Home Features 2025 Chevy Tahoe
2025 Chevy Tahoe
35
10513
The Chevy Tahoe is an SUV but it’s also the replacement for the full-size, V8-powered and rear-drive American sedan – which is a type of car that’s not made anymore because the government regulated them out of existence via ever-higher “fuel efficiency” requirements that full-size, rear-drive sedans with big V8s can’t comply with.
SUVs like the Tahoe have survived because they were held to a less onerous regulatory standard than cars as regards how many miles-per-gallon they had to average, else the government would hit their manufacturer with “gas guzzler” fines mean to discourage their manufacture by making them more expensive to sell and thus less affordable to buy.
The last full-size, rear-drive, V8-standard American sedan was the Ford Crown Vic – and it’s been gone since 2011. It could seat six and it could tow – because it had a V8 and a heavy steel frame that could bear the load. These are two things not a single of the handful of front-wheel-drive/AWD and four cylinder-powered cars left on the market today offer.
Americans who need something that fills that gap have moved over to SUVs like the Tahoe. But working and middle income Americans are being pushed out of them, too – by the same government that out-regulated the full-size, rear-drive American sedan.
The Chevy Tahoe is a full-size SUV – not a crossover SUV – with room for up to eight people in three rows. It features body-on-frame construction, like a truck and comes standard with a V8, like the full-size American sedans that were once commonly available in America until they were systematically pushed off the market by federal regs.
It is also the only SUV in its class that offers a diesel engine, too.
The Tahoe’s main rival is the Ford Expedition, which is similar except it no longer offers a V8 (once again, because of the federal regs). The Toyota Sequoia is another rival that’s similar in terms of its general layout but also no longer offers the V8 that used to come standard. All current Jeeps are powered by turbo’d sixes, too.
Tahoes start at $58,500 for the LS trim, which comes standard with a 5.3 liter V8, a ten speed automatic transmission, 18 inch wheels and rear-wheel drive. Adding the optional 4WD system bump the MSRP up to $61,500.
The LT ($61,700 with RWD, $64,700 with 4WD) adds a power rear liftgate ad leather seat covers.
The RST ($66,500 with RWD, $69,500 with 4WD) gets 22 inch wheels, and upgraded interior/exterior trim; the RST can also be optioned with an adjustable-height suspension with GM’s magnetically-controlled shocks, Brembo high-capacity brakes, a free flowing exhaust and air intake and sunroof, among other items.
The Z71 comes standard with 4WD, underbody skid plates, 20 inch wheels with all-terrain tires and higher-clearance front and rear ends. Z71 Tahoes can be ordered with the adaptive suspension and a limited slip rear differential.
The Premier ($73,100 with RWD, $76,100 with 4WD) gets second row bucket seats (replacing the otherwise standard three-across bench)  with heaters for both the first and second row and unique-to-this-trim set of 20 inch wheels.
A top of the line High Country comes standard with the 6.2 liter V8 that’s available as an option in the RST, Z71 and Premier trims, plus a set of 22 inch wheels.
What’s New For 2025
All but the base LS trim can be ordered with an updated version of GM’s 3.0 liter Duramax turbo-diesel inline six. All trims get a revised dash with a new 17.7 inch LCD touchscreen.
A big American sedan like they used to make them – that’s good in the snow, too.
Still comes standard with a V8; is available with a bigger one.
Priced several thousand dollars less than rivals like the Expedition ($57,345 to start) and Sequoia ($62,425) that don’t even offer V8s anymore.
Even though it costs less than rival big SUVs, it still costs  much more than a big American car used to.
Will the huge touchscreen still be working ten years from now?
Both the optional diesel and the larger (6.2 liter) V8 are only available as options in the more expensive trims.
Believe it or not, the Tahoe is the only remaining full-size SUV that still has a V8 under its hood.
