Home Features 2026 Hyundai Ioniq 9
9
4592
Times are tough for EVs, in part because prospective EV buyers can no longer get the $7,500 tax credit that helped to offset the higher buy-in cost vs. an otherwise similar vehicle with an engine rather than a battery pack.
But that is only part of the reason why.
Another one is the now-well-known range issue which is really a charge-time issue. It is one thing to have a vehicle that can only go 250 or so miles before it needs to be charged up again. The more fundamental problem is the time it takes to recharge.
That can be compensated for by increasing the fully charged driving range – which is what Hyundai hopes will get the EV Reluctant to consider buying the new Ioniq 9.
The Ioniq 9 is a medium-large, three-row crossover similar to Hyundai’s Palisade. In fact both are exactly the same size and look closely related. But they are very different in terms of their drivetrains.
While the Palisade comes standard with a 3.5 liter V6, the Ioniq 9 comes standard with a 110 kWh battery pack. You can pick single motor, which gets you rear-wheel-drive or dual motor, which gets you AWD – as well as a bump in power from 215 horsepower to 303. There is also a high-performance set-up that bundles a pair of more powerful motors (422 horsepower) with AWD.
The rear-drive/single motor version S stickers for $58,995 and touts 335 miles of driving range; the dual motor set-up that’s standard in the SE ($62,765) an SEL ($66,320) trims have a claimed 320 mile driving range. Performance ($71,250) and Caligraphy ($74,990) and top-of-the-line Performance Caligraphy Design ($76,490) trims with the high-performance dual-motor set-up and AWD tout 311 miles of fully charged driving range.
What’s New For 2026
The Ioniq 9 is a new EV just added to Hyundai’s model lineup.
No extra charge for additional range. (Many other EVs come standard with less range than the more expensive trims.)
Room for adults in all three rows.
Advertised range is realistic driving range.
As with any EV, you still have to keep track of range remaining – and make time for recharging.
This EV cannot be charged using a Level I (120V ordinary household) outlet, which means you have to get a Level II (240V) outlet wired up at home or use commercial fast chargers.
At almost $60k to start, the Ioniq costs about $20k more to start than the otherwise similar Palisade; it’s doubtful you’ll save enough on what you didn’t spend on gas to make up for what you spent on the vehicle.
As mentioned, every Ioniq 9 – irrespective of motor count or horsepower – comes standard with the same 110 kWh battery pack. What’s arguably most interesting about this Hyundai EV is that you get the most range with the standard (S) trim. In other words, Hyundai doesn’t tout a long-range iteration that costs extra.
If you want more power – or AWD – both are available, at the cost of some (but not much) range.
The take-home point is you don’t have to buy either if you just want the max-range version of this EV.
This was smart of Hyundai, since it is probably true that the majority of the people who might be shopping for a vehicle of this type are not chiefly looking for how quickly it gets to 60 but practicality. It is, after all, fundamentally a family-type vehicle. And a family-type vehicle that doesn’t go very far unless you pay a lot extra is something like A$25 fast food burger; i.e., it is something at odds with the basic concept.
It is also nice that Hyundai doesn’t bundle the AWD set-up with the high performance dual motor set-up, once again because AWD is a desirable feature in a family-minded vehicle such as this – while 422 horsepower is something like finding a $100 bill on the street. As in its nice to have if you don’t have to pay for it.
An interesting thing about this EV is that it can only be charged one of two – rather than the usual three – ways.
Most EVs can be charged – slowly – via plugging them in to any common household 120V outlet, which has the upside of being able to plug in anywhere there is electricity. The downside is that it takes a long time to recover any significant charge this way; typically, you’ll get about 30 miles’ worth of range overnight.
You don’t get this option with the Ioniq 9.
It can only be charged at a commercial fast charger or via a Level II (240v) outlet that generally requires adding the circuit to your home’s electrical panel. This may require upgrading your home’s electrical panel, if your home is older and the panel you have hasn’t got capacity to add a 240v (and typically, 30 amp) circuit. You also have to have a home. People who live in apartments or who rent may not be able to Level II charge, effectively forcing them to drive to a commercial fast charger.
