Home Features 2026 Hyundai Ioniq 5
10
4416
Even without the no-longer-available $7,500 federal tax credit, the Hyundai Ioniq 5 is affordable for an EV. And not just for an EV, either. This electric crossover’s $35,000-to-start base price is competitive with the starting prices of same-size non-electric crossovers such as the Toyota RAV4 ($31,900), the Honda CR-V ($30,920), the Subaru Forester ($29,995)  and several others that also cost gas money.
The Ioniq 5 is also not fixated on getting to 60 as quickly as possible – at the expense of range. Or cost. The base trim is powerful enough – not over-powered. That’s why it doesn’t come standard with a big price. And that price is thousands lower this year than it was last year.
You can buy more performance – and range – if you want either (or both).
But it’s not one-size fits all – and it’s not ludicrously expensive – which is often the case with EVs.
The Ioniq is a compact-sized crossover-ish/hatchback-esque EV available in several different configurations, beginning with the $35,000 SE standard range, which emphasizes affordability rather than horsepower and driving range. This trim also comes with 19 inch wheels, LED headlights, a six speaker audio system and a flatscreen main gauge panel with a secondary 12.3 inch LCD touchscreen.
You can get more power (225 vs. 168) and range (318 miles vs. the SE standard’s 245 miles) in the $37,500 SE, which comes with an 84 kWh battery pack that can store more electricity than the base trim’s 63 kWh-capacity battery pack. Both of these versions of the Ioniq 5 are rear-wheel drive. AWD (dual motor) is available optionally with the SE. If ordered, the output of the electric drivetrain goes up to 320 hp.
So equipped, the price goes up to $41,000.
The $39,800 SEL adds synthetic leather seats, a power rear liftgate, rear air vents, wireless phone charging pad and adaptive cruise control with lane centering. This iteration also comes standard with the single motor/rear-drive layout but AWD (dual motor) can be added. This increases the MSRP to $43,300.
Limited trims ($45,075) come standard with a panorama sunroof, seat heaters for both rows, plus a heated steering wheel, a sliding center console, digital rearview mirror, rear sunshades and ambient interior lighting, among other upgrades. This model is also rear-drive but AWD is available optionally. So equipped, the MSRP goes up to $48,975.
There is also an XRT trim, which is a kind of EV-take on the “off-roady” versions of many non-electric crossovers, such as the Wilderness versions of Subaru models such as the Forester and Outback. Like them, the XRT comes standard with more ground clearance than the other versions of the Ioniq 5, as well as standard AWD – which includes the higher-output EV drivetrain – plus all terrains tires, tow hooks and different front and rear clips designed to look different and to offer improved angles of approach/departure to enable the XRT ot traverse uneven terrain with less risk of damaging (tearing off) those front and rear clips – which (as is generally true of most new vehicles) are literally clipped on, which is why they are so easily torn off.
You also get an upgraded Bose stereo with eight speakers and a 360 degree/bird’s eye camera system.
The XRT lists for $46,275.
What’s New For 2026
All trims come standard with a charge cord compatible with both Level I (115v standard household outlet) and Level II (240v, electric stove-type) charging as well as an adapter that allows this EV to use pretty much any commercial Level III fast charger. Two colors that were previously restricted to the XRT trim – Ultimate Red and Cosmic Blue Pearl – are now available with other trims.
But the really big news is that the 2026 Ioniq 5 is much less expensive than the ’25 Ioniq 5. The base price last year was $42,600 – or $7,600 higher than the price of the same Ioniq 5 (just one model year newer) today.
Standard model is affordably priced.
More power – and range – is available.
Fast-charges faster than some other EVs.
Standard range isn’t much.
Even fast-charging still takes much longer than the time it takes to gas up a non-electric car.
Faster-than-average depreciation is a cost that comes along for the ride with every EV.
The Ioniq 5 can be a sensible EV or a performance EV – or something in between.
As detailed above, the SE Standard Range is the sensible pick, if you’re not wanting to spend a small fortune on a small EV. It isn’t powerful – just 168 horsepower. Nor is it quick. But it’s also not slow. Zero to 60 takes about eight seconds, which is on par with the 0-60 times of many non-electric small crossovers.
As is true of all EVs, the Ioniq 5 (with the standard set-up) also feels stronger than it is, because of the immediate response – which you get on account of the immediately available torque (258 ft.-lbs at zero RPM). Most gas-engined small crossovers have much less torque and it’s not available immediately. As an example – to make the point – the current Subaru Forester, which is about the same size as the Ioniq 5 (and at $29,995 to start, only a little bit less expensive) comes standard with a 2.5 liter engine that only makes 178 ft.-lbs. of torque and doesn’t make it until the engine has reached 3,700 RPM.