The others used to but their latest iterations now come standard with turbo (and turbo-hybrid) sixes instead. These engines are much smaller – e.g., the Ford Expedition’s 3.5 liter V6 – and they don’t use appreciably less gas, but they do tout more standard horsepower. For example, the Expedition’s standard 3.5 liter twin-turbo V6 claims 400 horsepower vs. 355 for the Tahoe’s standard – and much larger – 5.3 liter V8.
But which will last longer?
The V8 doesn’t need a turbo to make sufficient (for a vehicle this size) power. A small six does. That’s a difference that may matter once the odometer and the calendar roll past the warranty period and that may matter to you if you’re planning on keeping the vehicle for longer than the warranty coverage.
If not, you may not care.
What’s inarguable is that the turbo sixes have turbos (and intercoolers and other peripherals specific to turbocharged engines) and that makes them cost more. It is probably why even though the Tahoe comes standard with a big V8, it costs thousands less than its  turbo-hybridized six competitors.
There’s also another – bigger – V8.
The Tahoe’s optional 6.2 liter V8 touts 420 horsepower and 460 ft.-lbs. of torque. This V8 is stronger than the Expedition’s standard 3.5 liter, 400 horsepower turbocharged V6 but not quite as strong as the Expedition’s optional, high-output V6, which touts 440 horsepower and 510 ft.-lbs. of torque.
The Toyota Sequoia comes standard with the strongest engine of the bunch, a turbo-hybrid 3.4 V6 combo that touts 437 horsepower and 583 ft.-lbs. of torque. The Sequoia also touts a 9,520 lbs. maximum tow rating, just shy of the class-leading Expedition’s  9,600 lb. maximum tow rating
The Tahoe’s max is considerably lower at 8,300 lbs.
Rivals’ turbo sixes may be smaller, but the torque-swell provided by the boost is what gives them more grunt to pull heavy loads.
Interestingly, the Chevy’s available turbo-diesel six – which touts 305 horsepower now and 495 ft.-lbs. of torque – does not up the Tahoe’s tow rating. But there is a reason why you might want to buy this engine; more about that below.
A ten speed automatic is standard in the Tahoe – and the Expedition. GM and Ford collaborated on the development of this transmission, so whether you buy the Ford or the Chevy you get the same transmission.
The big American sedans of the past were long – and so is the Tahoe. It’s also tall – and wide – which makes it feel even bigger than a ’70s land yacht. This can be both enjoyable and a bit unnerving, depending on where you’re driving.
On the highway – or on multi-lane roads where there’s plenty of room to maneuver – the Tahoe (and other full-size SUVs) are commanding vehicles to be in, precisely because they are so big and so tall. They enjoy the deference accorded to big dudes when they walk down the street. But as any big dude will admit, being a big dude isn’t as great when you’re trying to walk down a narrow corridor – and it’s a similar thing with the Tahoe and its rivals. These things are nearly as wide as some country roads, which leaves not much room to pass that cyclist up ahead. It’s a similar situation trying to fit one of these big rigs into a car-sized parking spot at the supermarket.
That aside, the Tahoe’s standout driving attribute is the sound of its V8 engines. As strong as the turbo-sixes in rival big SUVs are, they lack the sound-appropriateness of a big V8 engine. This auditory incongruity is why Toyota uses sound augmentation “technology” to make its turbo-hybrid six sound more like the V8 it isn’t. As capable as the Expedition and Sequoia are, there’s something off about the sounds their engines make. It is like riding a Harley that sounds like a Honda. Not that there is anything wrong with the Honda. The point is that a big SUV ought to have a big V8, just as a Harley ought to have a big twin.
The optional diesel six also makes the right sounds. It also allows you to keep driving for almost 600 miles on the highway before the tank runs dry. That is more than 100 miles farther than either of the gas-burning V8s can take you. Equipped with the 6.2 V8, a Tahoe’s highway range is only 432 miles – and that’s not with a trailer behind you.