Hyundai says the Ioniq 9 can be charged from 10 percent to 80 percent in about 24 minutes – but that’s still a half-hour wait at a place that isn’t at home.
On the upside, Hyundai does provide a universal adaptor for the charge port that enables the Ioniq 9 to be charged at pretty much every commercial fast charging kiosk – including Tesla “superchargers.” Some EVs have brand-specific charge ports that do not work with some fast chargers.
Another upside is that the Ioniq 9 is rated to pull as much as 5,000 lbs. with the dual moor drivetrain (3,500 lbs. for the rear-drive model). Hooking up a tailer that heavy will, of course, cut down on how far you can drive before you have to stop for a charge – but because this EV starts out with respectable fully charged range, you could pull a trailer farther before having to stop than is feasible with many other other EVs.
If you didn’t know it was electric, you might not be able to tell it is.
Well, unless you floor it. If you do, you’ll get to 60 in just over four seconds in the versions with the high output dual motor set-up.
Hyundai has done an excellent job of making the Ioniq 9 feel reassuringly normal. Yes, it is quiet – just like the Palisade is. Just as most new vehicles are. Vehicle manufacturers have done a remarkable job of making even vehicles like the Palisade that have engines nearly as silent-running as electric vehicles. The most noticeable difference is the instant forward thrust, which continues linearly as long as you keep your right foot pressing down on the accelerator pedal. There is no sense (or sound) of shifting, because there is no shifting – because there is no transmission. The electric motor(s) directly connect to and drive the wheels.
There is also no fake sound of what isn’t there; i.e., fake engine/exhaust sounds piped into the passenger cabin, to make it sound as if there’s an engine in there somewhere. A number of EVs do this, which is a kind of apology for being electric and that’s odd because people who buy an EV presumably bought one because they wanted to not hear an engine or exhaust noise – much less fake noises.
The main thing is the same thing that comes standard with every EV: keeping track of how much range you’ve got left.
One of the interesting thing about this EV is that Hyundai gives you a spectrum of range remaining. There’s the maximum, the minimum and the likely, which are updated by the computer as you drive. The maximum assumes mostly low-speed driving on flat roads in temperate conditions; i.e., not too hot and not too cold – so less energy is consumed by accessories such as the heater or AC. The minimum assumes continuous high-speed driving and use of electrically powered accessories. The likely is what you’re likely see most of the time. It comports with the roughly 300 miles of fully charged driving range Hyundai advertises and what I experienced during my weeklong test drive, which involves both city and highway driving. It was enough real-world driving range to be able to drive into town and back three times before I needed to stop for a charge at a commercial fast charger.
That, however, can be a hassle – aside from the time spent.
In my experience, some of these fast chargers are clumsy to use; i.e., the “nozzle” can sometimes be balky about unplugging when you’re done charging and some won’t let you charge unless you’ve downloaded an app on your phone. At no fast charger can you use cash to pay for a charge. Also, the charge door is located on the passenger side rear, which effectively forces you or back up to the charger.
The first time you get behind the wheel, you may find yourself wondering how to start – how to turn on – this Hyundai EV – until you see the Start button, which is semi-hidden on the same stalk you use to put the vehicle into Drive or Reverse (by rotating the stalk). The button is very close to the end of the stalk – almost right up against the steering column itself. Once you see where it is – and remember where it is – it’s not a big deal. But newcomers might be confounded for awhile.
The Ioniq is – arguably – what the VW ID Buzz ought to have been. Both are large vans, basically – with room inside for a large family or just a large number of people. The difference is the VW – which has been “temporarily” cancelled for 2026 – didn’t have enough range (just 250 miles, best case) to make it practical for a family. The same issue detracts from the Ioniq 9’s slightly smaller, Kia-badged cousin – the EV9. That one comes standard with just 230 miles of range.