If faster acceleration is wanted, the SE’s powertrain steps it up to 225 hp (and the same 258 ft.-lbs. of torque) which is enough additional scoot to reduce the time to get to 60 to about 7 seconds; range also goes up t 318 miles on a full charge; adding the dual motor/AWD set-up kicks up the power to 320 hp and 446 ft.-lbs. of right-now torque, which is more than most V8s make and much sooner. So equipped, the Ioniq 5 can easily out-accelerate most V8 muscle cars of the ’60s and ’70s – because not one V8-powered muscle car of the ’60s and ’70s was able to get to 60 in 4 seconds.
Very much the same as was the case with the old V8 muscle cars (as well as today’s muscle cars) the additional power and performance comes at a cost – in range (rather than mileage, though it kind of amounts to the same thing). The highest-powered/highest-performance versions of the Ioniq 5 have about 269 miles of fully charged driving range, a loss of 49 miles vs. Ioniq 5s equipped with the 225 horsepower/rear-drive combo.
On the upside, the Ioniq 5 fast-charges more quickly than many other EVs. On the downside, “fast” is still slow – about which more below.
AWD equipped versions can tow up to 2,700 lbs. Rear-drive versions are rated to pull up to 2,200 lbs.
The Ioniq 5 – like every other EV – is almost as silent when it is under way as it is when it’s parked. The sense of movement – that immediate thrust – is how you tell it’s not parked.
There are some things that differentiate this Hyundai EV from other EVs. One of them is the pair of paddle shifters mounted on the steering column. These look like the paddle shifters you see in many cars that have engines because they also have transmissions and the paddle shifters are there to allow the driver some control over the shifting of the gears. But this EV (like most EVs) doesn’t have a transmission, so there’s nothing to shift. But Hyundai has included the paddle shifters to emulate – sort of – the operation of paddle shifters in a vehicle that has a transmission. If you tap the paddle shifter on the left-hand side of the column, the regenerative braking effect increases, giving you something like the feeling of a downshift. You can use this during cornering or when descending a steep grade to slow the vehicle without manually applying the actual brakes. If you tap the paddle shifter on the right, the regenerative braking eases up and your momentum increases, kind of simulating an upshift.
Another different thing about this Hyundai is the way its driving range is estimated. Instead of a single number of miles left to go, a range – from best case to worst case and a likely in-between range – is displayed. This gives you a much better – a much more accurate – feel for how far the Ioniq 5 will actually go before you need to stop to charge it up.
I experienced a roughly 30 percent unfavorable disparity between the indicated driving range available and what remained after I had driven a given distance. One trip began with 217 miles of driving range indicated (in between best case and worst case) and after driving 42 actual miles, I had burned through 71 miles of indicated range. To be fair, part of this drive included a steep ascent from the Roanoke valley up to my place in the mountains – this sort of driving burns range in an EV like my old Trans-Am burns gas. I also had Sport mode turned on and I don’t drive slow. A lighter right foot and a flat road would almost certainly have burned through less charge.
Speaking of which.
Hyundai says the Ioniq 5 charges faster (or can be charged faster) at commercial “fast” chargers than some other-brand EVs. I added 51 miles of driving range after a 25 minute hook-up at an EV Go fast charger. It is possible Tesla-style superchargers are faster than that; Hyundai says that it is possible to go from 10 percent to 80 percent charged in 20 minutes. But the catch is you’d have to find one to plug the Hyundai into. In my area, the EV Go fast chargers are the only conveniently situated fast chargers. And they’re not very fast. That’s not Hyundai’s fault, per se. But the reality is that the rate at which an EV can be charged depends as much on the EV as it does on the charger.
On the upside, Hyundai does include a Level 1 (standard 115V household outlet) power cord that you can use to get a charge anywhere there is electricity. Believe it or not, some other EV sellers charge extra – a lot extra – for a power cord. You find it in the frunk up front. It will take a long time to draw any meaningful charge this way; overnight might get you about 30 miles’ worth. But that’s better than nothing and it’s convenient to be able to “top off” this way, in between visits (and waits) at commercial “fast” chargers.
You can also the same supplied cord to Level II (240V) charge this EV at home in about six hours but you will probably need to have a 240V outlet installed in your garage and a dedicated circuit (on a 40-50 amp breaker which may entail having to upgrade your home’s electrical panel).