The diesel is a nice option for those who do pull a trailer (or an RV) and prefer to avoid having to stop every couple hundred miles for a fill-up.
The Tahoe is 211.3 inches long, which is almost exactly as long as the last full-size, rear-drive/V8-powered American sedan – which was the 2011 Ford Crown Victoria. But the Vic could only seat six – because it had only front and rear seats. The Tahoe comes standard with a third row that can accommodate two more passengers. But the most relevant point – the reason why big SUVs are the modern full-size sedan of choice – is because they can seat six in the first two rows, just like a full-size American sedan used to be able to.
There are no new sedans that seat that many. Five is the max. And none of them = not even the “full-size” ones (all of which are six figure luxury-brand sedans now) have much room in their trunks because they’re all not nearly as long as the full-sized sedans Americans used to be able to buy.
The Tahoe is thus effectively not just one big car but two of them. And that is why it and others like it have become the “family car” of choice, for those who can afford one (more about that follows).
Chevy decided – like many other vehicle manufacturers – to go big on touchscreens, too. This Chevy comes standard with an almost-18-inch LCD screen for the secondary system and an 11 inch LCD display in front of the driver. The italics are to make a point. It was only about a decade ago that only luxury-brand vehicles from Mercedes, Audi and BMW, et al came with these glowing LCD displays, which did set them apart from the run-of-the-mill brands that still had analog (or mostly analog) gauges. But LCD displays are the one thing that’s getting cheaper (a 50 inch flatscreen TV costs $300 at Wal Mart) and that’s bad news for the luxury-brands, because now brands like Chevy have screens just as big those inside a Mercedes or a BMW or a Lexus.
So – now – the Chevy looks a lot like a Mercedes, on the inside. Will it prove to be as glitchy? Time will tell.
There is one way the Tahoe and its like are not like the big sedans working and middle income Americans used to commonly drive – which they could because there were many that were affordable. For example, a 1976 Chevy Caprice sedan stickered for just over $5,000 when it was new. Granted, 1976 was 50 years ago – but even when adjusted for inflation, a ’76 Caprice only cost about $26k in todays dollars. A new Tahoe costs nearly twice as much and – yes – it is a much nicer vehicle in terms of all the luxury features it comes with. But what good are they if you can’t afford them?
Increasingly, working and middle-income Americans cannot.
The Tahoe’s the last of its kind, probably, that will ever come standard with a V8.
And that may change come 2026 or 2027.
Our donate button is here
35 COMMENTS
  1. Hi Eric, late reply from Australia
    “The Chevy Tahoe is an SUV but it’s also the replacement for the full-size, V8-powered and rear-drive American sedan – which is a type of car that’s not made anymore because the government regulated them out of existence via ever-higher “fuel efficiency” requirements that full-size, rear-drive sedans with big V8s can’t comply with.”
    We’re actually getting this here, in the GMC Yukon Denali trim. Very happy about this, and seeing a simple V8 ladder on frame petrol motor wagon, much like they used to be. There’s a couple of caveats – the RHD conversion is done locally (along with Silverado, RAM, F150 by various groups) and the cars are offered with manufacturers warranty. Other caveat is price – it isn’t cheap to do this so top dollar for US full size.
    https://www.carsales.com.au/editorial/details/2025-gmc-yukon-full-australian-details-ahead-of-early-2025-debut-147164/
    These conversions have been remarkably successful in Oz. Many wealthy grey nomads now choose these over LandCruisers to tow the big caravan on ‘the Lap’ around Australia. The Silverado is the pick, now that the RAM has lost the V8, for simplicity.
    Diesels have become complex with DPF filter and ‘dusting’ woes that can run up to 30K with destroyed motors, so a simple petrol has proved popular. The other reason the big US pickups appeal is their towing capacity and load weights are not as restricted by regulations, which find many vehicles close to maximum capacity and towball downweight once caravan attached, fuel filled, but before people sit in them!