The Ioniq 9 also feels more luxurious. More finely, it doesn’t feel or look like it ought to cost $30,000 rather than almost $60,000 (as the ID Buzz – which has an almost startlingly spartan-looking interior – does).
This Hyundai comes standard with LED headlights, rain-sensing wipers, seat heaters, wireless charging and seven of the new-style USB C charge ports, plus dual 12.3 inch LCD touchscreens. Also standard is a sliding center console that can be slid rearward.
Certain desirable features such as the sunroof and heated steering wheel  are, however, not available with the base S or the next-highest SE trim. You have to step up to the SEL to get the heated steering wheel (and ambient interior lighting) and if you want the sunroof, you’ll have to buy the Limited. If you do, you’ll also get the upgraded 14 speaker Bose premium stereo that’s not available with the lower trims.
Massaging “relaxation seats” are also available.
A neat feature we probably won’t get in this country are second row seats that can turn to face the third row seats – creating a kind of mobile lounge for passengers. The reason why this feature will likely not be available in this country is because of federal “safety” rigmarole.
The difficulty Hyundai may have selling this EV is that buyers might cross-shop the Palisade and decide that spending $20k more to get into something that’s otherwise similar (sans the engine) might not be worth doing. On the other hand, the Ioniq 9 is at least plausibly practical – on account of its standard and realistic 300-plus miles of fully charged range and the fact that it’s also a nice place to spend time in.
Even if you’re just sitting at a fast charge kiosk waiting to get going again.
9 COMMENTS
    • Am I the only one thinking $60 Grand for a future raging electrical bonfire i can’t park within 30 feet of my house?
      It’s a never ending Ren & Stimpy cartoon…
      “It’s an EEEdiot Vehicle, you fool!!!”
      YMMV….
  1. As always, money talks. All these EV sellers have to answer the question, what am I giving the customer that makes them want to spend thousands more?
    So far I have not seen it in EVs.
    More $$ for a similar product isn’t a selling point. If it were, no one would shop at Walmart or Target.
    At the end of a sale, no matter what it is, the buyer wants to feel like they got a good deal. In the world of EV’s one could get some satisfaction that they don’t have to buy gas, or the car is quick, or there is less maintenance, but at the end of the day they’ve purchased transportation.
    These trade offs have not shown to be worth the extra dollars paid. EV will always be a failure with current technology.
    • I agree, Dan –
      The Ioniq 9 is not a bad vehicle for most daily driving. The problem is it’s so much more expensive than otherwise similar vehicles. There is also the time cost, which is not small. Even if you have a home and can Level II charge at home, it takes about 8 hours. That’s fine if you don’t need the vehicle during that time and most of the time that may be true. But there are times when you just need to go – as in right now – and with EVs, that is a problem sometimes.
      There is also the problem of highway driving. I could drive a Palisade up to DC – 240 miles away – without stopping once unless I needed to pee. I’d have to stop at least once, probably, to charge this one up and even if I did make it there without stopping, it’d be very close to needing a charge and then I’d have to find a place and sit and wait there for at least 45 minutes or so. In the Palisade, I can fully refuel in less than five minutes. This is not a trivial difference.
      • I cannot think of any technical limitation on a car being charged on 110V. I know people who work at home and do just that with their EVs and it works just fine on many models and makes.
        • From the review it sounds like it could reasonably be a daily driver or soccer mom transport (if you ignore the disproportionate price of entry). Lots of short, local trips and urban commuting are two use cases where an EV is a plausible option. Particularly the short trips shuttling kids here and there, where asking an ICE to do abrupt start/stop cycles without enough warm up causes a lot of wear and results in terrible mileage. To be successful in these markets you need to do the majority of your charging with the car sitting at home or work between uses. Not allowing 120V charging is an epic oversight or a tacit admission that recovering just tens of miles overnight is insulting and likely to result in unhappy buyers.
          • That’s pretty much my take as well, Eileen –
            Of all the EVs I have test driven to date, it’s the only one I could realistically drive more than once every other day. That’s an improvement!