The Ioniq 5 can be considered either a small, sporty-looking crossover or a small, sporty-looking hatchback. All of the trims except the XRT are pretty low-sitting (6.1 inches of ground clearance) and that plus the standard 19 inch wheels and raked windshield give it a zippy appearance. The XRT’s slight lift (ground clearance goes up to 7 inches) and off-roady affectations move the needle more to the crossover side of the dial. Either way, the little EV has a lot space inside:  26.3 cubic feet of storage space behind the second row and 59.4 cubic feet with the second row folded forward.
Both of this little EV’s rows have ample legroom (41.7 inches and 39.4 inches, respectively) as well as headroom (39.8 inches and 38.7 inches, respectively) notwithstanding the low-looking roofline. The flat floor (No hump in the middle for the driveshaft tunnel that isn’t needed) increases the feeling of space and allows for a really deep center console that is available in a sliding fore-aft configuration.  Three people can sit pretty comfortably in back because the middle seat isn’t the hump seat.
Most of the secondary controls are tap-swipe but there is still a knob for adjusting the volume of the sound system as well as useful button controls on the steering wheel hub. All trims come standard with five USB power points, two 12V power points and in all but the base SE standard range, a wireless phone charging pad.
The charge port is located on the passenger side rear quarter panel, so you’ll have to back up to many commercial fast chargers.
It is very rare to find a new vehicle that costs thousands less than it did the previous year – but this is one of those rare instances. Last year’s base trim Ioniq 5 SE standard Range cost more than this year’s SEL – two trims up from the base trim. And this year’s SEL ($39,800) is priced nearly $10k less than last year’s SEL ($49,600).
Last year’s XRT listed for $55,500. This year’s lists for $46,275.
That – as President Trump likes to say – is yuge. And for once, in favor of the buyer.
There’s a lot to like about the Ioniq 5 – and it costs thousands less now to like it.
10 COMMENTS
  1. I do like the look of this car and the price is going in the right direction.
    I will testify that the instant torque in the Bolt is something highly desirable and it is unlike anything I’ve ever driven.
    • Absolutely, Landru –
      Dinging people for access to the frunk – or charging them extra for a charge cord – is beyond obnoxious. I’d walk out of the showroom if I encountered such.
          Charging people who buy an EV extra for a charge cord is pretty much the same thing as charging people who buy gas-engined cars extra for a fuel filler door. Or for the privilege of one that opens.
  2. The 2026 Toyota RAV4 Hybrid
    Manufacturer’s Suggested Retail Price (MSRP)
    of $33,350 (includes mandatory $1,450 destination fee).
    2026 Hyundai Ioniq 5SE Standard Range RWD:
    $36,600 (Base $35,000 + $1,600 destination)
    $33,350
    v.
    $36,600
    i think most people would say
    the Rav 4 was a better deal
    • Hi Richard,
      It depends. The roughly $3k difference in purchase price between the two would likely be equalized after about three years of driving and possibly less, depending on the annual mileage and also the cost of electricity vs. gas. I will say – having riven. both – that the Ioniq 5 is more peppy feeling (even with the standard powertrain).
      It is weird hearing myself toot the horn for an EV but this one’s ok, as I see it. I mean, relative to what the same money buys in a hybrid or gas engined otherwise equivalent car.
      • the 2005 hyundai ionoc 5 was &36635
        after the $7500 tax credit including
        the retail price of $42660 and
        $1475 destination fee
        Thei sold 44.789 at that price
        It looks like the 2026 lower price
        is compensating for the loss
        of the $7500 tax credit
        2025 rav4 hybrid sold
        sold 168,000 units at $34,295
        with no tax credits
        Tooting the horn for an EV
        could get you on
        a Trump DOJ watch list
        assuming this website
        hasn’t already got you there
  3. “V2H: The Ioniq 5 Can Power Your Home
    Vehicle-to-Home is a game-changer for the Ioniq 5. During a power outage, a fully charged Ioniq 5 (77.4kWh battery) can power an average home for 2–3 days. But V2H adds complexity to your panel setup:
    Transfer switch required — prevents backfeeding the grid (code requirement)
    Bidirectional charger — standard J1772 only charges one way
    Panel capacity planning — your panel must handle both charging and future V2H discharge
    Even if you don’t set up V2H today, plan your panel for it now. Adding a circuit for V2H later is much cheaper than upgrading your panel twice.”
    https://evchargeright.com/blog/hyundai-ioniq-5-charger-installation