    I’m still excited for your Dodge Charger (not coming here, presently) now the Sixpacks are being released. 5.2m long, RWD, petrol motor, 4 door sedan – it’s the template of our old industry, too. Big cars for a massive continent. Understand you prefer the V8s, they will probably be put in the Charger in time.
    Only other bit of news to mention: the new model Grand Cherokee and Grand Cherokee L were offered here, but have failed in sales and are being discontinued. This is a real shame, for the ingredients were good: indirect injection 6 cylinder, big wagon, 4×4, space. They did a few things wrong with the launch, mostly ramped the price greatly (high USD vs AUD didn’t help), got rid of the diesel option many used for it’s towing capacity, and no V8. These are running out as demonstrators at big discounts currently.
    Other than that, we’re being flooded by so many Chinese brands I can’t keep up with them all at present. No desire to buy any of them. US automakers could do so much better here as the basic ingredients for what works are similar in both countries.
    Me, I continue to hoard and accumulate my simple reliable Barra 4.0 inline 6 powered sedans and wagons.
  2. The Tahoe was my 2nd choice recently. Because it’s big and has good engine choices (not great though).
    It literally came down to price or value. At the time last year, I wanted the grand cherokee v8, found a couple left, at 75K!!!!!! nope. Tahoe is that min. for on-the-lot, and that’s what I needed, and for the same price I was going to go tahoe.
    When I was ready, Jeep put 17K on the hood, and I bought 2.
    Tahoe might be my next 2 though if jeep doesn’t put the non-etorque hemi back in the GC in 2-3 years.
    Now I just have to watch out for Jim H trying to burn it down, haha………….
  3. 25 years ago, you could get a base Tahoe (RWD 4.8 with steelies) for $25k.
    I suppose the $58k cost of entry into a 2025 matches the LS trim from the same era in terms of features.
    You can probably thank the malinvestment of the EVs for a fair part of that.
    GM ain’t gonna claw back a few wasted billions by selling “strippers.”
    • HA! “GM ain’t gonna claw back a few wasted billions by selling “strippers.””
      I – could – buy one of those pieces-of-crap’s GM gurgi tates, but I never, ever, would.
      I may just rather, attach a cart to a donkey.
      Or, ,,,
      …Are those guys trying to sell this sheet smoking Crack!? Or, just embracing our Overlords in trying to end mobility? Idk.
      Either way: They SUck!
      Fuck ’em!@ And, feed ’em fish heads!
      I’m Not buying any of their controlling crap.
      Not. Ever.
    • Oops, I forgot to mention, non-durable.
      Their crap, is planned obsolescence, sheet.
      I’m reminded of the term, backwardization.
      As in, … psft, who cares?
      [A parade of 1950’s & 40’s tractors drives by]
      Rock Lobster!@
  4. Consistently amazed that those that pretend not believe the Government lies turn to the government inflation calculator . . . That lies.
    “Granted, 1976 was 50 years ago – but even when adjusted for inflation, a ’76 Caprice only cost about $26k in today’s dollars.”
    Let’s get serious – stop comparing purchasing power of fiat dollars to more fiat dollars.
    I’ll grant you comparing to gold and silver is a bit tricky as you get very close to 1971 when the Bretton Woods collapsed but it makes more sense than believing bogus Government lies.
    Let’s look at silver. Silver was $4.35/oz average in 1976.
    $5000/$4.35 =1,149.42 ounces of silver to buy that Caprice
    1949 oz silver today at $38/oz = $74,062.
    The dollar has depreciated a lot more than the government says it has.
    Silver has been in a bull market the last year or so. Even if we go back and few years to account for commodity market lags
    1949 oz x $25/oz = $48,725 which is a far cry from the lie the government is telling. So, . . . . no, a 1976 caprice would not cost $26k in today’s devalued dollars.
    We can argue about which commodity to pick, gold, silver, oil, or whatever but the reality is the Government is still lying to us about the value of first . . . Please stop believing the lie and believe what the markets and your own eyes are telling you.
