4 million and that just their first names would be shown.
      And so to this day, all Ford air conditioner controls say Lo, Norm, Hi, and Max.
      • Bada brump — tissshhh!
        I’ll be sure to tip the waitress & glad you’re here all week!!
        My daughter groans when I’m at her shop & I start swapping dad jokes with some of the regulars.
    • HA! I agree.
      My ‘Silent Generation’ uncle and my Dad both love the fucking stupid controlling sheet on new cars.
      I don’t understand that at all. It’s totally at odds with what they taught me while growing up. Like, ‘Invasion of the Body Snatchers’ level stuff.
  8. I think a vehicle would sell better if dealerships advertised what is NOT there. Have a “go back to the good old days” sale, where you can purchase a vehicle without any of this safety crap. A real standard transmission 6 to 8 cylinder engines. Regular, old fashioned knobs instead of touch screens. For fun, screw up the younger generation by having the dimmer switch on the floorboard-ha ha. Aaah, as Rolling Stones once sang, “You Can’t Always Get What You Want”.
    • I’ve thought that about the floor dimmer switch – totally baffling to youngins I’m sure.
      Add in a 8 track player & glove box of 8 track tapes.
      I restored my old home stereo system, dug out the ‘70s record collection. My grandson was floored by the rich accurate sound hidden in those 50 year old grooves.
      • I soooo totally miss floor mounted dimmer switches.
        Wish I woulda kept the L.P. record collection I inherited, too.
        As I once saw in a silly vampire flick about the sound, “it’s so, alive”.
  9. I’m driving a rental Dodge Hornet. It has all of these “options” although probably not the Jedi gesture controls. The only gestures I use while driving might get me in trouble for being an aggressive asshole driver.
    Because it is a hybrid of some sort, it constantly cycles the engine. Because it is supposed to be a “sporty” car it includes a tuned exhaust that’s pretty loud in the cabin. So all week long it has been near silent pulling out, then a barely detectable vibration from the ICE starting, then the exhaust roar. Next stop light, repeat. All week has been like this. Had I not been paying attention I probably would’ve noticed but now it has become something I can’t unsee.
    The other thing is there are so many buttons and levers on the steering wheel and column that it is really hard to figure out what does what, and not only that, why they made controlling the tuner frequency more important than driver info screen layout or cruise control mode selection (apparently there are several different modes, I can’t figure out how to change them). And those flappy-paddle shift levers get in the way of all the other stalk controls. Not only that but the seats are, for all practical purposes, an upsized child safety seat. You can’t easily move or look behind you when backing up, you must use mirrors and the camera. The center rear view mirror is mostly blocked by the rear seat headrests.
    What a mess modern cars have become.
    • sOh yea, and because it is a rental, I can’t connect my phone for Apple Airplay maps, so no navigation. Luckily I don’t need it this week because I know the neighborhood. But it does have a speed limit database because there’s a little speed limit sign above the digital speedo that turns red when going over the PSL.
      I checked and there was a list of about 5 previously paired phones in the system. I’m sure some of them are company phones and probably full of call logs and contact list addresses. Nice data breech.
      • Morning Ready.
        For your navigation, just look for a used Garmin on Craigslist and get a model that features lifetime maps. That way you don’t need to pair your phone with the rental. Hands free for calling can be solved with some other gadget.
        Don’t modern cars suck?
        • A simple Kenwood head unit allows everything I need. I understand why people buy factory auto electronics. They arent smart enough to take responsibility so are forced to bend over and take it hard.
          Unfortunate.
        • Oh my phone works just fine for navigation, but that massive touchscreen on the rental is just displaying the radio station.
    • “ upsized child safety seat “
      My absolute pet peeve with new cars. Kings ransom $$$ for the rig, worse than peasant quality seating.
    • Wow. I’ve not been in a new car in a long long time. Your characterization, “Not only that but the seats are, for all practical purposes, an upsized child safety seat” makes me Never want to do so.
      Thanks for sharing. I’ll prolly never forget that descriptor.
      No wonder young people don’t wanna get driver’s licenses, there’s fugly carryover from captivity.\\
      Fun, is a four letter word, these days.