    • Hi BID,
      I don’t trust the government. That said, it was common back in the ’70s and ’80s for American families – not just rich families – to own a large, RWD American sedan or wagon with a V8. That’s an inarguable fact. Just as it was once common for a man to be able to afford a single family home, wife and kids on his income alone.
      We have been “inflated” out of a lot.
      • Maybe in your neighborhood. Not so much where I grew up.
        Used slant sixes and worn out tires were far more common than a new sedan with a V8 in my neighborhood.
        Not disagreeing that wages haven’t kept up with inflation but need to share that not all experienced the childhood you refer to as if it were universal in this country.
        I had two working parents in 76’ and the best they could afford was a new 76’ Mazda 808 at about $3200.
        $5000 v8 sedans were the territory of my UAW uncle.
        Needless to say – we weren’t welcomed to park in his driveway when visiting.
        • Hmm, this seems pretty good compared to the rest of the world at that time, “I had two working parents in 76’ and the best they could afford was a new 76’ Mazda 808 at about $3200.”
          Keyphrase:… “they could afford […] a new 76’ Mazda 808”
          Let that, sink in.
          “New”
          My F.I.L. was not-so-well-off, same as you guys, I think, yet he could buy a new 442 & then, a basic F-150.
          New.
          …New.
      • Eric, I think BID is simply trying to point out, using PM’s as an economic yardstick, that inflation is MUCH, MUCH worse than the government has been telling/lying to everyone about.
        A $5000 cars, using silver, at $4.35/oz, yes, about 1,150 ounces. But that 1,150 oz at $38/oz? Only $43,700, not even enough to buy a stripper model of Tahoe’s today.
        My folks solved that dilemma the oldest way possible, buying used cars 2 to 5 years old, back then which dropped prices by 35 to 75%, depending on the make and model.
        YMMV….
  5. Eric did not cite the avoirdupois of this gross fatty. [“She was putting on the avoirdupois like nobody’s business,” offers the internet as a ‘humorous’ usage example.] But it’s 5,705 lbs — nigh on three tons of fat-bottomed, zaftig Detroit iron.
    I didn’t like land yachts in their original iteration, when 1969 Chrysler station wagons, with their billowing yards of Coppertone Brown sheet metal, cruised the new interstate highways like a new breed of mechanized pterosaurs. And I don’t like them any better as ‘SUVs’ [Spectacularly Ugly Vehicles].
    These lumbering monstrosities bring out the arsonist in me. I’d like to set one alight, like that Scandinavian guy who blew up a Tesla. There was a Tahoe. It’s gone now:
    https://postimg.cc/TLyqTSQ1
    And a 10-speed transmission? Nobody needs ten speeds, except to MacGyver a CAFE test. AI Overview blandly offers this shocking observation:
    Longevity:
    With proper maintenance and in stock applications, the 10-speed transmission can last for 100,000 to 150,000 miles. However, vehicles with modifications (larger tires, tuning, etc.) may experience earlier failures.
    WHUUUUUTTT?? Muh ten-speed might last 100,000 miles? In a freaking $60K vehicle? You gotta be jokin’ me.
    ‘This way to the egress, folks!’ — PT Barnum
    • Hmm, RE: “Nobody needs ten speeds”.
      “Nobody needs”?
      Has someone hijacked your nic? Or, are you a bit dense on some subjects?
      Nobody, “needs” ?
      Do you not see the slippery slope, there?
    • Hi Landru,
      We’ve had to turn that on – again – because of the god-damned Spam. It’s getting very difficult to leave the comments section wide open because of the god-damned spammers. I would love to be able to smash in the teeth of just one of the assholes who produce this crap.
      The security measures are temporary. I appreciate everyone’s understanding.
        • Not at all, Landru!
          For the past several days, the site’s been under a barrage spam. One “bot” alone was leavings 500-plus spam turds a day. This slows down the site, screws everything up.
          • We know which tribe has become totally obsessed about suppressing any criticism of their ongoing genocide of Palestine through starvation and saturation bombing and their ongoing genocide of western civilization through diversity, perversion, population replacement, miscegenation, usury and mind control.
            These chicken swingers have been taking down web sites for decades. Andrew Anglin’s Daily Stormer was hounded all over the planet by the tribe with every conceivable attack. This is how Jews work. There are many others too.
            So now you seem to have rustled their feathers somehow. They are becoming desperate and their crackdown is becoming ever more draconian.
            It seems to me that you are at a crossroads. You can bend the knee to Jewish power like powerful countries and powerful families have been doing for centuries. You can censor your website from any criticism of the type of Jewish behavior that has gotten them thrown out of 109 countries more than 1000 times.
            Or you can continue to defy them and face the consequences. I am afraid the prognosis here. Ye, Michael Jackson, Mel Gibson, Andrew Anglin and many others have had their lives crushed for not obeying their Jewish overlords. You know that this is why they keep playing mind games with your x.com account too.
            AG has been throwing typical Jewish hissy fits on several threads because a few commentors, me included, try to point out patterns of Jewish abuse. You should understand that Jews are very devious and they won’t just come out and tell you what is going on. Consider how they mined the pagers of Hamas, Hezbollah and Iran and them detonated them when their targets were at home with their families and children. Or consider how they tricked Iran into lowering their guard during peace negotiations and then performed a sneak attack orders of magnitude more despicable then Pearl Harbor when they murdered hundreds of the Iran Elite, and their families as well.
            So you really should obey AG and his Jewish cadre of Rabbi thugs and censor Eric Peters Autos. I and all the other reality based “antisemites” will understand completely. We will lose a lot of respect for you, but we will understand that this is what Jews do and this is why you have to “shut it down” on their behalf.
            All I ask is that you then make your mea-culpas to the Jews official, and then I will know what has happened and I will quite commenting here.
            • No worries, Brosi –
              I won’t ever bend the knee to anyone who tries to make me say or do that which I oppose saying or being pushed to do. I am in the happy (and also unhappy) position of not having children whose security might be leveraged against me. I just don’t care. They can do what they like. My self matters to me more than any other consideration.
            • Got Damn, Brosi. Your weirdness and infatuation, is disturbing.
              I’m not sure if Eric’s ‘wave off’ of it all is worse.
              It’s no wonder Libertarianism gets the bad rap that it does.
              Turns me off. And, I’m as Freedomista as it gets.
  6. I miss my Vic. It got turned into a dirt track car, a fitting end as financially it made no sense to put 2 fenders, 2 wheel wells, 2 quarters and a floor pan in to repair the rust. Oh yeah it needed exhaust and brake line work too.
    The one question I have is regarding income vs affordability. Was buying that Caprice in 1976 that much more affordable than a Tahoe in 2025? Perhaps President Trump can bring back WIN buttons. It worked for President Ford didn’t it?
    • Hi Landru,
      “Was buying that Caprice in 1976 that much more affordable than a Tahoe in 2025?”
      Absolutely. Evidence for this being the fact that such cars were commonly owned by average-income people. Most of my friends’ parents had a big American sedan or wagon when I was a kid. Now only rich people’s kids get to ride around in Tahoes.
      • A cheap and dirty web search shows a list price of around $4134.00 for a 1976 Nova Concours. Sure it was the luxury version of the Nova but that’s $900 less than a than a full size Chevy Caprice. The problem now is that the full size family capable car costs $20K or more than the smaller car does. I guess all that safety crap costs a lot of money.
  7. A 50 inch “smart” TV costs $300 at Walmart because every one available in the store comes loaded with client software for various streaming services and spyware to report your viewing habits back to the manufacturer who then sells the data to interested third parties.
    The carrot to accept this stick has been to increase the size/resolution of the screens, but even the smaller sets where increased pixel count will not make a difference are now “smart” devices.
  8. Government Motors likely had inside information that the gas guzzler tax would not be enforced after the fake President was put into office. That is the way the entire US government and economic system function these days. Its not Crony Capitalism, its Cousinhood Capitalism.
    So GM knew to keep their V8’s and dump the Volt/Bolt while their biggest competition, Mercedes and VW, sunk billions in malinvestment into EV’s. Toyota appears to be the only competition to GM who figured out early on that the “energy transformation” was just more Jewish fraud.
    • Vehicles exiting the design pipeline now entered the process before Impeachment started in 2019.
      Just wait.
      I have pictures from a distance of what looks like a shrouded Crown Vic replacement rolling around the streets of Chicago in March 2019, shortly before Impeachment started. Any rumors of that vehicle disappeared as soon as the hearings began.
      • The GM diesel engine was developed starting in 2019. This meshes with your comment. But one has to wonder why GM (and Ram) was spending money on diesels when the European and Japanese manufactures were forced to drop them under threats of billions in fines like the $20 billion extorted from VW after dieselgate.
        As you say, impeachments had already started and Zero Carbon Joe Biden was a shoe-in. Yet GM knew to throttle back volt/bolt and invest in diesels anyway. The US is nothing more than the corpse of a banana republic that is being looted by Jews.
        Here is what Grok has to say about the 3l diesel:
        “Origins of the Chevrolet 3.0L Inline-6 Duramax Diesel (LM2)
        The 3.0L Duramax diesel (RPO code LM2) is the 6-cylinder diesel engine in the 2021–present Chevrolet Tahoe (fifth generation, T1 platform). Below, I detail its origins, development, specifications, and context, using sources like Diesel Army, GM Authority, and autoevolution, while addressing any inaccuracies.
        Development and Origins
        Introduction: The 3.0L Duramax (LM2) debuted in the 2019 model year for GM’s light-duty trucks (Chevrolet Silverado 1500, GMC Sierra 1500) and was introduced in the 2021 Tahoe and Suburban, later extended to the Z71 trim for 2025, per autoevolution.
        Design Partnership: Unlike GM’s earlier 6.2L diesel (1982–1993, Detroit Diesel, indirect injection, 130–160 hp), the 3.0L LM2 is a modern, clean-sheet design developed by General Motors in collaboration with Isuzu, a long-time partner in GM diesel engines (e.g., 6.6L Duramax). GM’s expertise from the 6.6L Duramax (LB7, 2001) informed the LM2’s design, focusing on efficiency, emissions compliance, and performance for lighter applications.
        Purpose: The LM2 was engineered as a fuel-efficient, high-torque alternative to GM’s gas V8s (5.3L L84, 6.2L L87) for full-size SUVs like the Tahoe. It targets buyers needing towing capability (up to 8,200 lbs in the Tahoe) and better fuel economy (21 mpg city, 28 mpg highway, EPA-estimated) than the 6.2L V8 (16/20 mpg).
        Manufacturing: Built at GM’s Flint, Michigan plant, the LM2 reflects GM’s post-bailout (2008–2013) investment in advanced diesel technology, leveraging lessons from the unreliable 6.2L/6.5L diesels (main bearing cracks, pump issues)”
        So the US automakers strangled superior European diesel technology and then substituted their own. This is just like how the JewSA blew up the Nordstream pipeline and then forced the Europeans to buy US LNG at 5x the price.
        • Grok missed a key point there, that being that Isuzu had nothing to do with the 3.0, it was a collaboration with Opel. Isuzu was only involved in the 6.6 Dmax. The 3.0 is a “superior” European diesel, hence the timing and oil pump drive being on the back of the engine – designed for European cabover trucks.
    • The manufacturers are currently hedging their bets about Impeachment 2.0, but even if the Orange Man escapes that, the Midterms will still be ugly.
